Old Jun 02, 2012, 04:36 AM
viperviper is offline
Find More Posts by viperviper
Antarctica
Joined Apr 2012
Originally Posted by ApexAero View Post
After following the thread I went ahead and ordered Tam's adapter set prior to ordering the fan. I have not one complaint at all, this is with a CP motor and my fan looked like a squirrel gnawed on the entire bottom surface and trailing edges of the fan from shipping. It sings up to a full woosh and is smooth as a babys butt and I've never balanced it one bit.
hi, may i ask what is the spinner washer for... ? and it's effect with or without it? can advise? as i'm thinking of getting it for my HET motors and CS 10 bladed Fan. tks!!
viperviper is offline Find More Posts by viperviper
Old Jun 02, 2012, 08:32 AM
Antarctica
Joined Apr 2012
Originally Posted by clive45 View Post
Yes remove both red leads and plug ubec into any spare channel.
I have been using these without any trouble
http://www.hobbyking.com/hobbyking/s...dproduct=10313
otherwise there are the Castle Creations becs etc, but I have not had a problem with the HK ones in over 4 years of using them.
I wire the ubec to the battery plug that way if the esc fries and the power lead comes off you still have power to the rx
Thanks Clive! btw, are the input leads of the BEC soldered to the ESC leads? if i dun want to do this, can i use a parallel connector lead?
Old Jun 02, 2012, 09:12 AM
xfatdannx is offline
Find More Posts by xfatdannx
advanced n00b
xfatdannx's Avatar
United States, NE, Omaha
Joined Feb 2012
in your experience (anyone who would like to answer) how well balanced are these outta the box? I know they are not gonna be dynamically balanced until hooked up to a motor and ran but static, how well made are they?
xfatdannx is offline Find More Posts by xfatdannx
Old Jun 02, 2012, 09:42 AM
houstonderk is offline
Find More Posts by houstonderk
United States, MD, Clinton
Joined Oct 2010
So looks like the eflite bl 32 with tamjet adapter on 6s should be good? Thinking about trying this with some 80amp esc's in both my f22 and a10 bh planes. I love the way the fan sounds in the a10, but it def wasn't handling the stock power system at all.
houstonderk is offline Find More Posts by houstonderk
Old Jun 02, 2012, 01:18 PM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
Yes, some folks snip a 6 or 9 inch servo extension in half and using just the power and ground wire, solder those to the BEC and ESC leads. I always use the 22 or 26 gauge wire extensions for that.
bamaguy is offline Find More Posts by bamaguy
Old Jun 02, 2012, 02:19 PM
unclecrash is offline
Find More Posts by unclecrash
unclecrash's Avatar
white lake michigan
hey Clive, tks for your advice. So i still need to remove 2 lead before i plug into the throttle channel? And the ubec lead subsequently into the batt channel?
Any good recommendation on the ubec? reliable one. tks!!
Myself I dont use any bec or ubec's I eliminate all that stuff and run a 5 cell pack straight to the reciever. I lost one plane using the bec before never again.
unclecrash is offline Find More Posts by unclecrash
Old Jun 02, 2012, 03:20 PM
M3ATpl0w is offline
Find More Posts by M3ATpl0w
Progress with the process...
M3ATpl0w's Avatar
NE Alabama
Joined Feb 2011
this 70mm Red Viper F-18 really flies well with this fan setup, on 6S 3300mah lipo. HET 2W25. Lots of thrusts and 3-4mins of flight with few speed passes, rolls, loops and vertical climbs. Just for sharing.
Is that the HK 70mm F22? CS10 in it as well? Rattlesnake posted a vid several pages back with the F22 and it sounds great.
TIA
M3ATpl0w is offline Find More Posts by M3ATpl0w
Old Jun 02, 2012, 03:37 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
the spinner washer takes the play out of the stock spinner to rotor. there is so much side to side play in the stock parts that it makes the spinner unusable. with the washer the play is removed and you can get a good balance with the spinner installed and it wont move on you like the stock parts can. its also a good idea to use true precision shaft adapters
jcdfrd is offline Find More Posts by jcdfrd
Old Jun 02, 2012, 03:42 PM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
John,
Tomorrow look like goes to be hungover....
Tamjets is offline Find More Posts by Tamjets
Old Jun 02, 2012, 03:44 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
ah so you are going to fly really fast tomorrow??........speed runs?????
Old Jun 02, 2012, 10:22 PM
Antarctica
Joined Apr 2012
TIA
yes, it's also fitted with CS10. with 2W18v2. the setup is hot. But the sound is just GREAT!!!
Old Jun 02, 2012, 11:35 PM
THESANDMAN is offline
Find More Posts by THESANDMAN
THESANDMAN's Avatar
United States, NY, New York
Joined Oct 2010
how fast is your f18 with that set up u have
THESANDMAN is offline Find More Posts by THESANDMAN
Old Jun 03, 2012, 12:38 AM
gchrisgo34 is offline
Find More Posts by gchrisgo34
gchrisgo34's Avatar
United States, GA, Jonesboro
Joined Nov 2010
Originally Posted by Mannyman535 View Post
Where did you purchase this fan from
i purchased it from PW-RC.com $16 plus shipping.
gchrisgo34 is offline Find More Posts by gchrisgo34
Old Jun 03, 2012, 12:44 AM
gchrisgo34's Avatar
Joined Nov 2010
where do you get an adapter that will work with the HET 2w-20, 3.17mm shaft. the ones at tamjets are for 4-5mm shafts?
Old Jun 03, 2012, 12:57 AM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
are you running 4s? if so cross your fingers and hope you get a good one with the fan
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7224 Apr 21, 2016 02:53 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
