Los Banos Ca.
Joined Apr 2000
Peter, That is what I was expecting on 2300 motor but my numbers are much lower,480wts,28amps measured on my wattmeter. don't know if should get a 5s pac or get the 2800 motor. Don't want to get the 5s pac if this motor is defective. put my 2w20 het fan back in the F-86 for now. Another ? do you run brake on or off?
Joined Nov 2005
I'd say good, the one I had I put over 20 flights on it around 2000 watts..I put more than 2000 watts on it and it didn't last past 3 minutes so if you're going to fly at 2000 watts make sure to use throttle management
Australia, VIC, Melbourne
Joined Nov 2006
Depending on the aircraft, you may or may not need, or get benefit, from a lip.
If the fan entry side has a full surround and is flush to the housing, then there is no need. If there is ANY irregular shaping at the housing entry surround, then it will most likely benefit - but of course the actual shape and construction around there, space etc can dictate what you can, or can not, do. And in bench testing it is that HUGE thrust loss if you don't use a lip. |
Bench testing without an inlet lip will show ~30% drop in potential performance. If your getting 400-500watts without the lip then you will get ~550-650watts with it. The lip adds inlet area that will equate to loading the fan when flying. The lip also helps in acceleration because it allows more inlet area to the airflow stream. If the airframe your putting this into has ducting you will not need the lip when installed in the airframe the ducting will take care of directing the airflow to the fan, one caveat is there needs to be at least 1/8 inch thickness to the inlet duct of the aircraft or the system will not perform up to its potential, if the airframe does not come with a proper set of inlet ducting then the lip can be used in the airframe to help gather airflow to the fan. One more item to add with the airframe that has not inlet ducting the fan needs a little bit of duct leading into the fan which can be made from 1/64" thk plywood and the lip can be attached to that, the reason is that when installed into a bare airframe drawing air to the fan without a proper duct the airflow eddies arround inside the fuselage and creates a lot of turbulence, the short velocity stack helps to settle the turbulence into a straight flow pattern before reaching the fan. It helps tremendously. Now if it is a foamy like the Vampire the ducitng is already supplied and thus no extra ducting is needed except maybe outlet ducting if its not the correct size.
Cheers, Eric B. |
Latest blog entry: T/A 37 Tweet/Dragonfly
Joined Apr 2012
Need to seek some advices on my setup.. running on 2w18 with CS10 blade 70mm with intake lip.. current drawn is ard 90A (max 105A), Wattage is 1150 W (max 1400w when sudden throttle up) when full throttle.
Is my setup efficient? in my F-22 70mm plane. Running on 4S 2200mah... max i think is 2-3mins of flight time....the CS 10 blade Fan unit is all stock setup, no change in adapter. |
Joined Nov 2005
1105watts / 90 amps = 12 volts so the run time voltage is already dipping below 3.5 a cell... Can you use a 3000mah or 3300 mah 4s? Regards |
| Thread Tools | |
| New Product Change Sun 12 blade 90mm | Flip Flop | Electric Ducted Fan Jet Talk | 6424 | Yesterday 08:48 PM |
| New Product Change Sun 120mm and new 10 blade 70mm fans | Flip Flop | Electric Ducted Fan Jet Talk | 131 | Apr 27, 2012 07:07 PM |
| Sold Change Sun electric retracts | Flip Flop | Aircraft - Electric - Jets (FS/W) | 3 | May 23, 2011 06:20 AM |
| Sold Change Sun Electronic retracts w/Lander struts | hole digger | Aircraft - Electric - Jets (FS/W) | 2 | May 06, 2011 01:27 PM |
| Sold Change Sun Electric retracts NIB 75.00 | jzuniga | Aircraft - Electric - Jets (FS/W) | 2 | Sep 03, 2010 09:36 AM |
