Old Jun 15, 2012, 04:41 AM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Just done some testing with full ducting with 58mm exhaust tube in the F-100.
Steve Neu and I been doing R&D lately. He got my TJ70 doing testing and I got his sample motor here doing testing to compare data.
So far the number look really good.
If everything is accurate from what I see.
IT show 10% more effecient than all testing we di with E-flite motor and Mega on the same RPM.
I'll wait for Steve result come in to compare with his testing on the bench with bellmount lip and 58mm exhaust tube.
Soon we had Neu/Tamjets version motor at 2000 watts will do the same as 2300 watts Mega and E-Flite BL32.
As right now information of motor and kv is hidden secret until we had productions ready.
Tamjets is offline Find More Posts by Tamjets
Old Jun 15, 2012, 05:28 AM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Originally Posted by PeterVRC View Post
Or also between the heatsink and motor, if that is all you have (eg for a plastic fan housing).
You can use computer thermal paste, there are some useful 'thickish' grey types. eg Arctic Silver etc.
Not the thinnish white cheap stuff.
My StuMax 90mm has white thermal paste, are you saying that it is a poor heat conductor. I might have to get with ExtremeRC on this.
Eric B.
AirX is offline Find More Posts by AirX
Old Jun 15, 2012, 09:11 AM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
Eric B.
I'm running a HET 700-60 at 3400 watts in my Stu 80mm....I think the paste is doing it's job just fine!
Plus the Stumax alloy center is way bigger than any heat sink! Lots of heat transfer area!
Michael Paxton is offline Find More Posts by Michael Paxton
Old Jun 15, 2012, 09:53 AM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Hi Michael,
Thanks for that info.
I didnt think mark would use something that was inadequate.
Eric B.
Old Jun 15, 2012, 11:16 AM
PikeStaff is offline
Find More Posts by PikeStaff
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
The white stuff, typically, uses a ceramic compound for the heat-transfer mechanism. The silvery-looking stuff uses either real silver or aluminum. That's apparently about the only real difference.
Some interesting reading: http://www.dansdata.com/goop.htm
PikeStaff is offline Find More Posts by PikeStaff
Old Jun 15, 2012, 12:38 PM
AirX is offline
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Pike,
Thanks for that, good reading.
Eric B.
Old Jun 15, 2012, 12:55 PM
Gorilla Glue Expert
PikeStaff's Avatar
Joined Sep 2010
I'm partial to Crest for my heatsink paste.......
Old Jun 15, 2012, 01:19 PM
SkylineFlyer is offline
Find More Posts by SkylineFlyer
Hawk Fanatic
SkylineFlyer's Avatar
United States, KY, Louisville
Joined Jul 2008
Here is the skinny on my quick assessment of the CS10blade 70mm fan w/ STOCK motor from the Venom F-86. I quickly used a spare 50A ESC and on 4s4400mAh 45c (extremely tired nanotechs from last year) and for the initial run up, it seems to be holding. Not sure on the longevity of it all, but here are the numbers after about 30 seconds of run. I'm also not sure on if these are good numbers or if this Venom F-86 will be a dog. Your thoughts?
44 Amps
653.4 Watts
SkylineFlyer is offline Find More Posts by SkylineFlyer
Old Jun 15, 2012, 02:16 PM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
44 Amps
653.4 Watts
Looks rather low for this motor. It should be 60ish amps and 900-1000watts.
Is this measurement taken in the airframe or is it wihout an inlet lip?
If it is on a test stand without an inlet lip then all is OK or your batteries are not up to it.
In the airframe watts/amps and thrust will go up.
Now whether the motor lasts long, that's another question.
anlucas is offline Find More Posts by anlucas
Old Jun 15, 2012, 02:56 PM
Hawk Fanatic
Joined Jul 2008
On test stand w/out intake lip.
Old Jun 15, 2012, 07:18 PM
M3ATpl0w is offline
Find More Posts by M3ATpl0w
Progress with the process...
M3ATpl0w's Avatar
NE Alabama
Joined Feb 2011
Put the lip on and retry.
M3ATpl0w is offline Find More Posts by M3ATpl0w
Old Jun 15, 2012, 07:35 PM
Hawk Fanatic
Joined Jul 2008
Retried with lip. Like I said. Lipos are old, puffed, and pieces of crap.
With the lip:
749.6 Watts
53.17 Amps
Old Jun 15, 2012, 08:21 PM
Refalovala is offline
Find More Posts by Refalovala
Joined Jun 2011
Here is a few videos of my HK fiberglass f16 w/ arc 28-58-1 in a wemo minifan, on a 6s. After I repair it and change the rx in it, I should have some longer and better ones for you.
HobbyKing F-16, w- Arc 28-58-1,70mm MiniFan Pro,6s Repainted,Red Tail and Retracts (2 min 25 sec)
HobbyKing F-16, w- Arc 28-58-1,70mm MiniFan Pro,6s Repainted,Red Tail and Retracts 2 (6 min 59 sec)
Refalovala is offline Find More Posts by Refalovala
Old Jun 15, 2012, 09:01 PM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
Originally Posted by dpowellmeii View Post
Sweet, what A-10 is this?
That A-10 is the LX models A-10.....I also have one. Available from www.toysonics.com (Los Angeles)
bamaguy is offline Find More Posts by bamaguy
Old Jun 15, 2012, 11:10 PM
anlucas is offline
anlucas's Avatar
Joined May 2011
With the lip:
749.6 Watts
53.17 Amps
Oh well, at least the motor is not going to fry with these lipos...
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7289 Sep 27, 2016 01:24 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
