My current 70mm housings are a new design, the centre section of the outer shroud where the thread is has been reduced to a small ridge rather than a large flange, motor mount holes have been resized & optimised for most inrunners, and the stator finish is much finer. They are designed to fit into pre-molded foam models and all composite models that have ducting made for the common wemo/het housings. Housings are due in tomorrow, and this CNC run I made sure there was no production over run of my designs left laying around that could end up in other peoples hands... |
So far what is the minimum exhaust diameter that still gives good performance? Is 57mm already too small? I have a laser cut balsa and ply kit that as supplied gives enough room for 57mm. With some careful sanding I could get 59mm but 60mm is going to start getting into some of lightening holes in the formers.
http://www.effluxrc.com/efflux-Pro-7...g-EFP70HSG.htm There are a number of the 70 and 90mm housings flying our jets with Skyworld rotors in them on our YouTube channel. http://www.youtube.com/user/effluxRC...lts_right_main |
We also stock the E-flte BL32 (2150kv, 5mm shaft) motor and a few other E-Flite products. If you don't see what you need, please PM or email us.
![]() We are located in CA. Gary - effluxrc@gmail.com |
By the way for anyone that wants I wrote a spreadsheet long ago that calculates FSA based on two data inputs. You just put in the shroud diameter and the fan hub diameter and it gives you FSA in 5% increments from 100 down to 70. The spreadsheet gives you the exhaust diameter in a single or double/bifurcated. It's the second spreadsheet. http://www.rcgroups.com/forums/member.php?u=114136 |
| Thread Tools | |
| New Product Change Sun 12 blade 90mm | Flip Flop | Electric Ducted Fan Jet Talk | 6419 | Today 09:01 PM |
| New Product Change Sun 120mm and new 10 blade 70mm fans | Flip Flop | Electric Ducted Fan Jet Talk | 131 | Apr 27, 2012 07:07 PM |
| Sold Change Sun electric retracts | Flip Flop | Aircraft - Electric - Jets (FS/W) | 3 | May 23, 2011 06:20 AM |
| Sold Change Sun Electronic retracts w/Lander struts | hole digger | Aircraft - Electric - Jets (FS/W) | 2 | May 06, 2011 01:27 PM |
| Sold Change Sun Electric retracts NIB 75.00 | jzuniga | Aircraft - Electric - Jets (FS/W) | 2 | Sep 03, 2010 09:36 AM |
