![]() Guess I could give balancing an EDF a whirl, looks a lot harder than my props. |
Joined Nov 2011
The difference in amp draw could caused by high/low timing, exhaust diameter, ducting ... or the accuracy of the meter ..... How long can you stay in the air with that 3000mah pack? thx. for reference: the 2W-20 is used with 3s lipo packs. 3s, 10blade 70mm fan, draws about 55amps Amp draw was 30 Amps with a minifan |
"The new CS 10 Blade rotor has brought that stumax "wooooooosh" sound to 70mm jets!! We have just finished preliminary testing of this new fan and have test flown it in our Foam/Glass F16 with simply amazing results! The new EXTREME CNC Alloy 70mm 10 blade fan sounds amazing in the air, little motor noise, no fan whistle, just the roar of the exhaust and the wooooooosh! Of course its not a stock fan, what you get is the new CS 10 Blade rotor that has been cleaned up and checked for trueness and balance, this is mated to our CNC Alloy housing and comes with 3.17mm shaft adapter suitable for all HET and ARC motors and our custom alloy spinner. We are currently working on shaft adapters with even higher tolerance than the factory ones and will be able to offer better 4mm adapters soon. " I thank you good sir for your fine contribution to the hobby and to my fun time. "Your Order Number is: 2608 Thank you! Your order has been successfully submitted for processing!" Boooooooyyyaaaa ![]() Boy, I posted in the right forum. *happy dance*EDIT: Running 4S 2800mah 30C packs currently. I'm guessing this is heavier than the stock ARF powerplant. But I'll compare weights of each out of the F-18 and check the CG obviously with the new combo and ESC installed. Looks like I need a 80amp ESC now. All I have lying around is a 60amp Turnigy Plush (although it states 80 amp burst) |
Joined Aug 2004
I usually put about 2000mAh back to the pack. 30A for 2w20, 3s with a minifan is more in line with my expectations, when compared with a report of 45A for 2w20, standard 4s setup with the minifan: http://www.rcgroups.com/forums/showp...postcount=6352 However, I think James' numbers are just as valid, given timing and all other variations you outlined above. All these tests confirm that the CS-10 is very sensitive to battery/motor/timing/etc combinations. As long as a motor is not over-driven at the intended power level, the system can be quite efficient. Once a motor is driven pass some power level threshold, the efficiency with the CS-10 will fall off the cliff. |
For sure it will be a bit heavier but it wont be a huge difference, you should be able to get your CG. 4s2800 is fine, and if you wanted an ESC shoot me an email and I will give you some options that might negate the cost of getting one from HK.
Joined Aug 2009
[QUOTE=PeterVRC;22103696]I finished up my ERC alloy CS10 with HET
HET 2W30-2200KV 6S 4000mAH 30C At $77 for a HET, and $13 for the "limited ability" L2855's, I think I would rather the TurnigyXK's (50mm series or even better the 60mm series) - IF they had them! Because they are doing HET jobs for $32 or so. Basically half price or a bit under. Once you go to Tacon or Leopard, you are getting pretty well to HET prices anyway..... and I suspect HET come from Leopard really anyway. It is not the same Leopard series, but could be made for them by Leopard and just different can ends and small changes they requested. Good Info here Peter, but I think you meant to say 28mm series motors not 50mm or 60mm series. 28 series @ 50 or 60mm length . 50 series is way too big for a 70mm fan set up. Im just stating this more so for the new comers, your statement will confuse the hell out of them.
Australia, VIC, Melbourne
Joined Nov 2006
I did mean 50mm or 60mm... the can length, in a 28mm diam motor.
That is what sets the approx power capability of it... bigger can length, more capable. Probably should not have said 'series' without a bit more text to explain... but in that I meant they have a whole series of each motor type. 50mm 60mm and others. Check the range here: http://www.leopardhobby.com/product/...ionID=01020204 |
Joined Nov 2006
LOL, yes even 4S would be way too much. And probably even pushing 3S.
A 2800 on 5S is 71A 1200W. So I expect a 3350 on 3S would be in that 1200W region too, so then 80A or so. Say 75A to 85A range... which is pretty hefty even at the lower Amp end of that. Need a few batteries for that task! Save that motor for a high RPM 3 or 4 blade fan.... on 5S or 6S then. Something doing 50k to 60k RPM. (I have a few [basically Wemo version clones] but I don't know if they can do those sorts of RPMs - I have never tried that). Or really, more optimal on something lower blade count (5 or 6) 4S I would think. |
Well since everyone is putting their two cents I will too.
Heat dissipation is the prime reason not to run the lighter/shorter motors that have a kv that is rather ordinary in other fans that have a rotor design that has less loading. Even power from an efficient motor will produce heat from the current load at extremes but in the case of this Het 2w20 it suffers from the extreme in kv on the CS 70 that is normally used with 2800kv/90gr motor for 3s usage to 2150kv/167gr motor on 6s. Not only do you have to look at motor kv but length/weight/size. Eric B. Btw, I have been working with several low price L2855-2300's for a couple of projects I am working on. I am using Tam's shafts and washers with the stock fans, so far out of 4 motors 2 had hammered bearings and the two I bought from members of this community have come out really smooth and quiet. I am going to shelve the 2bad ones and get a couple more to round out my 4-fan project. |
The bigger the motor the better on any fan, but with the high load fans it`s even more important. Just an example. I`ve switched the 3126 outrunner to a 2200kv on my CS-10 fan. On 6s it`s hitting 93a at about 2.1kw. But the intresting thing is that the motor is hitting 91% of it`s unloaded KV! 91% on a $20-$30 outrunner depending on where you buy it. Those short inrunners will probably be lucky to hit 80% of their KV. The rest of the power is just turning into heat that will cause the motor tube to weaken and let the rotor hit the shroud. |
Latest blog entry: EDF, My First Six Years, mostly Pictures
| Thread Tools | |
| New Product Change Sun 12 blade 90mm | Flip Flop | Electric Ducted Fan Jet Talk | 6431 | Today 12:52 AM |
| New Product Change Sun 120mm and new 10 blade 70mm fans | Flip Flop | Electric Ducted Fan Jet Talk | 131 | Apr 27, 2012 07:07 PM |
| Sold Change Sun electric retracts | Flip Flop | Aircraft - Electric - Jets (FS/W) | 3 | May 23, 2011 06:20 AM |
| Sold Change Sun Electronic retracts w/Lander struts | hole digger | Aircraft - Electric - Jets (FS/W) | 2 | May 06, 2011 01:27 PM |
| Sold Change Sun Electric retracts NIB 75.00 | jzuniga | Aircraft - Electric - Jets (FS/W) | 2 | Sep 03, 2010 09:36 AM |
