Old Apr 12, 2012, 01:46 PM
jk671 is offline
Find More Posts by jk671
John
jk671's Avatar
United States, NV, Las Vegas
Joined Mar 2011
ok guys what would be the best motor for this fan on 6S!!! I tried to run my new CyclonePower 2800kv on 6S and while I achieved 11lbs of thrust.... I damaged the magnets on the bell of the motor!
jk671 is offline Find More Posts by jk671
Old Apr 12, 2012, 01:52 PM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
6S!! No wonder....
Even the 2500kv CP would be stressed on 6S....
I think a motor 2100-2200kv on 6S is about right. The eflite v32 and a HET come to mind.
anlucas is offline Find More Posts by anlucas
Old Apr 12, 2012, 02:08 PM
jk671 is offline
John
jk671's Avatar
Joined Mar 2011
Originally Posted by anlucas View Post
6S!! No wonder....
Yeah I forgot I was going to run this motor on 5S not 6S.... and while I was amazed at how much thrust I achieved.... i feel really stupid for forgetting
Old Apr 12, 2012, 02:30 PM
dpowellmeii is online now
Find More Posts by dpowellmeii
Madison, MS
Joined Oct 2006
Wow! Too bad you don't have a video of that. I bet it was humming!
dpowellmeii is online now Find More Posts by dpowellmeii
Old Apr 12, 2012, 04:29 PM
jk671 is offline
John
jk671's Avatar
Joined Mar 2011
it was pretty cool.... until i ran down the motor.... then the magnets started breaking apart
Old Apr 12, 2012, 04:41 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
You sure you didn't burn the windings first?
It's hard to demag an outrunner.
Regards
erh7771 is online now Find More Posts by erh7771
Old Apr 12, 2012, 04:42 PM
Joined Nov 2005
Did they crack or demag?
Demag the magnets stay together but lose all magnetic properties but if they crack you can see them split
Also, with the magnetic field sizes that are present today people have been doing 11lbs of thrust at around 3 - 4000watts with 90mm fans, it would take and fairly larger amount of watts do that the same at 70mm.
How long did you run the test?
Regards
Old Apr 12, 2012, 04:52 PM
jk671 is offline
John
jk671's Avatar
Joined Mar 2011
Regards
they cracked!
Old Apr 12, 2012, 05:05 PM
jk671 is offline
John
jk671's Avatar
Joined Mar 2011
Regards
11 lbs is what the scale said!
Old Apr 12, 2012, 05:11 PM
Glacier Girl is offline
Find More Posts by Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
Originally Posted by SteveC68 View Post
You must be buying your fans from the wrong place. HET 6904 is $35. I bought two on sale for $25 each. That's a pretty long stretch to get to a couple of hundred. No offense to the CS fan, but the HET and Wemo will kick the crap out of it in all out speed and efficiency.
No Steve, Het motor, Wemo fan, If you can get them for even $35.00 together you got one heck of a deal. And I'm running pairs of them. Ok so we'll say $100.00 for one set up.
Anywho, if anyone has been looking Horizon is releasing a new foam Habu.
Has flaps, and can be equipped with Eflite retracts.
http://www.horizonhobby.com/webapp/w...pe=productgrid
Glacier Girl is offline Find More Posts by Glacier Girl
Old Apr 12, 2012, 05:50 PM
ZACATTACK is offline
Find More Posts by ZACATTACK
ZACATTACK's Avatar
Canada, ON, Hamilton
Joined May 2011
6S!! No wonder....
I run a TJ70/ DS30 Rotor/ Ice100 Lite/ Arc 28/58/1 on 5s and 6s...no problems at all ...and the 28/58/1 is a 3180Kv motor...It's all got to do with the Fan..The TJ line of Fans are just amazing...Lots of 70mm Fans don't have a built in Heat sink..Big Difference...Take one of Tam's set-ups for the foam Habu...It has the E-Flite 3600Kv motor and he runs it on 5S steady..If you put that motor in a different Shroud with no heat-sink...break out the marshmallows & wieners..BBQ
ZACATTACK is offline Find More Posts by ZACATTACK
Old Apr 12, 2012, 09:31 PM
clive45 is online now
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
L2855-2300Kv are in at HK.. Go get them
clive45 is online now Find More Posts by clive45
Old Apr 13, 2012, 12:07 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Plenty of guys run my Extreme CNC alloy housing with the ARC2858-1 and wemo rotor at 1900 watts / 6s producing 2.5kg+ thrust and hammer the things all day long, the housings are about the most efficient around when it comes to heat extraction, and very affordable.
I am now running the new HET 1W40 in the same fan, 6s is pulling 2060W and producing around 5K rpm more than the ARC motor does!! Close to 3kg thrust, will be testing it this weekend now I have some time to swap motors around in my test fan. I think this new motor would be hot on 5s with the CS10 rotor in an alloy housing. Not sure I would trust it in a plastic housing at this power level.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Apr 13, 2012, 06:53 AM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
I got the F-15 ducting work and tests done.....
Rounding off the inlets made ZERO difference. Exact same thrust before and after.
Unfortunately if you do this first then you can't test a difference AFTER opening the exit ducts.....
I note the Freewing Su-35 has blunt, sharp inlet duct openings (same as the F-15). So it seems Freewing (who seem to test things at least somewhat well) don't think the inlet duct edges matter at all.
My, not totally conclusive, tests suggest that too.....
Opening the exhaust ducts gave increases.
I did it in gradual stages, to see if I could discern any benefits.... and there were gains at every stage of opening them larger!
It went from the sub 0.6Kg, up to 0.98 Kg by the time I got them as open as they can be..... this is from a 1.35Kg (stabilised) CS10 setup. So that is a big improvement, but still well short of acceptable really!!
Pic1) The inlets are rounded... hard to discern that in the pics, but they are. I sanded them with glass paper.
Pic2) The exhausts in this pic are almost totally opened out. The next step made only a fractional difference as there was really nothing left to gain. They look as if there is a bit left, but the 'fluffy edge' of the sanded foam is just making that look like that.
The only way to get MORE exhaust area is to cut off the nozzles!!
I am humming and harring over that, but pretty certainly will do that.... then test with them off, which should give another 2mm of diameter or so. Based on the gains so far, I think they need close to 2mm more diameter each.
A larger opening can be re-tuned to be smaller, so that is ok too. But I will investigate making up thrust vectoring nozzles (larger diam) (make the "ball" assembly using a ping pong ball? lol) to put back to finish it off - or otherwise just plain larger nozzles.
The aim is to persevere until at least 1.2 Kg of the 1.35Kg 'base' thrust is found! Cutting of fthe nozzles might jump it right into that area anyway!
Then worry about tuning it for best real flight operation later on. eg might need some reduction then.
PeterVRC is online now Find More Posts by PeterVRC
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7232 Jun 06, 2016 02:40 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
