Well fan clearance is just a hair over 1/16" on the fans to the WeMo shrouds, and throttle range has been checked (I had thought about that too) even maxed out didn't change it.
I'd be blaming the esc settings, but these motors were slugs to begin with, with the 6904 fans. I'm really beginning to doubt the kv ratings. I did a little digging and I find the motor is listed either as a 2980 kv or a 3020. With the watts and amps I'm getting, compared to the tested ones on the chart, it looks like more like somewhere around 2400 kv. Got me. I just wish HK would get some 2100 or 2300's in. Least I know those will work. |
The air stream exits the blade area rotating in the same direction as the fan wheel. The guide vanes attempt to change the airflow to nearer axial to improve efficiency. Generally fan manufacturers settle on a particular guide vane configuration irrespective what fan "species" they supply. Its probably not too important from an airflow viewpoint...what is important there be a different number of guide vanes to the number of fan blades otherwise sound resonance will be set up at blade passing frequency. Tip clearance needs to be smaller as developed pressure increases. A low pressure fan like an "Expelair" wall type has a huge clearance to maximize efficiency. A high pressure fan has a small clearance to minimize "leakage" downstream to upstream. In the case of our EDF's it would be best to have as small a gap as reasonably possible without risking blades touching. Bob |
I agree with you re the tip clearance and the number of static vanes but I was under the impression that the number and angle of them was critical to efficiency as well. Anyway its all fluid mechanics which is way above my head but I would think that certain fans will work well or better in some shrouds than others and some worse. Just got to find the best combination.
Tamjets talks about this subject on one of his vids........... |
Puerto Rico, Mayagüez
Joined Jan 2011
Hi, has anyone used this fan on a eflite bae hawk or f-86 sabre?
Because a friend of mine gave both of them to me, but without the power system. This fan sounds great but I don't know if it would be enough, and if so, with what kv motor? I have read through this thread looking for some guidance...
Joined Feb 2006
hi guys I have a question. I have a himax ha2825-3600kv
Motor, how do you guys feel this on the cs10 blade fan?? I know this motor runs the multiplex twister pretty good but not that fast on 3s, I tried 4s once long time ago and it fried the motor, but im thinking on 3s cs10blade fan it should be pretty good?? Please let me know before I even try to mess with it.
Try it, measure the numbers, post the results. Contribute!
| Thread Tools | |
| New Product Change Sun 12 blade 90mm | Flip Flop | Electric Ducted Fan Jet Talk | 6509 | Jun 18, 2013 07:39 PM |
| New Product Change Sun 120mm and new 10 blade 70mm fans | Flip Flop | Electric Ducted Fan Jet Talk | 131 | Apr 27, 2012 07:07 PM |
| Sold Change Sun electric retracts | Flip Flop | Aircraft - Electric - Jets (FS/W) | 3 | May 23, 2011 06:20 AM |
| Sold Change Sun Electronic retracts w/Lander struts | hole digger | Aircraft - Electric - Jets (FS/W) | 2 | May 06, 2011 01:27 PM |
| Sold Change Sun Electric retracts NIB 75.00 | jzuniga | Aircraft - Electric - Jets (FS/W) | 2 | Sep 03, 2010 09:36 AM |
