Old Jun 19, 2012, 03:31 PM
SkylineFlyer is offline
Find More Posts by SkylineFlyer
Hawk Fanatic
SkylineFlyer's Avatar
United States, KY, Louisville
Joined Jul 2008
Is it a clearance issue? With higher speed, blade stretch and hit shroud? Or is it just the material make up?
SkylineFlyer is offline Find More Posts by SkylineFlyer
Old Jun 19, 2012, 03:33 PM
joe1 is online now
Find More Posts by joe1
United States, OH, Dresden
Joined Mar 2004
rotor
Originally Posted by Tamjets View Post
Here is the video rotor give up.
Last night I ran another one in the shop to make sure that rotor give up over 46k rpm.
Sure enough it fail right after 46k plus.
So three out of three fail over 46k rpm.
It seen working flawless at 44.5k rpm for many flight we did.
http://www.youtube.com/watch?v=wiG1D8O9Kx0
It sounded like you gave it full throttle from 0 when it exploded ??
joe1 is online now Find More Posts by joe1
Old Jun 19, 2012, 03:36 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Was there any slow start included in the motor spin up?
regards
erh7771 is offline Find More Posts by erh7771
Old Jun 19, 2012, 03:41 PM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Everything you guys thinks of I had take that in account and tested.
Blade cut down to test that theory...still blew up blades.
Easy spool up still blew up blades..
In flight testig still blew up blades.
All that happen above 46k rpm.
So is a comfirm rotor give up above 46k rpm.
So watch out and kept it under 44.5kw with nice balance rotor you guys will had good fun with it.
I working fine tuning high effecient 2kw 6s set up to spin 43.5k RPM for every day fun flying without worry about blades blew up.
Only things left is FOD...which no one had control over FOD.
Tamjets is offline Find More Posts by Tamjets
Old Jun 19, 2012, 03:45 PM
joe1 is online now
Joined Mar 2004
rotorYes
Yes, but it sure-ly was not at 46,000 when it blew in the take off video ??
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
My habbit never punch throttle on turbine for EDF. So my throttle spool is very gentle.
If you listen to the first video and all my videos. You can see how I manage throttle.
I even recommending guys had bad habbit hit full throttle too soon by using throtle delay 2 second from idle to full. This help the rotor load up.
Tam's F-100 Maiden (3 min 8 sec)
Old Jun 19, 2012, 03:46 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Data show it hit 46k and jump to 48k.
Old Jun 19, 2012, 03:47 PM
joe1 is online now
Joined Mar 2004
rotor
Humm, amazing !
Old Jun 19, 2012, 03:49 PM
erh7771 is offline
Joined Nov 2005
+1, difference between pitch of that vid and pitch of in flight test is notable...
Of note...
Saw evidence of turbine throwing blades....I'm sticking to EDFs for that alone...the blades that were found are razor sharp!
Old Jun 19, 2012, 04:07 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
LOL....
the fan is so quiet and I even can't hear when is at full thottle. Only my thump can feel it.
Old Jun 19, 2012, 04:09 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Humm, amazing !
Data log is like the bible. You can see the graph at split second before it jump.
My left thump is very quick respond to chop the power anytime in trouble.
Old Jun 19, 2012, 05:38 PM
Super Matt is offline
Find More Posts by Super Matt
Joined Dec 2011
Good thing that happened with plenty of room to spare. Would have sucked if it happened after rotation or just past the end of the runway on takeoff.
I'm still surprised your using the Hun as a test bed with that cheap chinese EDF.
Super Matt is offline Find More Posts by Super Matt
Reply With Quote  (Disabled)
Old Jun 19, 2012, 10:58 PM
Knife Liddle is offline
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Here`s a short vid on mine on the bench. This test is with a tight fitting plywood nacelle that produces the same numbers as the stock intake ring, but has a smaller frontal area and reduced drag as a result.
The lipos were already partialy discharged for the video, but on a fresh charge a full 22.2 volts produced these numbers
22.2 volts
160 amps
3.55 kw
6lbs 7oz thrust
262 mph efflux speed
46,500 rpm
I need better lipos to get these numbers in the air, but a good 65c 6s 4000 should do the trick for some speed runs.
Here`s the video and some pics of the new nacelle.
20120619-223224.MOV (1 min 5 sec)
Knife Liddle is offline Find More Posts by Knife Liddle
Old Jun 19, 2012, 11:03 PM
nighthawk0077 is online now
Find More Posts by nighthawk0077
Canada, ON, Vaughan
Joined Oct 2009
Originally Posted by viperviper View Post
hi, May i know what the AUW of your aircraft? and what is the thrust the 2W-30 produced?
Its ~1.6kg, not sure about thrust, but I underhand launch at 60 degrees or so and it climbs straight up.
nighthawk0077 is online now Find More Posts by nighthawk0077
Old Jun 19, 2012, 11:41 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Wow, that is an awesome little project there Knife!! Well done too!
PeterVRC is offline Find More Posts by PeterVRC
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7289 Today 01:24 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
