Old Jul 23, 2012, 10:14 AM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Not all battery ratings are all the seem....
The nano-tech 25-50c batteries I have perform a touch better than the standard 40C batteries because of the much lower internal resistance.
Smaller sized batteries, irrespecitve of their C rating, do not hold voltage well so their amp delivery capability is only for a few seconds after jamming the throttle all the way.
anlucas is offline Find More Posts by anlucas
Old Jul 23, 2012, 10:15 AM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
If you use less C, then the battery is the part you will be killing, instead of the motor....
Horses for courses.
You need to use the RIGHT (adequate) battery, for the right (load capable) motor.
That is if you want a system that does its true best, AND will continue to do that long term - both battery and motor.
And the various battery 'qualities etc is why "Capable Amps" is a better number to show what they really can do. Not what the flakey C etc say they can do.
I use 2x as the multiplier that a battery needs to do a decent job in a setup - which means drive the motor as what it can do, and not damage the battery via excess load on it.
(but there are 100 and 1 one other factors that come into it all... but I start with the battery capability)
PeterVRC is online now Find More Posts by PeterVRC
Old Jul 23, 2012, 10:21 AM
Joined Nov 2006
Oh, and those motors fried in a twin 70mm using that battery.
So that was 55A each at WOT = 110A and the "174A capable" battery is only marginally up to that job (seeing I say you want 2x the current needs to have good leeway), but at the weight level the battery was, I chose to use that rather than a heavier more adequate battery - at the expense of its harder life, which would mean shorter life overall.
Old Jul 23, 2012, 10:23 AM
Tartago is offline
Find More Posts by Tartago
Plane crazy
Tartago's Avatar
Joined Apr 2006
Originally Posted by airraptor View Post
EXT did you cut the overall length of the blades or the cord?
Also guys i am not tryingto get max power out of these fans, if wanted to do that i would just order a setup from EXT. As i stated earlier these will go in some FREE GWS 262's I have. looking for low power set up with somewhat of a whoosh sound. now if there was a 64mm version it would be simple.
Maybe you can get a pair of Mercury 64mm from the King. Not s cheap as the CS though.
Tartago is offline Find More Posts by Tartago
Old Jul 23, 2012, 10:24 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
40c at 2800mah = 120-ish amps constant ....the 2100kv motor will pull 60-ish amps on 6s no?
That's half the C rating for a 2800mah pack WOT...
That extra half to full volt makes a tangible difference on the operation of these motors it seems. For 12usd to 16usd for these motors I'm not going to complain
No head room = 40c and below for me...I don't mind...40c packs these days are still decent quality and I'm not trying to fly past 90% capacity
erh7771 is offline Find More Posts by erh7771
Old Jul 23, 2012, 10:26 AM
erh7771 is offline
Joined Nov 2005
What's the burst current on the pack?
Regards
Old Jul 23, 2012, 01:05 PM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
St. Martin is offline Find More Posts by St. Martin
Old Jul 23, 2012, 04:30 PM
tofast4u is offline
Find More Posts by tofast4u
speeddemon
United States, TX, Whitesboro
Joined Jun 2011
if saying to high of a C rating is bad then what would be good for a 3000kv motor with a 100amp esc?
tofast4u is offline Find More Posts by tofast4u
Old Jul 23, 2012, 05:18 PM
SteveC68 is offline
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
So is there any housing that the Turnigy SK3 will easily fit in? It sure doesn't go into the CS10 housing.
SteveC68 is offline Find More Posts by SteveC68
Old Jul 23, 2012, 11:51 PM
anlucas is offline
anlucas's Avatar
Joined May 2011
Steve,
which SK3 the 3300kv on a stand-off?
It does fit!....
You just have to inset the ring at an angle and then work it in. Fits like a glove.
Old Jul 24, 2012, 02:25 AM
Joined Nov 2006
I have an SK3 I have never used.... hmmmmm......
Old Jul 24, 2012, 02:26 AM
Joined Nov 2006
Well I don't think "Burst" stands for much of use either.
The best way to know the true ability is test it in the combo. Then you will find out what is sustainable, and what a 'burst' can do too.
And it is never anywhere near what the crap numbers say!! So that is a waste of time worrying about those.
(it is a 30C - 40C battery)
My quoted numbers were 'sustainable'. eg the L2855-2100 did 58Amps sustainable on the battery. 67Amps for peaks (eg rest it and burst again etc). That is 1400W peaks.
If you use a 6S battery that CAN'T do that, then you are overtaxing it and will shorten its lifespan (cycles). Because even though it can't do it, it will be TRYING to. And will run hotter, and if you do it too much it will damage it (strip anode?).
Same as running a battery down too low. Same principle occurs - just relative to how much over-stress you are doing to it.
So you should never be using a battery that is not up to what the load truly wants. You should have a lower kv motor to correct that properly. Or... a better battery.
(there is sort of a circle of 'wants more amps, volts drop, less amps then'... what came first, the chicken or the egg?.... it stabilises volts/amps somewhere.... but overall it is overloading the battery)
Old Jul 24, 2012, 02:31 AM
anlucas is offline
anlucas's Avatar
Joined May 2011
Try it. Just make sure it never spins for long pulling more than 85amps.... or it will do what your 2100kvs did.... I am tempted to try another one but only in a plane of fully unrestricted intakes.. like an ME-262 or an SU-35.
But then again why do that the L2855-2300kv on 5S does better....
Old Jul 24, 2012, 02:41 AM
Joined Nov 2006
Yep, the L2855-2300kv is a killer combo. So if that suits, that is best.
I am not sure what I would use the SK3 for.... was it 3300kv? Too much for even 3S really.
It pretty well has to go into a 5 or 6 blade 3S combo. Which was propbably what I bought it for originally. But I hate 3S 70mm EDF's, LOL. Even 4S.
I don't want to see less than 5S for 70mm's! (though I have a painful F-15 4S CS10.....)
Old Jul 24, 2012, 02:49 AM
anlucas is offline
anlucas's Avatar
Joined May 2011
The SK3-3300kv would do very well in a Wemo on 4S. Just as long as amps are kept down to a max of around 80A.
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7289 Today 01:24 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
