Old Jun 06, 2012, 02:56 PM
RugFlyer is offline
Find More Posts by RugFlyer
"LiPo-Blaster"
RugFlyer's Avatar
Duluth, GA
Joined Apr 2009
It's good to have 2 options now for the CS-10 Aluminum Spinners!
I have some of the "EXTREME CS10 PRECISION ALLOY SPINNERS" from http://www.extremerc.com.au/estore/i...oducts_id=1183
They look great plus they sit tightly on the CS-10 rotor so you don't have to buy an additional spinner washer.
RugFlyer is offline Find More Posts by RugFlyer
Old Jun 06, 2012, 04:13 PM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Yup...the more the better.
That way folks can choose where to get it.
When the new E-flite foam Habu coming out.
I bet all the guys want to the upgrade to stock fan with BL32 2150 and CS 10 blade rotor.
Hope CS get more rotor out....I wish just buy the rotor by itself.
My last order got 20 fans and throw away everything and only kept the rotor.
Tamjets is offline Find More Posts by Tamjets
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Originally Posted by RugFlyer View Post
It's good to have options, now we have two for aluminum spinners!
The plate look good to eat.
Old Jun 06, 2012, 06:11 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
I just got a pile more adapters in which has reduced the price a little on them, now only $12.00 for an adapter set with all the fittings.
Adapter and Extreme precision spinner is $21.90 the set. I can send 5 sets in the one pack to anywhere in the US for $13.00 airmail, so get together for your orders guys!
Extreme_RC is offline Find More Posts by Extreme_RC
Old Jun 08, 2012, 12:46 AM
GryphonRCU is offline
Find More Posts by GryphonRCU
GryphonRCU's Avatar
United States, CA, SF
Joined Mar 2008
Originally Posted by erh7771 View Post
You know of a 56+mm long can 2400kv - 2700kv motor?
erh7771,
MEGA 16/35/1.5RE will come in below 2700KV, maybe 2625-2650 KV.
Option of 3.2mm , 4mm, 5mm output shafts (all will have 5mm shaft and bearings inside)
Gryphon
GryphonRCU is offline Find More Posts by GryphonRCU
Old Jun 08, 2012, 01:06 AM
viperviper is online now
Find More Posts by viperviper
Antarctica
Joined Apr 2012
one query: u guys hv the amp drawn and thrust values for 2W23 with 4S and 5S respectively? Pls kindly advise... i hv been searching this thread...can't seem to find the data..
viperviper is online now Find More Posts by viperviper
Old Jun 09, 2012, 01:19 AM
Goody63 is offline
Find More Posts by Goody63
How close are those trees?
Goody63's Avatar
Perth, Western Australia
Joined Apr 2008
70MM EDF Flights
Got a few flights in today with my 'CS' squadron.
I had my TWM J-11B (twin fans with L2855 2300kvs on 5S - 2030w @ 100amps) and FW F-16 (CP 3300kv on 4S - 1200w @ 85amps).
One combined video filmed by a mate on my 'still' camera whilst a couple of other videos shot by another friend on his very nice HD camera.
I'll post them as they load.
Cheers
Dave's F-16.wmv (4 min 50 sec)
Changesun 70MM EDF 10 Blade Powered J-11B and F-16 (3 min 31 sec)
Dave's J11B.wmv (2 min 49 sec)
Goody63 is offline Find More Posts by Goody63
Old Jun 09, 2012, 02:35 AM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Dave, the F-16 sounds just like my Mig-15 with the same motor.....
These CP motors have a distintive sound me thinks.....
anlucas is offline Find More Posts by anlucas
Old Jun 09, 2012, 03:22 AM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Goody, what batteries were you using with those two planes? Brand, mAH, C.
PeterVRC is online now Find More Posts by PeterVRC
Old Jun 09, 2012, 03:48 AM
Antarctica
Joined Apr 2012
video removed.apology.
Old Jun 09, 2012, 03:56 AM
anlucas is offline
anlucas's Avatar
Joined May 2011
Viper,
sounds great!
Old Jun 09, 2012, 10:40 AM
jk671 is offline
Find More Posts by jk671
John
jk671's Avatar
United States, NV, Las Vegas
Joined Mar 2011
Viper, how's it flying on that 6S setup? Any heat issues... amp draw?? Trying to decide between the 2w-25 and the 2w-30 for 6S... i am tired of my motors overheating!
jk671 is offline Find More Posts by jk671
Old Jun 09, 2012, 10:56 AM
Goody63 is offline
Goody63's Avatar
Joined Apr 2008
Hey Pete
The J-11B was running 2 x Turnigy 3000MAH 5S 30C lipos. They had over 50% left (and were almost cold) after 3+ minutes flying today.
The F-16 was flying with Nanotech 2650MAH 4S 35-70C lipos. A little warm after a few minutes flight but just over 20% left after both flights today.
Cheers!!
Old Jun 09, 2012, 12:56 PM
RugFlyer is offline
"LiPo-Blaster"
RugFlyer's Avatar
Duluth, GA
Joined Apr 2009
Nice Video's Dave!
jk...if given a choice of the two on 6S then I'd go with the 2W-30, Less kv and a lot less Amp draw!
My 2W-25/CS-10 is pulling Amps in the mid to high 70's on 5S.
Also here's some BL-32/CS-10 numbers from the same post over on the WingsMaker J11-B Thread.
Power #'s with EDF's Installed in the J11-B. Stock with no Thrust Tube, & the Huge 68mm Stock Nozzles
(may add thrust tubes down to around 60mm)
Changed out the Bad K-Force 100A ESC(the reason for my earlier Low #'s) for a Hobbywing 80A Opto ESC.
*2W-25/CS-10 Fan&Housing 5S Numbers installed in J11-B Sorry no Thrust Numbers, Digital Scale was out at the time.
(Low Timing) 3300/5S/30C =76.63A @ 1377.8Watts / 16.90VM, voltage after 20-25 sec.run, 19.81V.
(Med. Timing) 3300/5S/30C =77.80A @ 1396.5Watts / 16.78VM, voltage after 20-25 sec.run, 20.34V.
(Amp#'s were at around 80 using a 3000kv/40C lipo)
*BL-32/CS-10/Delta-V Housing 6S Numbers installed in J11-B
(Low Timing) 3300/6S/45C =68.82A @ 1578.0 Watts / 22.53VM, voltage after 20-25 sec.run, 24.56V.
(Med. Timing) 3300/6S/45C =70.10A @ 1659.9 Watts / 22.84VM, voltage after 20-25 sec.run, 24.71V.
*Since these numbers were posted I changed out the HW 80A ESC(getting Hot even on Low Timing) to a Castle Phoenix 125 and it really smoothed out the throttle up and numbers are slightly better.
Old Jun 09, 2012, 02:07 PM
jk671 is offline
John
jk671's Avatar
Joined Mar 2011
Thanks... i have to buy 3 setups.... one for my f-18 and 2 for an su-35
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7243 Jul 18, 2016 07:09 PM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
