Old Mar 06, 2012, 06:19 PM
SKYRYDER1000's Avatar
NEW JERSEY U.S.A.
Joined Mar 2010
Originally Posted by 901racer View Post
Looking at the data I would expect more headroom with the Tacon motor for 4 & 5S operation.
Thanks for the response racer. Thats the one I'm going with. I hope it has enough push on 4s for a 2.5lb F/A-18. If the data sheets are correct I should be around 3.2 lbs of thrust.
SKYRYDER1000 is offline Find More Posts by SKYRYDER1000
Old Mar 06, 2012, 09:16 PM
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
Originally Posted by HARD DRYVE View Post
Hi, has anyone used this fan on a eflite bae hawk or f-86 sabre?
Because a friend of mine gave both of them to me, but without the power system. This fan sounds great but I don't know if it would be enough, and if so, with what kv motor? I have read through this thread looking for some guidance...
If you check back in the thread quite a few are using the fan with the Delta shroud, in the Habu and they are missiles! I would think the Hawk and Sabre would both be great ones for this unit. As for kv it would depend how big of a pack you want to run. Something in the range of 2100/2300 for 4 or 5S, even 6.
If you have a big amp esc and pack you could look at a 2800 to 3000 kv motor.
sherlockshah, Yeah I think you have too high of a kv motor for even 3S on this fan. You aren't going to be happy.
It seems this fan likes a low kv motor on high voltage to really make it shine.
Glacier Girl is online now Find More Posts by Glacier Girl
Old Mar 06, 2012, 09:41 PM
Joined Nov 2005
My CP480-2500kv motor numbers
4s\ 15.2v\ 50a\ 48oz settled
5s\ 17.6v\ 60a\ 58oz settled
6s\ 22.2v\ 85a\ 84oz settled
195f peak outside of can after 20 second run then couldn't get the motor or the motor shaft above 200f. Shaft of outrunner is decent measuring point for heat of windings cause it's were most heat is going to be held after a run.
All other temps weren't worth mentioning..
Edit on 5s...
5s\ 18.3v\ 62a\ 61oz settled
erh7771 is offline Find More Posts by erh7771
Old Mar 06, 2012, 09:47 PM
Joined Feb 2006
Can you please explain
What is wrong with a 3600kv motor on 3s?? Will it pull too many amps? I know this motor can run on 4s with proper cooling fins so i was thinking at 10blade fan with the same 3s cell count the motor should hold up, but please explain your reasoning why I will be unhappy?
sherlockshah is online now Find More Posts by sherlockshah
therealhiphop's Avatar
USA, UT, Springville
Joined Dec 2005
Wow, that's a big jump from 5S at 58oz to 6S at 84oz...
therealhiphop is offline Find More Posts by therealhiphop
Old Mar 06, 2012, 09:54 PM
Joined Dec 2005
Sherlock ~ based on past experience, ultimately it will not matter what test results and common wisdom dictate, you are going to do what you are going to do. No matter how many recommendations we make, there will always be a but...
Take a moment to read through the thread and you will note some patterns. Also, how about this, run your own test rather than having other do the work for you. Experience is the best teacher (especially when you don't listen anyways).
So as I said, please go ahead and use your 3600Kv motor on 3S, run it up to WOT, and make sure you get some video of it.
Good luck.
Old Mar 06, 2012, 10:06 PM
Joined Oct 2011
Nice .. a pair of those in a twin will be 10 1/2lbs....
901racer is offline Find More Posts by 901racer
Old Mar 06, 2012, 10:10 PM
Joined Feb 2006
I have not done it that why im asking questions
Good luck.
I want to keep it light, I know its not going to be a fast plane so im just trying to use what i have so i dont have to spend extra money
Old Mar 06, 2012, 10:25 PM
Joined Nov 2005
I take it you have some high C 3s packs, I think the MB1 which is 3200kv hit 100 amps on 4s so your 3600kv is prolly going to do the same tAng but with lower thrust numbers.
Do you have a 5s 4000mah 40c pack? If so those 2300kv L2855 motors are 12.50 for 1 and 25usd for two and will do 100amp for both on 5s around 7lbs of thrust.
That's some decent get gone.
The calculated RPM for 3lbs of thrust is 37000 rpm so 37000 / (3.5 x 3) = 3600kv with a 60 - 70 amp pull from a 3s
So you can prolly do 2 of em for 6lbs of thrust with this CS10 fan for 120amps on 3s....use heavy gauge pack wires
Old Mar 06, 2012, 10:29 PM
Joined Feb 2006
dude i tried to get those motors they been out of stock
for so long I did get my fans though. I am trying to find someone to build my F-22 for me since I suck at building. No body local seems to want to take the task and on top I guess I was not offering much LOL $100bucks. If i ship it out to someone I guess they can build it for me and just leave the wings off for me to glue here so the box is not that big.
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
Good luck.
+1
very politely said, I was going to post something very similar but it was not sounding so good so I held my tonge
jcdfrd is offline Find More Posts by jcdfrd
Old Mar 06, 2012, 11:55 PM
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
I think:
3600kv * 12.6Volts= 45360/16.8=2700
One 3600 kv motor to 3s is same a 2700kv motor to 4s.
around 950 watts and 86Ampers with 3slipo fore 3600 kv motor.
More easy with 2700 kv motor to 4s= to 65Ampers, 950 watts.
Manuel v.
manuel v is offline Find More Posts by manuel v
Old Mar 07, 2012, 12:02 AM
It should fly at least once
clive45's Avatar
Joined Mar 2006
You want someone to tell you what you need, then someone to build it............
do you know someone who will fly it for you, I bet not.
I'm too old to be polite all the time
clive45 is offline Find More Posts by clive45
Old Mar 07, 2012, 12:34 AM
manuel v's Avatar
Joined Aug 2004
Edit on 5s...
The most efficient motors.
Manuel V.
Old Mar 07, 2012, 04:30 AM
Joined Nov 2005
I'm going to try a couple on a falcon 120 if they ever come back into stock at NP
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 6431 Today 12:52 AM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 07:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 09:36 AM
