Greece, Attica, Athens
Joined May 2011
If the 3300kv is pulling less than 75amps now, you could try the 3700kv CP. |
Australia, VIC, Melbourne
Joined Nov 2006
I don't really know, but....
I would think higher altitude needs more RPM, because it needs to 'pump' more air volume to get the same thrust as lower altitude. BUT, the resistance of thinner air is less.... and likely to all end up proportional in terms of power needed for that same end result. So whilst you NEED more RPM.... which means you need a bit more KV for a same fan system.... the load total is the same, and thus current draw will be the same. eg If someone has a 1600kv at low altitude, you might need 1800kv. But the Watts (power) needed will be the same, for the same aircraft performance (if you get the KV matched to have that same flight performance as the lower altitude had). But then there is lift..... probably a bit lower..... so you will need a bit more AoA to fly the same - probably a weeny amount, like 0.1deg or whatever. Which will rob a bit of power. And all in all I would not expect too huge a power use increase. But you would need to get that required KV increase worked out. |
Joined Mar 2012
[QUOTE=anlucas;21365608]How high up are you?
5000ft If the 3300kv is pulling less than 75amps now, you could try the 3700kv CP. QUOTE] I dont know how many amps Im pulling as I dont YET own a testing tool to check what is going on with the motor. Im suspecting that I will have to invest in larger Mah batteries if I decide to go to a larger KV motor. |
Joined Mar 2012
Joined May 2011
Silverstate,
the CS 10 blade is a heavier load than the other 4-5-6 blade rotors out there. At the same rpm, it generates more thrust than others. This is why we use lower kv motors. In general, it needs slightly more amps to generate similar thrust levels to other fans. If you spin any rotor in a total vacum then the motor will pull no more amps than the motor would pull without a rotor on it. As the air becomes denser, the force needed to keep the rotor turning at a specific rpm rises. In your case at 5000feet you will find that a motor with higher kv will need the same amps as a motor with less kv running at a lower altitude. It is important to measure the amps you are pulling now because that will tell you how much more kv you need. You could also get away with using the same motor but with a 5S battery. |
Joined Mar 2012
Joined Mar 2012
Oh, you are mistaken my friend. I live in the state of Nevada. We are considered high mountain DESERT. It gets plenty hot here during the summer. We have quite the spread in temperature here, during the summer. Anywhere from 20C up to 40C. But on average we will see 29C to 33C. But because I live in the desert the humidity is relatively low by comparison to where you live in Greece. Typically we will average 20-25% humidity, and sometimes as low as 10-15%. Which also makes our air less dense because of the lack of humidity. |
Joined Mar 2012
Edit: Ken you sir are correct. I just looked it up and found some interesting information. Interesting information: Pilots use charts or calculators to find out how temperature and air pressure at a particular time and place will affect the air's density and therefore aircraft performance. In general, these calculations don't take humidity into account since its affects are so much less than the others. When the air's density is low, airplanes need longer runways to take off and land and they don't climb as quickly as when the air's density is high. So knowing this information. Come summer time Im really gonna be screwed with my EDF's. Even though I live at 5000ft=thinner air, and in the dry desert=less humidity=more dense air. But the one thing that Im not sure if I can over come is what is refered to as density altitude. Based on the heat of the day that I see in Nevada during the summer, and the elevation the air becomes even more less dense. So lets say on a 90 degree temperature day at 5000 ft elevation. It would be like trying to fly at like 7000 or 8000 ft. So I really need to figure out good hot motor/ESC set up with my CS10, to compensate for the environmental condition. Or only fly in the morning while the air is still cool and calm. Either way I want to figure out a good set up. |
Now I have some new numbers, measured the CS70 fan in Hobbyking 70mm composite L39.
This setup: - CS70 mm 10 blade -blades - Red Brick 125A ESC - 6S 5000 mAh 30C, just charged, good battery - Turnigy 2860-2200 kV. - Heatsinks from ExtremeRC (two installed on the motor) - RC-lander metal fan housing - Hobbyking Composite L39 70 mm (Pro-Design L39) - No thrust tube yet since I have not figured out how to fit one in the congested space available in the rear of this plane which also contains elevator pushrod mechanics (and would poke inside the thrust tube even if there was a thrust tube). - Straight intake in the fan (that seamlessly connects with the ducting of the plane) - No cheater hole Everything else is now ok except for thrust. Thrust is poor and thrust per watts is poor. The numbers: - 1380 W peak, 58A peak, motor stays cool/slightly warm (if power is stopped immediately) - 1200 W sustained power, was reading something like 56 amps sustained, motor stays cool - ESC gets slightly warm - Electrically everything looks to be sane and okay and I am very pleased that the motor does not cook with this setup But then: - Measured with fish scale by hanging the model in the air. Having the power on or off only seems to have 450 grams difference. In other words, the fan produces 0.45 kg static thrust at 1200 W sustained power. That is kinda the worst propulsive efficiency I have ever come by. By looking at it, there clearly is larger gap between the fan and housing than with the original RC lander blades. This will reduce efficiency, but I hope not this much. I did not get reliable thrust numbers on stand without the plane, but I think I was getting more thrust than this. So the question is that is the intake or exhaust the problem. I will retest later with different fan on the same duct, to verify that it is not a problem with the fan. The plane is supposed to fly with 3000 mAh 6S, I weighted it without landing gear to be about 1.8 kg. To have even somewhat jet-like performance, I would need more than 1kg sustained thrust. Should I make a cheater hole, add thrust tube (somehow)? Any suggestions? |
Joined May 2011
It is quite easy. Just make the tube. Bend it in a U shape along the length and push it in through the rear - then tape it to the fan. |
| Thread Tools | |
| New Product Change Sun 12 blade 90mm | Flip Flop | Electric Ducted Fan Jet Talk | 6431 | Yesterday 12:52 AM |
| New Product Change Sun 120mm and new 10 blade 70mm fans | Flip Flop | Electric Ducted Fan Jet Talk | 131 | Apr 27, 2012 07:07 PM |
| Sold Change Sun electric retracts | Flip Flop | Aircraft - Electric - Jets (FS/W) | 3 | May 23, 2011 06:20 AM |
| Sold Change Sun Electronic retracts w/Lander struts | hole digger | Aircraft - Electric - Jets (FS/W) | 2 | May 06, 2011 01:27 PM |
| Sold Change Sun Electric retracts NIB 75.00 | jzuniga | Aircraft - Electric - Jets (FS/W) | 2 | Sep 03, 2010 09:36 AM |
