Australia, VIC, Melbourne
Joined Nov 2006
hehe. The rest was fine.
Take two off the CS10.... 8 blades, and might have a good, or bad, side-effect off the "gap" to the output sound. Even taking off 4 and going to 6 could have its own unique sound compared to 'normal' 6's. But for lower blade count you either need more RPM to get the same thrust, or just use it for a lower power output (weaker drive system). And I guess there is a bit of upside leeway to RPM in most typical users cases. I guess there is a chance that doing this idea could give a still nice sound, for that lower torque input needed. I am not breaking any of my CS10 blades off to find out though!! LOL |
Greece, Attica, Athens
Joined May 2011
If it doesn't workout then fine. But if the sound is not different then I may have found a way to reuse stuff.... That's who gave me the idea.... Knife! http://www.rcgroups.com/forums/showp...postcount=3407 |
Latest blog entry: EDF, My First Six Years, mostly Pictures
Joined Mar 2011
well i was looking to keep all ten blades. I was given two GWS me 262's (dont laugh) lol. i was thinking of using these fans on a low power set up. this way i would have that high edf whine but more of a whoosh. now a lower power will have less rpm which means the whoos will go away and more of the whine will be back. so to get the rpm up with a low power set up is thinner cord wise blades. i think it will be easier then you think. i just need to order some fans and extra rotors to mess with.
I also think that the fan is not suited to less blades, it already shows a lot of loss at mild changes in outlet area with all the blades present. Eric B. |
Latest blog entry: T/A 37 Tweet/Dragonfly
Have you checked this out. Been around for a while, exellent for bancing fans.
| Thread Tools | |
| New Product Change Sun 12 blade 90mm | Flip Flop | Electric Ducted Fan Jet Talk | 6431 | May 22, 2013 12:52 AM |
| New Product Change Sun 120mm and new 10 blade 70mm fans | Flip Flop | Electric Ducted Fan Jet Talk | 131 | Apr 27, 2012 07:07 PM |
| Sold Change Sun electric retracts | Flip Flop | Aircraft - Electric - Jets (FS/W) | 3 | May 23, 2011 06:20 AM |
| Sold Change Sun Electronic retracts w/Lander struts | hole digger | Aircraft - Electric - Jets (FS/W) | 2 | May 06, 2011 01:27 PM |
| Sold Change Sun Electric retracts NIB 75.00 | jzuniga | Aircraft - Electric - Jets (FS/W) | 2 | Sep 03, 2010 09:36 AM |
