Old Jun 15, 2012, 11:27 PM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
Originally Posted by Refalovala View Post
Here is a few videos of my HK fiberglass f16 w/ arc 28-58-1 in a wemo minifan, on a 6s. After I repair it and change the rx in it, I should have some longer and better ones for you.
http://youtu.be/tXS_brZjTWs
http://youtu.be/IjwZ6rAH_to
Desperately seeking relevance....
Michael Paxton is offline Find More Posts by Michael Paxton
Old Jun 16, 2012, 01:48 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
Michael,
+1
Prof100 is offline Find More Posts by Prof100
Old Jun 16, 2012, 02:54 PM
M3ATpl0w is offline
Find More Posts by M3ATpl0w
Progress with the process...
M3ATpl0w's Avatar
NE Alabama
Joined Feb 2011
I loled!
M3ATpl0w is offline Find More Posts by M3ATpl0w
Old Jun 16, 2012, 03:04 PM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Looks like he posted the video on several threads including a none EDF thread.
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
ZACATTACK is offline
Find More Posts by ZACATTACK
ZACATTACK's Avatar
Canada, ON, Hamilton
Joined May 2011
Originally Posted by Tamjets View Post
Just done some testing with full ducting with 58mm exhaust tube in the F-100.
Steve Neu and I been doing R&D lately. He got my TJ70 doing testing and I got his sample motor here doing testing to compare data.
So far the number look really good.
If everything is accurate from what I see.
IT show 10% more effecient than all testing we di with E-flite motor and Mega on the same RPM.
I'll wait for Steve result come in to compare with his testing on the bench with bellmount lip and 58mm exhaust tube.
Soon we had Neu/Tamjets version motor at 2000 watts will do the same as 2300 watts Mega and E-Flite BL32.
As right now information of motor and kv is hidden secret until we had productions ready.
Defintely interested in another TJ70 Tam with the new motor..keep me posted upon completion Buddy!!
ZACATTACK is offline Find More Posts by ZACATTACK
Old Jun 16, 2012, 03:20 PM
Prof100 is offline
Prof100's Avatar
Joined Jul 2007
Gryphon
Oh no, a serial poster of irrelevant videos.
Old Jun 16, 2012, 04:16 PM
PikeStaff is offline
Find More Posts by PikeStaff
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
Gryphon
Was that the video where they were flying on a public road, and about ran the plane into a motorcyclist while landing?
Smooth.... as a train wreck.
PikeStaff is offline Find More Posts by PikeStaff
Old Jun 16, 2012, 04:33 PM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Recycling old junk
Someone mentioned an intake lip? What about a velocity stack? My nephew is into the boom stereo and had an old 15's sub woofer box that was falling apart so I snagged the aluminum ducts for 70mm NASA style testing in small scale! The e-flight is a bit larger but a lander,wemo,het, CS all fit and smooth the flow for testing etc.
PS: Is it me or is the stock CS shroud pretty lame. The motor mount flexes at high rpm causing scrub. I have a CP 3300 on 4s it runs well but tried on 5s and couldn't get past 1/2 throttle without it shaking.The one Phase-3 has isn't much better.
ApexAero is offline Find More Posts by ApexAero
Old Jun 16, 2012, 05:27 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Nice score, there are also lots of plastic ducts available out there for speakers, but your alloy ones are trick
Extreme_RC is offline Find More Posts by Extreme_RC
Old Jun 16, 2012, 10:55 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
But why would you need a CS10 in a speaker box????
PeterVRC is offline Find More Posts by PeterVRC
Old Jun 17, 2012, 12:13 AM
bobbit4447 is offline
Find More Posts by bobbit4447
Fly it like you stole it !
bobbit4447's Avatar
Australia, QLD, Coolum Beach
Joined Oct 2011
Dunno.... but wots a peaker box ? I think it must be a Kings Cross thing.
B
bobbit4447 is offline Find More Posts by bobbit4447
Old Jun 17, 2012, 02:23 AM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Got my F-100 done with TJ70 CS rotor 7s set up.
Peak 2300 watts and steady 2100 watts.
AUW 7.6 lbs.
Let see what the 70mm can do in the 90mm airframe.
Tamjets is offline Find More Posts by Tamjets
Old Jun 17, 2012, 03:20 AM
PeterVRC is offline
Joined Nov 2006
3.45 Kg !!!! That F-100 is going to be a flying brick!! Maybe a fast flying brick.
But I guess fairly typical of a composite 90mm. (though my 90mm Hawker Hunter composite is 3.0Kg).
It also probably makes them fly more like a real version.... More runway needed, higher take-off and landing speed... less manouverable. All the things models usually do "too well'.
Old Jun 17, 2012, 03:26 AM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
This bigger than Habu and be much lighter wing loading. It will fly like a glider. It flew before with 2400 watts at 8.5 lbs.
Old Jun 17, 2012, 08:44 AM
Defacto is offline
Find More Posts by Defacto
Joined Feb 2008
Can I get 5 lbs + static thrust with the cs 10 blade easily?
Defacto is offline Find More Posts by Defacto
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7232 Jun 06, 2016 02:40 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
