Old May 19, 2012, 11:56 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Originally Posted by Thomas Nelson View Post
Hi Eric
Yeah, erh7771 is actually using a Cyclone Power unit which has the motor on a stand-off, well back of the motor mount. This places the motor away from the mount and in the airflow, which is probably why this 145 gram motor can handle that crazy amount of power without nuking itself or melting the mount. In fact, this is the same kind of power my 330 gram HET (also 6S) sees when spinning my 90mm CS12 setup.
tn
Yeap, 2500 watts would burn a lot of things real quick. The hols in the beginner of the mount at the end of the stand off allow for a good amount of air to flow through pretty good.
I kept WOT on the motor for longer than 2 mins, sick performance in a GWS A-4 but at 2500 watts something that small isn't going to last long..
erh7771 is online now Find More Posts by erh7771
Old May 20, 2012, 07:56 AM
Goody63 is offline
Find More Posts by Goody63
How close are those trees?
Goody63's Avatar
Perth, Western Australia
Joined Apr 2008
Originally Posted by RugFlyer View Post
Any numbers with the 2W-25/CS-10 on 5S yet? Seems it would be a doable since its 2720KV and is pulling 50-55 Amps on 4S. It's also rated at 70Amps and up to 6S.
Goody, good to see you're working on the J11B, mine should be here Monday!
Speaking of the CS Housing mounting holes, I use 3mm washers with all four mounting screws and it centers the motor and has worked fine in my housing's.
-Rick
Cool.
I've ordered another fan but I may have another look at the suspect one to see if its salvageable.
Goody63 is offline Find More Posts by Goody63
Old May 20, 2012, 02:39 PM
ApexAero is online now
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
I was surfing and found this one coming soon. Looks like a good canadate for a lightweight 4s power system for the 70-10
http://www.hobby-lobby.com/brushless...33014_prd1.htm
ApexAero is online now Find More Posts by ApexAero
Old May 20, 2012, 03:37 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
I'm sorry guys, I keep forgetting that you guys may have a different goal than me. You guys are definitely looking to find the edge of the technologies your using.
Hi Thomas,
Yup things are definitely different than when you came down here to Houston. Is a trip down still in the plans?
Eric B.
AirX is offline Find More Posts by AirX
Old May 20, 2012, 05:29 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Apex, that motor doesn't look overly special or useful. Specs a bit low, and a bit small (can length) to be physically capable. So it is not going to be any different to the L2855 series - very close to that sort of thing. And they are only $12.40.....
So it will work ok... to unknown (untested) results for now... but at a higher price for no benefit.
The Cyclone motors are heftier, so for a step above the L2855 sort of ability motors, they would be the next in line (that sort of motor). A longer can... more true capability. And they are probably really in the HET territory of result/ability... for the lower price than HET. ($40's)
In a way they are good as being 'extended' it means more aftwards weight, so you can use the higher cell/weight battery with little effort to get the CofG right again.
The next in line (and possibly not a great deal better, if any, than Cyclones) are the HET's (ARCs too?).
PeterVRC is offline Find More Posts by PeterVRC
Old May 20, 2012, 06:02 PM
efflux RC is offline
Find More Posts by efflux RC
efflux RC's Avatar
United States, CA, Santa Clarita
Joined Aug 2009
Here's another one to consider for 4s (and 5s for high power) in the CS fan.
(it is a 6s max motor for all other 70mm EDFs.
You'll need a 4mm shaft adaptor.
These motors are 60mm long and have excellent cooling. You can also add a finned heat sink for additional cooling.
http://www.effluxrc.com/Velocity-Hig...28-60-2900.htm
We have some CS fans coming for testing.
efflux RC is offline Find More Posts by efflux RC
Site Sponsor
Old May 20, 2012, 06:22 PM
clive45 is offline
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
  • Internal Resistance: 10.5 Meg ohms
This is taken from the web site of this motor. I think mili ohms would be better than Meg ohms............................
clive45 is offline Find More Posts by clive45
Old May 20, 2012, 06:28 PM
efflux RC's Avatar
Joined Aug 2009
Thanks. corrected.
0.011 ohms
Site Sponsor
Old May 20, 2012, 06:39 PM
clive45 is offline
clive45's Avatar
Joined Mar 2006
There is not much difference between the price for a HET/ARC and that motor also. But very nice to see one with such good cooling.
You could always send one to me for testing
Old May 21, 2012, 03:10 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Gotta remember the velocity motor is burst rated, not continuous, the ARC2858-1 was tougher and the new HET 1W40 is tougher again!
The first carton of 70mm housings just came in today, I will start going through all the backorders tonight and get the loose parts orders out tomorrow, CS10 fan combos will be done in the order they were received and will take a week or so to clear them all.
Extreme_RC is offline Find More Posts by Extreme_RC
Old May 21, 2012, 05:43 AM
viperviper is online now
Find More Posts by viperviper
Antarctica
Joined Apr 2012
Originally Posted by erh7771 View Post
Blades look like they're slightly above shroud rim, smoother air with the rotor as deep in shroud as possible... more thrust possibly
it's the max i can go...
viperviper is online now Find More Posts by viperviper
Old May 21, 2012, 05:56 AM
Antarctica
Joined Apr 2012
-Rick
As i do not hv any 5S lipo in my inventory so i tested it on 6S lipo. HET 2W25 motor.
##### tested with 6S, 60A at 1120W ard 1.8-2kg of thrust!! ##### it's indeed an economical setup with comparable results to those expensive alloy setup! Save tonnes of money in long run esp on the fan unit itself $85-$90 vs $16.
Old May 21, 2012, 06:32 AM
genghiskt is offline
Find More Posts by genghiskt
genghiskt's Avatar
Joined Sep 2011
On which motor? HET 2W-25 ? Running on 6S ?
Kev.
genghiskt is offline Find More Posts by genghiskt
Old May 21, 2012, 06:46 AM
Antarctica
Joined Apr 2012
Kev.
yes, 2w25 running on 6S.
Old May 21, 2012, 08:00 AM
Joined Nov 2005
Check Hobby partz search for 2600 or 2700kv , it's on there with a longer can for 16usd
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7224 Apr 21, 2016 02:53 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
