Old Jul 24, 2012, 09:07 PM
unclecrash is offline
Find More Posts by unclecrash
unclecrash's Avatar
white lake michigan
70mm fan
Working on balancing my fan been here for about 45minutes got it whisper quite with all the stock fan parts and the 2855 motor . I did the clock didnt do much so I then went to the spinner and found the sweet spot. Now Im transfering it to the inside hope it says after the silicone dries. I can't seem to find the 70mm motor data page does anyone have a link or know what page its on. Thanks UC
unclecrash is offline Find More Posts by unclecrash
Old Jul 24, 2012, 11:44 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Crash,
is this the thread your looking for?
http://www.rcgroups.com/forums/showt...highlight=cs70
Eric B.
AirX is offline Find More Posts by AirX
Old Jul 25, 2012, 12:05 AM
unclecrash's Avatar
white lake michigan
Originally Posted by AirX View Post
Crash,
Eric B.
Yes thats it, I will bookmark it this time Thanks Eric.
Old Jul 25, 2012, 12:31 AM
Slaanesh is offline
Find More Posts by Slaanesh
Not enough hours in the day
Slaanesh's Avatar
Melbourne
Joined Feb 2009
I'm running an L2855-2100Kv w/ CS10 on 2200mah 5S 45C in my HET ME-163 EDF version.
Is a super setup! And it sounds awesome - like a deeper thrusty white-noise sound.
I originally chose the 2100Kv as it seemed to be somewhat more efficient than the 2300Kv motor, especially on early tests conducted on 4S.
There also seemed to be only a marginal increase in thrust which seemed worthwhile sacrificing for
the large gain in efficiency.
Is this not true on 5S?
Slaanesh is offline Find More Posts by Slaanesh
Old Jul 25, 2012, 12:39 AM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Increases are generally non-linear... you need more power than the thrust % gain you get.
I don't have those numbers here now, but I remember deciding I want 2300kv thrust for my 5S.
Vaguely it was something like 1.25Kg 2100kv (not sure Amps, but prob just under 50A I would think) and 1.4Kg 2300kv for low/mid 50A's.
I can post correct ones in a few hours.
I guess if you don't need or want speed/ power, then 2100kv is fine.
PeterVRC is offline Find More Posts by PeterVRC
Old Jul 25, 2012, 01:07 AM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
The L2855-2100kv on 5S is a good low amp choice with descent thrust.
anlucas is offline Find More Posts by anlucas
Old Jul 25, 2012, 06:28 AM
PeterVRC is offline
Joined Nov 2006
Hmmm the L2855's on 5S were:
2300kv 1.45Kg for 50Amps = 290g thrust per Amp
2100kv 1.35Kg for 44Amps = 307g thrust per Amp
So 2100kv is more efficient, because it is weaker, and as usual if you want more thrust you pay non-linear Amps (Power) increase. (Probably the same reason and maths [squared law] as for speed/drag.... because you are driving air faster). So to drive the same fan faster, for more thrust, gains are a squared law of input power (or something towards that sort of maths) to get that gain. At lower numbers squares are not as dramatic, but as the numbers grow the 'losses' due to that become huge.
For 100g thrust gain, you would probably want to have a good reason to want, or need, that... to make the 6 Amps extra worth it!!
100g/1350g = 7.4% gain
6A/44A = 13.7% cost
Non-linear as would be expected. But if you want it.... you just have to pay for it... LOL
Old Jul 29, 2012, 04:44 PM
alanjets is offline
Find More Posts by alanjets
alanjets's Avatar
Ripoff britain
Joined Jan 2011
whats the best het motor for 4s setup and around 80a too many pages to look through lol
alanjets is offline Find More Posts by alanjets
Old Jul 29, 2012, 06:54 PM
PeterVRC is offline
Joined Nov 2006
I think they have a 2900 approx motor.
80A should be in that 3000kv area, or even a bit higher.
By then you should bench over 1.5Kg thrust
Old Jul 29, 2012, 10:43 PM
Jetsom is offline
Find More Posts by Jetsom
Formerly "Heli Copter"
Jetsom's Avatar
United States, CA, Watsonville
Joined Apr 2009
Here is a video of my Projet A-10 with twin CS 70 10-blades.
Projet A-10 Maiden Flight (3 min 31 sec)
Jetsom is offline Find More Posts by Jetsom
Old Jul 29, 2012, 10:55 PM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
Congrats! Nice runway and landscape!
bamaguy is offline Find More Posts by bamaguy
Old Jul 30, 2012, 12:45 AM
jbc is offline
jbc
Find More Posts by jbc
jbc
WHO's your DADDY!!!
jbc's Avatar
Australia, SA, Adelaide
Joined Sep 2009
Now THAT's what I call a runway!
jbc is offline Find More Posts by jbc
Old Jul 30, 2012, 12:52 AM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
yes we are spoiled
jcdfrd is offline Find More Posts by jcdfrd
Old Jul 30, 2012, 06:48 AM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
2w25 but I dont think it will draw 80 amps, more arround 60 amps.
Eric B.
Old Jul 30, 2012, 09:22 AM
Slaanesh is offline
Slaanesh's Avatar
Melbourne
Joined Feb 2009
HET 2W-23 is 2950kv
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7194 Dec 14, 2015 04:03 PM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 08:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 07:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 02:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 10:36 AM
