Old Jun 13, 2012, 10:42 AM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Originally Posted by onefastxp View Post
do you think it could handle 8s with throttle management.
That would kill it.
Tamjets is offline Find More Posts by Tamjets
Old Jun 13, 2012, 10:45 AM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
self-censored as a waste of breath.
tracknoob is offline Find More Posts by tracknoob
Old Jun 13, 2012, 10:49 AM
PikeStaff is offline
Find More Posts by PikeStaff
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
Originally Posted by houstonderk View Post
Well here is my presetup. Probably not going to be done before leaving for 6 months but nice to look at nonetheless. I had this setup with the stock 50 amp and motors and was just a beast, so now fully pursuing this plane setup with more power.
Godspeed and good luck. Make sure you get back to it - you got some work to do there and sure would like to see a vid of you flying it!
PikeStaff is offline Find More Posts by PikeStaff
Old Jun 13, 2012, 12:09 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Originally Posted by Tamjets View Post
That would kill it.
There's someone who did 8s on the motor without proper cooling and flew for more than 2mins before smoking windings so maybe proper cooling can get the motor to 3000 watts?
lol..
I don't have 75usd to burn though...wife will be beating me when the "stash" is discovered.
seems like a really good motor like you said
erh7771 is online now Find More Posts by erh7771
Old Jun 13, 2012, 12:11 PM
Joined Nov 2005
Please post vid of flight, someone did upthread and the fans sounded really really nice
Old Jun 13, 2012, 01:23 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Real inflight data
Here is data in our foam Habu that can compare apple to apple.
Is almost identical number on the same watts.
Nick run with Mega 2300kv 6s.
My son Habu E-flite BL32 2150KV on 7s.
How you upload the file to view?
Old Jun 13, 2012, 01:25 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
lol..
That why I put it to the test and you guys don't have too.
Old Jun 13, 2012, 01:36 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
here ya go
jcdfrd is offline Find More Posts by jcdfrd
Old Jun 13, 2012, 02:19 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
also keep in mind that we have been running this bl32 motor in the Habu32's on 80mm fans and pushing them to 7s and they just keep running and then they went into our cs70-10 setups and they just keep running (well over 200 flights), we have yet to smoke one. so if it seems like we like this motor it is because we do like this motor, as the graph shows it is hard to beat at 75 bucks. the mega motor did not last 20 flights for what ever reason it smoked and is gone
Old Jun 13, 2012, 02:23 PM
Joined Nov 2005
Originally Posted by jcdfrd View Post
...the mega motor ` not last 20 flights for what ever reason it smoked and is gone
Same WATT draw?
TIA
Old Jun 13, 2012, 02:26 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Same WATT draw?
TIA
The Habu 32 7s 80mm fan is up there. IT work with the heat sink upgrade.
This weeken is father day. We plan to blew more rotor testing .Don't tell my son that.
Old Jun 13, 2012, 02:31 PM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Just done chance the rotor and test the motor.
Everything working smooth as silk.
Since I got it out to do service. Here is few tip I had done to hold the shaft while tight the nut. Don't hold on the rotor. It will break.
Take the dremel tool cutting disc and cut the slot.
Old Jun 13, 2012, 02:50 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
Same WATT draw?
TIA
same watt in, same rpm out, the bl32 does it on 7s at 95amps and the mega did it on 6s at 109amps
Old Jun 13, 2012, 03:57 PM
onefastxp is offline
Find More Posts by onefastxp
crashing build's character.
United States, AL, Dora
Joined Mar 2008
what is your flite time and what size battery are you running on 7s
onefastxp is offline Find More Posts by onefastxp
Old Jun 13, 2012, 04:25 PM
SKYRYDER1000 is offline
Find More Posts by SKYRYDER1000
SKYRYDER1000's Avatar
NEW JERSEY U.S.A.
Joined Mar 2010
delete
SKYRYDER1000 is offline Find More Posts by SKYRYDER1000
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7243 Jul 18, 2016 07:09 PM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
