Old Apr 09, 2012, 03:46 AM
clive45 is online now
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
Unless you are using twin EDF's bifuricated outlet ducting is a power waster, even turbine guys make a single outlet between the twin outlets to not loose power..
clive45 is online now Find More Posts by clive45
Old Apr 09, 2012, 04:36 AM
MagnusEl is offline
Find More Posts by MagnusEl
MagnusEl's Avatar
Sweden, Gävleborg County
Joined Jan 2004
Peter, please take some measurings of inlet and outlets. Since it is a 64mm plane and you get lower current draw I am almost sure the fan is starving, not geting enugh air.
Bifurcated outlet for this fan should be around 40mm each to be @ 80-85% FSA.
MagnusEl is offline Find More Posts by MagnusEl
Old Apr 09, 2012, 07:06 AM
Glacier Girl is offline
Find More Posts by Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
Peter thanks for the info on the fan lips and ducting.
And yep I have to agree with everyone else, it's starving for air.
Glacier Girl is offline Find More Posts by Glacier Girl
Old Apr 09, 2012, 07:31 AM
clive45's Avatar
Joined Mar 2006
Or is it constipated...............It won't go in the front unless it can get out the back.
Old Apr 09, 2012, 10:32 AM
dpowellmeii is offline
Find More Posts by dpowellmeii
Madison, MS
Joined Oct 2006
Originally Posted by clive45 View Post
or is it constipated...............it won't go in the front unless it can get out the back.
lmao!!!
dpowellmeii is offline Find More Posts by dpowellmeii
Old Apr 09, 2012, 10:48 AM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Err, seemed conflicting decision on the cause(?).
Exhaust side?
I had sat and thought about the idea of conjoining the rear ducts, via opening a central channel 'bridge'. I think the "makeshift cheater hole" (via fan cover off) showed it is not the inlet side - though that might show up to be another issue later if the rear end is opened to more throughput!
But apart from looking and thinking about the read end stuff, I then put it back in the workshop corner in disgust !! LOL. The rear end 'opening' project doesn't look like it will be easy, or best looking. But maybe if I try hard, I can get it to look good... and HOPEFULLY it will actually help!
It will be a good learning curve too!
I have a Dynam Meteor with a 5S CS10 that is losing just over 100g of thrust compared to the bench testing. So that is another one I want to "find" the cause of loss. And will be another good learning source!
With the common used "80% FSA" for exhaust nozzle size..... wouldn't that really alter according to fan volume/thrust? If outputs are within a commonly seen range, then it might be a fair enough general rule. But when we have high speed fans, lower speed 'torque' fans, and even quite dramatically different power systems to drive fan types at wide ranges of thrust outputs, wouldn't that alter what size the flow path restrictions can be efficiently?
Plus the front end's flow ability must match off (in some ratio) to the rear end's flow ability too. (??)
PeterVRC is online now Find More Posts by PeterVRC
Old Apr 09, 2012, 11:21 AM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
the intake and exhaust exits are commonly way too big on most foamy jets.
Peter
measure you fan I.D of the housing and O.D. of the motor tube and then measure you exhaust exits for me and I can run the numbers and post them for you
jcdfrd is offline Find More Posts by jcdfrd
Old Apr 09, 2012, 01:56 PM
SteveC68 is offline
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
No it isn't a power waster. It just takes time to design correctly so most people take the short cut of a single outlet.
http://www.rcgroups.com/forums/showthread.php?t=879830
SteveC68 is offline Find More Posts by SteveC68
Old Apr 09, 2012, 04:44 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
+1 Steve
I also dont believe the fan is starving for air, instead the exits are almost certainly way too big. anyway this is my guess and we wont know until measurements are taken
Old Apr 09, 2012, 06:49 PM
foam and tape is offline
Find More Posts by foam and tape
Retardedly intelligent
foam and tape's Avatar
beavercreek,ohio
Joined Jan 2007
Hi all, I'm about to pull the trigger on a pair of these: http://www.hobbypartz.com/96m32-car-2848-2618.html The data looks pretty good on 4S but does anyone have any data on 3S, I want to use these fort the windrider 737 and my target weight for the plane is about 4-5 pounds. Would this motor be a suitable fit?
foam and tape is offline Find More Posts by foam and tape
Old Apr 09, 2012, 06:55 PM
Joined Nov 2006
I will measure it up and post that when I get home tonight!! Thanks.
The airflow/thrust FEELS nice... LOL. (When using the scientific 'hand behind it' method).
Old Apr 10, 2012, 06:57 AM
Joined Nov 2006
F-15 measurements:
Inlet ducts have a "vertical" area of 70mm (height) by 33mm (width) X 2 of course.
The pic distorts the view a bit, they are perfect rectangles - just with sloped side profiles.
Exhausts are 37mm Inner Diameter. And are larger before that final tapered exit.
And X 2 again of course.
It is of course a CS10, with a 28mm inrunner, so I guess the real "inner radius" item is the fan's motor shroud anyway. Which pretty well means that all CS10's would have the same FSA.
The fan housing is a pefect fit into the rearwards ducting, so it is mounted right up against that and goes marginally into that opening - like 0.1mm. It is a good seal just like that.
The forward area is also a pretty good match to the fan housing, and the fan cover closes down the open area and forms a taper to that forward area. But it is not quite perfect and I will be modifying it to be a perfect match and taper.
Old Apr 10, 2012, 07:15 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
39mm = 80% FSA for a bifuricated setup, so its not far off. The small square sharp edged intakes wont help with static figures, I would fly it and see what happens.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Apr 10, 2012, 07:22 AM
Joined Nov 2006
At 0.56Kg static thrust, I would assume that means pathetic acceleration.... that gains more and more thrust as it gains speed. But in time to take-off? Or a very very long roll out !!? LOL (eg building up to speed and thus thrust increase.)
That would not make for a very good hand launcher either! hehe
Old Apr 10, 2012, 07:25 AM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
Joined Nov 1999
Mark, from my numbers on my spreadsheet the outlet area is pretty tight for this fan, the FSA = 2933mm^2 and the outlet area figures to 2148mm which is 73% of FSA.
The fan is definitely being choked and this is where the losses are coming from.
Eric B.
AirX is offline Find More Posts by AirX
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7194 Dec 14, 2015 04:03 PM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 08:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 07:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 02:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 10:36 AM
