Old Jun 18, 2012, 12:30 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Originally Posted by Tamjets View Post
That with batteries?
You be looking at 21 plus
Yes, with 3300mah cells on 12s...same as F120....
Got over 5 minutes mixed throttle on F120 during fly in this weekend and 2lbs of dead weight....vertical almost unlimited without extra weight so keeping it light = more flight time with less efficient fan
The fan I'm talking about gets around 16lbs - 17lbs 3500 watts, come on Tam...you know what fan this is....it's ugly and crude but it puts out with right motor and will fit in SM with very little modding.
erh7771 is offline Find More Posts by erh7771
Old Jun 18, 2012, 12:34 AM
erh7771 is offline
Joined Nov 2005
Did you see the Carf hawk I convert while back?
Yes, 25lbs AUW...used 2700mah on maiden ...really nice numbers ...the video I saw had around 4.5min flight time...with 65c pack and only 2700mah used that can be flown with 3300 cells and have room for 30 second WOT bolter if need be and even more for 4000mah pack.
I will be redoing the wings for this model and pretty much empty cock pit and TAM struts and some ESM etracts..
I will be keeping it light then adding the weight of scale looks later...
Old Jun 18, 2012, 12:37 AM
erh7771 is offline
Joined Nov 2005
Originally Posted by Knife Liddle View Post
This little fan has me taking a fresh look at all of the 90mm kits out there. Take the Golden Hawk F-86(Pro Design. I think ) It's too small for a 90mm. No room for lipos. Fish mouth intake. It would be perfect for this fan, plenty of room for lipos with smaller ducting and the intake could be reduced to a scale size.
After seeing plane stock Habu fly with well broken in 65c packs this weekend and keep up circuit with 120s I'm convinced ducting is really poor in 90% of EDFs...fans too big or ducting to small or too many corners.
To get most of EDF we should be around 90% bench thrust in plane...IINM that's what Habu gets
Old Jun 18, 2012, 09:22 AM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
I didn't check. But it spin 44,500 rpm inflight data around 2.2kw.
Thanks Tam, good information.
Eric B.
AirX is offline Find More Posts by AirX
Old Jun 18, 2012, 09:54 AM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
You are nuts....
Today I blew up another rotor goes over 46k.
So two already blew up over 46k.
It been working flawless 44.5k rpm. Wish CS had better mix on the material adding 2-3% of fiber.
Than we can push harder.
DUH! As I recall, the manufacturer's rating on this fan was right around 40K. No wonder they blow at 44K plus!
bamaguy is offline Find More Posts by bamaguy
Old Jun 18, 2012, 10:27 AM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Yeah...
Just want to confirm where is the limit of the rotor.
But with right mix of injected material. It can handle a lot more.
I spin Wemo 53k and no blow rotor.
Tamjets is offline Find More Posts by Tamjets
Old Jun 18, 2012, 10:58 AM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
I didn't see that you were blowing them at 46k. Guess I better dial mine back some
My tests were hitting more than 48k.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Jun 18, 2012, 11:05 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Tam, maybe you can talk them into making you a HiPo version of the rotor that you could balance and make it good for 60k. I'm serious.
Old Jun 18, 2012, 11:09 AM
MagnusEl is offline
Find More Posts by MagnusEl
MagnusEl's Avatar
Sweden, Gävleborg County
Joined Jan 2004
x-flights rating for the 10 blade is 52.000 rpm...I wonder if they realy tested it...
MagnusEl is offline Find More Posts by MagnusEl
Old Jun 18, 2012, 01:42 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Yeah it would be nice the rotor can hold 50k.
Than it safe to run 2.5kw.
Right now we work on 2kw 6s with NeuMotor to be safe at 43-44k RPM.
This good 70mm set up fly anything up to 8 lbs 90mm plane.
Old Jun 18, 2012, 02:09 PM
bamaguy is offline
bamaguy's Avatar
Joined Feb 2009
I had documentation from Change Sun that listed it at 42K, max. That was when they first became available a few months ago.
Old Jun 18, 2012, 03:04 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Originally Posted by SKYRYDER1000 View Post
Thanks for the reply. I'll be sending you one or two rotors sometime this week.
Send to my shop.
Next week I can balance them.
This is a short week and I be on vacation with family.
Old Jun 18, 2012, 03:12 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Kept wing loading light and you be suprise it use less power to fly.
Just like the F-100 I just got it flew. It flew so light on power and still very fast.
Old Jun 18, 2012, 03:16 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
The F-100 blew the rotor before take off on second.
With broken in 65C pack it goes up to 2.5kw over 48K RPM when it blew.
Old Jun 18, 2012, 04:55 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
The wemotec Minifan rotor is a very different construction, GRP based molding not this carbon impregnated stuff. I already asked the factory about molding the 10 blader in a GRP material, time will tell if it is done.
I run the Minifan rotor at 56K+ with the old ARC2858 setup, and with the new 1W40 its running at 63K without issue, of course balance must be perfect. When I did destructive testing I had to take it well over 70K to explode it, saw over 3.5kg thrust on the stand before it blew, and it took 2 runs to blow it, very tough rotor.
Extreme_RC is offline Find More Posts by Extreme_RC
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7289 Today 01:24 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
