Old Jun 17, 2012, 08:26 PM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Originally Posted by AirX View Post
Tam,
What thrust you getting installed in the F100?
Eric B.
I didn't check. But it spin 44,500 rpm inflight data around 2.2kw.
Tamjets is offline Find More Posts by Tamjets
Old Jun 17, 2012, 08:28 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Originally Posted by Knife Liddle View Post
Looks like old 90mm airframes are the new 70mm airframes, and the old 120`s are the new 90`s. Got to love it.
That means that the Old Turbines are the new 120`s.
With today batteries can handle higher amps.
Everything bump up the next level and save some weight with smaller fan package.
Old Jun 17, 2012, 08:36 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
CS10 Rotors and parts are back in stock, plenty of housings too so bare fan units are available, and with the new Extreme Spinner that fits straight to the stock rotor without the extra machining process needed the price has come down!
Extreme_RC is offline Find More Posts by Extreme_RC
Old Jun 17, 2012, 08:42 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
That`s right, STUPID fast, stupid powerful, probably just plain stupid too, but we`ll see how it holds up.
It`s powered by a Turnigy 3126 that has been rewound to 2.5 turns for aprox 2900kv (need to measure it). I added a 4" long shaft and an extra front bearing to support the longer shaft. The motor has an OD of about 37mm so it`s in the standoff position. I`m using a collet style adapter, but I`ll have to check to see which one it is. No mods to the shroud except what was needed to fit the standoff block. The rotor is bare bones stock.
Note: This is competely insane to run this $15 fan like this. Don`t do it, don`t even think about doing it. (That way I can be the only guy who has one).
Just the Facts.............
6s, 22v ( ran a 6s2p10ah battery to hold voltage)
145a......sustained
3.2 kw....""
97oz thrust.....6lbs 1oz
261 mph efflux speed (measured with Eagletree V3)
Esc used is a Suppo 7s 200a (the type with adjustable timming (30 degrees) and pwm 16k)
I`ll post some pics later. I may have found the powerplant for my Squal.
Cost about $80 for motor/wire/fan/esc. Then add lipos.
You are nuts....
Today I blew up another rotor goes over 46k.
So two already blew up over 46k.
It been working flawless 44.5k rpm. Wish CS had better mix on the material adding 2-3% of fiber.
Than we can push harder.
Old Jun 17, 2012, 08:43 PM
Knife Liddle is offline
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
That F-100 was like a rocket. Looked great!
Knife Liddle is offline Find More Posts by Knife Liddle
Old Jun 17, 2012, 08:54 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Thanks Lee....
This F-100 two year ago I was fly with 90mm at 2.4kw and it was 8.5 lbs.
The speed is much slower do to poor sharp intake lip.
With the 70mm not worry much about the FSA and even sharp intake lip will not penalty as much with over 120 FSA.
Here I shed off almost a pound in weight and smaller fan easy to feed air to the rotor.
We had awesome effecient set up.
Old Jun 17, 2012, 10:03 PM
SKYRYDER1000 is offline
Find More Posts by SKYRYDER1000
SKYRYDER1000's Avatar
NEW JERSEY U.S.A.
Joined Mar 2010
yes...we do for $25 service charge.
Send to my shop and we can balance it.
Thanks for the reply. I'll be sending you one or two rotors sometime this week.
SKYRYDER1000 is offline Find More Posts by SKYRYDER1000
Old Jun 17, 2012, 10:08 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Ok... I be look out for it.
Old Jun 17, 2012, 10:39 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
A Skymaster T-45 empty weight with gear is around 13.5lbs
I have to get some lighter wheels
erh7771 is offline Find More Posts by erh7771
Old Jun 17, 2012, 10:43 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Carf's Hawk is even lighter and bigger too.
Old Jun 17, 2012, 11:01 PM
erh7771 is offline
Joined Nov 2005
Yeah, SM didn't keep the wings light...stabs feel like they've been balsa sheeted over glass and then glassed again..
I was planning on coming in somewhere around 17-18lbs and use a single fan
The ESM wheels I have are pretty nice they're just heavy when every ounce counts
Old Jun 17, 2012, 11:09 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
That with batteries?
You be looking at 21 plus
Old Jun 17, 2012, 11:11 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Did you see the Carf hawk I convert while back?
Old Jun 17, 2012, 11:13 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
This little fan has me taking a fresh look at all of the 90mm kits out there. Take the Golden Hawk F-86(Pro Design. I think ) It's too small for a 90mm. No room for lipos. Fish mouth intake. It would be perfect for this fan, plenty of room for lipos with smaller ducting and the intake could be reduced to a scale size.
Old Jun 17, 2012, 11:20 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
That my idea...LOL
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7286 Sep 12, 2016 11:32 PM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
