Old May 30, 2012, 10:53 AM
nighthawk0077 is offline
Find More Posts by nighthawk0077
Canada, ON, Vaughan
Joined Oct 2009
Originally Posted by jk671 View Post
my cp shafts were sometimes bent a little as well... i just bent them back until they ran smoothly... a little trial and error...
btw.... has anyone ran the HET 2w-30 on 6S? I swear I want to run these motors... just don't want to buy 3 motors and then come to realize I made the wrong decision. But I seriosly think that the 2w-30 will be a great motor on 6S for this motor... anyone test it out yet?? i want to get my f-18 back in the air!
I've been running the 2W-30 on 6S for a few weeks now. Fan is unbalanced and doesn't sound as nice as some of the other setups yet, but it makes a ton of power on 25C nanos and pushes my Panther Lander to ~95mph.
Go for it, you won't regret it!
P.S. there is also an 8S option with this motor.... if you have space and the guts
nighthawk0077 is offline Find More Posts by nighthawk0077
Old May 30, 2012, 11:28 AM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Originally Posted by anlucas View Post
To close this vibrating CP 2800kv motor issue.
It was the shaft that was bent ever so slightly.
I have to give credit to Hobby-Paradise.com who after asking me the right questions, confirmed the issue and are sending me a new motor in replacement without me asking for it.
Nice.
tracknoob is offline Find More Posts by tracknoob
Old May 30, 2012, 12:26 PM
jk671 is offline
Find More Posts by jk671
John
jk671's Avatar
United States, NV, Las Vegas
Joined Mar 2011
Originally Posted by erh7771 View Post
How did you go about doing the bending. I think I have a bent shaft also
I would just run spool up the motor a little... Maybe 10% throttle... And listen and watch for imbalance... When these motors are balanced, it is the smoothest sound in the world!!! If it wasnt balanced i would just push on the shaft.. Oh yeah i did this with the shaft adapter on... So yanking and pushing on the shaft was a lot easier.... Then i'd run it up again to see if i'd made any progress.. Agin like i said before trial and error. Eventually you are bound to get it.... Luckily it only took 5 minute for me!!
jk671 is offline Find More Posts by jk671
Old May 30, 2012, 12:29 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Ah, with shaft adapter I can see it being twice as easy...
good idea
erh7771 is online now Find More Posts by erh7771
Old May 30, 2012, 12:35 PM
jk671 is offline
John
jk671's Avatar
Joined Mar 2011
good idea
Yup! You dont have to push or pull hard sometimes the least amount of pressure is all it takes!
Old May 30, 2012, 04:09 PM
clive45 is online now
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
surely if you can bend the shaft that easy what will happen with the centrifugal force of a fan when you turn quickly. Does not sound like a good fix to me, get a new or better shaft, better still get a better motor
clive45 is online now Find More Posts by clive45
Old May 31, 2012, 06:24 PM
joe1 is offline
Find More Posts by joe1
United States, OH, Dresden
Joined Mar 2004
Cs 10
Hi :
I forgot to ask in my last post, how do you measure RPM on the 10 & 12 bladed fans.
I have a tach for 2,3 and 4 bladed props, so do I set my tach on 2 and time it by 5 or do I have to buy a new tach .
joe1 is offline Find More Posts by joe1
Old May 31, 2012, 07:04 PM
dpowellmeii is offline
Find More Posts by dpowellmeii
Madison, MS
Joined Oct 2006
Get you a KV meter.
http://www.hobbyking.com/hobbyking/s...KV_Reader.html
Beware though, this one shows what you would assume to be 2 pairs of positive and negative wires coming out where you could solder on some deans connectors but mine came with the xt connectors soldered right on the pcb. Luckily I had one male and female xt connector lying around.
I emailed hobbyking about this and told them they needed to change their picture and they didn't seem to give a crap.
Other than that it works good.
dpowellmeii is offline Find More Posts by dpowellmeii
Old May 31, 2012, 07:27 PM
joe1 is offline
Joined Mar 2004
KV- Meter
Hi :
Is there anywhere in the states that sell these meters, as I will not order from HK.
Thank You
Joe
Old May 31, 2012, 07:46 PM
Madison, MS
Joined Oct 2006
http://www.rchotdeals.com/Products/r...s/kvmeter.html
Old May 31, 2012, 08:15 PM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
Originally Posted by dpowellmeii View Post
Over double the price of HK!
bamaguy is offline Find More Posts by bamaguy
Old May 31, 2012, 09:10 PM
Madison, MS
Joined Oct 2006
They are located in the U.S.
http://www.rchotdeals.com/Products/rc/contactus.html
That's the price you pay since its made in china then they ship it over here. Take your pick, I give up.
Old May 31, 2012, 10:29 PM
joe1 is offline
Joined Mar 2004
KV-Meter
I have bought through Hot R/C Deals before, and they are more but at least they are in the U.S. and they have the correct plugs.
I Thank You.
Old Jun 01, 2012, 06:55 PM
unclecrash is offline
Find More Posts by unclecrash
unclecrash's Avatar
white lake michigan
CS 70mm shroud dia.
Im thinking about starting back on a build that has been sitting for quite some time. Its a warthog, I have built the pods for minifans and the fit is perfect to them. I would like to use the CS 10blade fans. Can someone get me a very accurate outside and inside shroud diameter in millimeters.
unclecrash is offline Find More Posts by unclecrash
Old Jun 01, 2012, 07:32 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
hi Dave
I would highly recommend that you not use the cs housing as they are crap if you already have them fit to mini housings just use the cs 10blade rotor in that housing otherwise use the delta v15 housing. Tam sells the rotor dynamically balanced with a 4 or 5mm shaft adapter and spinner washer. that would be the way to go
John
jcdfrd is offline Find More Posts by jcdfrd
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7232 Jun 06, 2016 02:40 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
