Old Jul 14, 2012, 10:10 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Looks like its had a hard life! Here is a starmax F15 with Extreme Alloy CS10 fan on 4s, 850w. I am going to get some HD video of it next weekend as the phone cam vid sounds quite different to real life.
Rudys f-15 at PP (2 min 39 sec)
Extreme_RC is offline Find More Posts by Extreme_RC
Old Jul 14, 2012, 10:20 PM
Goody63 is offline
Find More Posts by Goody63
How close are those trees?
Goody63's Avatar
Perth, Western Australia
Joined Apr 2008
http://youtu.be/Obldo_xPQDg
That's choice bro!!
Goody63 is offline Find More Posts by Goody63
Old Jul 14, 2012, 11:30 PM
PAPE is online now
Find More Posts by PAPE
Joined Jun 2012
That sounds nothing like your phase3 F16 with the alloy cs10 fan
PAPE is online now Find More Posts by PAPE
Old Jul 15, 2012, 05:35 AM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Yeah the video is bad, phone cams seem to screw up the audio a lot. Its actually so quiet you dont hear it in the air, no roar, nothing, its a bit freaky actually, I didnt like it at first because it had no intake or exhaust roar but Rudes loves it. Wait till I get some video on my new cam, so far the sound has been really honest with it. Our weather has been terrible lately, this weekend was another blow out, and I got the flu anyway so barely able to type right now
Old Jul 16, 2012, 03:25 AM
jbc is offline
jbc
Find More Posts by jbc
jbc
WHO's your DADDY!!!
jbc's Avatar
Australia, SA, Adelaide
Joined Sep 2009
I've also noticed most videos don't do this fan justice, they seem to pickup the motor whine when in actual fact it's barely noticeable at the field
jbc is offline Find More Posts by jbc
Old Jul 16, 2012, 03:34 AM
anlucas is online now
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
True! Most camcorders are are incensitive to the low to midrange frequencies.
anlucas is online now Find More Posts by anlucas
Old Jul 16, 2012, 10:57 AM
mopetista is online now
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
HK Zephyr - 5-blader w/ good sound?
a bit off-topic (but prominent Anlucas left the remark at HK that the new Zephyr kit should also come w/out the fan and save another 15$ :-)
is it the camcorders, or why do the Zephyrs sound so good, unlike "normal" 5-bladers?
not like a CS70, but halfway there, and no whine, it seems to me
Here's an example, if you don't already know it
Durafly Zephyr V-70 High Performance 70mm EDF V-Tail Glider 1533mm (PNF) V70 (5 min 36 sec)
cheers
Clemens
mopetista is online now Find More Posts by mopetista
Old Jul 16, 2012, 11:13 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
http://www.youtube.com/watch?v=jsFwJr-v5wc
cheers
Clemens
Reminds me of the JF90 and a glider that retracted the JF90 during flight...the wings cutting through air make a great sound
An extremely well balanced wemo or even a SAPAC (which this rotor is close to) will sound great in a plane with a slight more tip whine than CS fan...
The caveats are very well balanced, I mean no harmonics at any RPM....I think TAM and some of the other vendors can get those blades down to turbine level vibrations (or harmonics) which to our human ears is none..
I have one of those rotors balanced in my GWS A-4 and it REALLY sounds nice....great white noise through the intakes...I tried a CS fan but it had a thrust tube and made the sound more quiet.
If you luck up and get one of those rotors really balanced it sounds good but if not you amplify the rotors tip whine a lot....with CS fan tip whine is already fairly low and unbalanced it's more forgiving on the sound
erh7771 is online now Find More Posts by erh7771
Old Jul 16, 2012, 12:05 PM
pardus is offline
Find More Posts by pardus
Graham Dyer
pardus's Avatar
Johannesburg, South Africa
Joined Jul 2003
A lot of the discussions in this thread are about huge power levels, however I'm looking for a recommended motor (& Kv) for around 250W (22A) on 3S? It doesn't sound like much but it's for a twin edf airliner that flies happily on about 300W total (currently GWS EDF 64's). I also don't want to add weight if I can.
So any recommendations?
pardus is offline Find More Posts by pardus
Old Jul 16, 2012, 12:23 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
The L2855-2300 would just about do the trick for a 300watt system. Maybe Anlucas can verify that as I dont have any 3s batts lying about, and on 4s its a little over 600 watts.
Eric B.
AirX is offline Find More Posts by AirX
Old Jul 16, 2012, 01:31 PM
anlucas's Avatar
Joined May 2011
cheers
Clemens
Yeah, it sounds good. I suspect this edf is the same as the vampire's.
The good sound though is a combination of white noise from the nacelle and rotor whine. The CS10 fan should sound awsome in this.
I was tempted if I am going to run the edf all the time, then might as well do it in an F-18 airframe....
If I want a sloper, the Dynamic S might be a better bet.
Old Jul 16, 2012, 01:33 PM
anlucas's Avatar
Joined May 2011
Eric B.
Give me 10mins...
Old Jul 16, 2012, 01:48 PM
anlucas's Avatar
Joined May 2011
Eric B.
I tested in-plane the Turnigy L2855-2300kv using a 3S 2200 45c nano I had around.
One minute into the test the battery voltage kept at 11.3V.
Sustained WOT - 22Amps and 250Watts. The thrust settled to around 700gr.
Peak numbers are 284Watts at 24.2Amps and 100gr more thrust.
Maybe a twin on these could give decent scale performance.
Old Jul 16, 2012, 03:31 PM
pardus is offline
Graham Dyer
pardus's Avatar
Joined Jul 2003
Thanks, that's exactly what I needed to know, much appreciated!
Old Jul 16, 2012, 06:06 PM
jim350 is offline
Find More Posts by jim350
Joined Aug 2011
cheers
Clemens
Because the Zephyr actually comes with a 6 blade rotor.
Typical for HK to not even get the specs listed correctly.
jim350 is offline Find More Posts by jim350
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7224 Apr 21, 2016 02:53 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
