Old May 14, 2012, 05:26 AM
clive45 is offline
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia
Joined Mar 2006
Well if I was only 3Km away I would go and pick it up, think yourself lucky I have to drive 50Km round trip to pick up a parcel from the PO no matter what it costs to be sent. What they do deliver is only 3 times a week.
clive45 is offline Find More Posts by clive45
Old May 14, 2012, 05:32 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Japan Post is heavily subsidised by the government, thats why its so cheap.
China EMS is strange, start of the year they are really tight with pricing and lots of issue with damaged shipments, once the reach their quota for the year they become more lax. EMS starts at 210RMB for the first 500g then 55RMB for each 500g additional weight, then usually less 30-40% depending on how big the senders account is. So average cost from China is RMB126 or AUD$20.00 for up to 500 grams then $5.25 per 500g on top.
Extreme_RC is offline Find More Posts by Extreme_RC
Old May 14, 2012, 08:24 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Originally Posted by Extreme_RC View Post
Lots of stuff in today, including the new CS10 spinners!
Fit is really nice, I pulled a random rotor from the box and grabbed a couple of spinners and they are a perfect interference fit. I think I will have to call them "Extreme Precision" Spinners
Also adapter blanks have come in, 4mm back in stock and more 3.17 and 5mm available.
Have you tested any heat transfer properties out of the spinner, seems like a great way to keep heat off the magnets of an inrrunner.
Also, do you have an ETC for your shroud...
Thx in advance for any input
erh7771 is online now Find More Posts by erh7771
Old May 14, 2012, 11:28 AM
genghiskt is offline
Find More Posts by genghiskt
genghiskt's Avatar
Joined Sep 2011
Problem with shipping in Australia is the size, spinners wont fit through 20mm letterbox openings, not unless I squash them flat first
The other problem is if I activate the regular mail option, people will use it to order expensive items, and when the package is "lost" by Aust Post I am the one who gets the bad rep because I wont cover their non insured non registered article.
Cheapest option for spinners is $9.10 for regular mail in a bubble envelope up to 500g, that only just covers the packaging and label costs on top of the postage. Adapters go via letter rates everywhere.
Mark,
Can look into the shipping cost, I find it cost too much for me even I m in Singapore.
The air parcel cost from your site, I can ship a kilo of lipo from China by UPS.
genghiskt is offline Find More Posts by genghiskt
Old May 14, 2012, 02:49 PM
mopetista is offline
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
Originally Posted by anlucas View Post
The ducting is quite good on this airframe.
I also tried with a slightly larger than 80%fsa on the thrust tube to see any differences in speed. Thrust was the same between 55mm and 62mm. Obviously 55mm gives a higher eflux speed....
Somewhat surprised that there would be no thrust difference. Just read in a German forum that a MPX Twister now has about the same thrust as w/ same power in Minifan after opening up the exhaust to 60mm (before, at around 53mm stock, it was down by an estimated 20% on the CS70). There are many such reports now, but things seem a bit more complicated and might depend on the inlet part?
Hope you find some more white noise, the Sapac T-45 is a beautiful model, it might as well sound good, too
cheers
Clemens
mopetista is offline Find More Posts by mopetista
Old May 14, 2012, 03:01 PM
Thomas Nelson is offline
Find More Posts by Thomas Nelson
Thomas Nelson's Avatar
Calgary, Alberta, Canada
Joined Sep 2002
Interesting.
I can confirm at least part of this from my own experience.
I have a Minifan installed in my superlight Twister drawing 450 watts on 3S. Better than 1:1 T/W. Nowhere near the same T/W when I swapped out the CS10 also running 450 watts on 3S (3000kv $9.00 motor from HK). However I did not open up the nozzle.
I'm going to try that now! That was the whole reason for getting the 3S setup in the first place - putting it in my Twister.
tn
Oh, I should add that the CS10 on the bench pulled fine (no numbers mind you, just me feeling the pull on the test stand). It was clearly under performing once installed in the Twister.
Thomas Nelson is offline Find More Posts by Thomas Nelson
Last edited by Thomas Nelson; May 14, 2012 at 03:12 PM. Reason: Clarified subjective 'bench vs installed' thrust observation.
Old May 14, 2012, 03:22 PM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Thanks for the feedback guys.
I should say that the thrust was measured statically. ie hang the model from the ceiling off the fish scale - nose pointing down.
I don't thing that we can compare other airframes.
It just so happens that this particular motor when run on 5S on the CS10 "seems" to produce the same static thrust with both 55 and 60mm appetures. I can tell you though that, although I have no way of measuring inflight speed, with the 55mm exit it was noticeably faster.
Next try will be with a 56-57mm exit.
anlucas is offline Find More Posts by anlucas
Old May 14, 2012, 03:58 PM
Vienna, Austria
Joined Apr 2007
Originally Posted by Thomas Nelson View Post
I have a Minifan installed in my superlight Twister drawing 450 watts on 3S. Better than 1:1 T/W. Nowhere near the same T/W when I swapped out the CS10 also running 450 watts on 3S (3000kv $9.00 motor from HK). However I did not open up the nozzle...
To be fair, the $9.00 motor in the CS70 will be > 10% below the very good efficiency of the (not so cheap) Mega you are running in your Minifan (I would estimate 80% vs. 70% at WOT), so you should also expect to get less power out with the same power in.
But it should be of the order of some 10%, not 30%...
Since Anlucas' T-45 was performing well w/ 55mm exit that might mean that the smoother thrust tube allows for slightly smaller diameter than would be efficient in a foam exhaust?
We will understand this fan eventually :-)
Old May 14, 2012, 04:50 PM
Joined Nov 2005
Interesting.
tn
HK motor has Smaller magnetic field, better for 5s on T-50 fan...4lbs of thrust on 5s\70 amps and the motor is being stressed...very light weight and inexpensive
Old May 14, 2012, 05:00 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
cheers
Clemens
I would like to put my two cents on this. It's no phenomena, the rotor is accelerating the flow a lot more than the average fan, the drawback is the rotor can't hold as much pressure, due in part to the blade design. The higher aspect ratio needed to allow more blades causes some efficiency loss.
The fix is to ease some of the pressure on the rotor by opening the exit area of the exhaust as has been shown.
Cheers,
Eric B.
AirX is offline Find More Posts by AirX
Old May 14, 2012, 05:55 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Originally Posted by genghiskt View Post
Mark, Can look into the shipping cost, I find it cost too much for me even I m in Singapore. The air parcel cost from your site, I can ship a kilo of lipo from China by UPS.
Unfortunately shipping is fixed by OZ Post, nothing I can do about it, I added 5 spinners to the cart and it shows $12.25 to Singapore for airmail, thats as cheap as you will get it from here to anywhere.
Old May 14, 2012, 08:13 PM
Joined Sep 2002
Yep, totally understood Clemens! But this elcheapo motor/fan combo works well enough outside the plane that I think it's worth re-visiting with the Twister. My swap was several months ago now. I forgot all about the Twister until you brought it up again the other day. Now with this piece of feedback I need to schedule some day-surgery! I'll use some transparent film to make a cone. 60mm seems pretty big but I'll give it a try.
To be fair, the $9.00 motor in the CS70 will be > 10% below the very good efficiency of the (not so cheap) Mega you are running in your Minifan .....
Old May 14, 2012, 08:24 PM
Joined Sep 2002
Gotcha, & thanks for the suggestion! I was looking for a cheap, light, better sounding 3S combo to try with the Twister. While the bird could certainly handle the weight of a 5S pack up front and counterbalancing weight in the back, my goal from day one was to have an exceptionally light jet for higher risk flying like this.
I'll give the motor/fan a try and report back. Certainly the harder part will be opening up the nozzle without making a mess of things. I think I used epoxy to join the fuse halves, so it won't be easy sanding relative to the surrounding foam.
tn
Old May 14, 2012, 09:43 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
You should be able to use a piece of dowel (1" diameter or so) with sandpaper wrapped around it, to make it quite easy to work down inside the ducting.
Or even larger PVC pipe (2".. or whatever fits well), for more 'smooth accuracy of the rounding.
PeterVRC is offline Find More Posts by PeterVRC
Old May 14, 2012, 09:52 PM
Glacier Girl is offline
Find More Posts by Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
Hmm, any chance the intake on the Twister is starving the CS fan, which in turn gives you similar thrust with different exhaust sizes?
It's all it can put out, as it can't pull in enough air?
Glacier Girl is offline Find More Posts by Glacier Girl
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7289 Sep 27, 2016 01:24 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
