Old Mar 05, 2012, 10:37 AM
SteveC68 is offline
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
anlucas,
When you tested the Turnigy L2855 did you remove the bell/cone that is threaded onto the back of the motor can? If so is it glued and threaded or just threaded? Also is it left hand or right hand threads?
Steve
SteveC68 is offline Find More Posts by SteveC68
Old Mar 05, 2012, 10:47 AM
anlucas is online now
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Originally Posted by SteveC68 View Post
anlucas,
Steve
Steve,
No I did not remove the bell/cone. It is threaded and to unscrew you have to turn clockwise. ie opposite than normal screws.
anlucas is online now Find More Posts by anlucas
Old Mar 05, 2012, 12:12 PM
901racer is offline
Find More Posts by 901racer
Joined Oct 2011
Originally Posted by therealhiphop View Post
I was thinking 2800KV because it's a good "in-between" range for both 5S and 6S configurations.
2500KV would be cooler on 6S but might not perform as well on 5S.
I am going to order a motor today and funds are limited so no option to get both .
Any other votes one way or the other (2500 vs 2800)?
Thanks all!
If you are primarily going to run 5S and run 6S now and then limiting WOT runs, the CP-2800 should be ok under these parameters.
If you are primarily going to run 6S primarily I would order the CP-2500.
901racer is offline Find More Posts by 901racer
Old Mar 05, 2012, 12:17 PM
901racer is offline
Joined Oct 2011
Originally Posted by PikeStaff View Post
Neat. Something else new to try. And spend money on . Love this hobby!
I maidened my 70mm F4 Phantom last Thursday, winds 12 to 15 with gusts 20+. Went up twice, back down twice with no damage, but flight was only correcting what the wind did to it. Couldn't consider trimming, as I had no idea what to trim or which way to go . Looking forward to sunny, calmer days.....
The gyro came from HPartz?
Yes, It came from hpartz. As erh indicates it does rate and heading hold. I have it programmed via er9x on a 3way switch so I can turn it off, rate, or heading hold. I have not had much luck with heading hold, but rate on the ail's work great. It was $12.
Old Mar 05, 2012, 12:27 PM
therealhiphop is offline
Find More Posts by therealhiphop
therealhiphop's Avatar
USA, UT, Springville
Joined Dec 2005
Thank you!
therealhiphop is offline Find More Posts by therealhiphop
Old Mar 05, 2012, 12:53 PM
Thomas Nelson is offline
Find More Posts by Thomas Nelson
Thomas Nelson's Avatar
Calgary, Alberta, Canada
Joined Sep 2002
Is it the Detrum GY192? There's two around the same price point ... ?
I've got several rate gyros and they're great for taming gusts. But trying to track straight down a runway during takeoff - with a crosswind - you need more than a rate gyro. This is owing to constant nature of the wind on heading, versus a gust.
I'd like to play with a HH gyro to get arrow-straight takeoff runs, but didn't realize they had come down $O much!
More than you ever wanted to know about using a HH gyro to stabilize a takeoff run is here.
tn
Thomas Nelson is offline Find More Posts by Thomas Nelson
Old Mar 05, 2012, 12:59 PM
901racer is offline
Joined Oct 2011
tn
It's the other one GY48V that i'm using. I am currently only using the Gyro in rate mode for stabilization in high wind and it's turned off during launch. I have not had luck with HH, need to learn and play a bit more with it.
Old Mar 05, 2012, 01:27 PM
MagnusEl is offline
Find More Posts by MagnusEl
MagnusEl's Avatar
Sweden, Gävleborg County
Joined Jan 2004
Originally Posted by anlucas View Post
Just saw this new motor from HK
http://www.hobbyking.com/hobbyking/s...00KV_755W.html
at 3000kv, it looks like it could be a bit better than the L2855-2800kv motors...
The other 3000kv motor, the L2226 is nice but being 29mm means using a different shroud that can take it which in my experience results in lower rotor blade clearance and slightly more rotor whine than the stock CS shroud.
It will be in my next HK order.
T-50 Ducted Fan (70MM) from HK does have a 29,5mm motor tube, and the shroud is 71mm, so it has more rotor clearance then original CS shroud. Out of stock for the moment...
Since the motor is 28,5mm, clearance is no problem.
T-50 fan is very similar to the fan that comes with the HK Vampire.
One more shroud that probably work is the Freewing 70mm. Motor tube 29,5mm and shroud dia 71mm.
MagnusEl is offline Find More Posts by MagnusEl
Old Mar 05, 2012, 01:47 PM
anlucas's Avatar
Joined May 2011
True in every aspect. Got a couple of T-50s from the last batch and got a few freewings from days past. I am using them with my L2226s.
I was just mentioning it because for someone who doesn't have the T-50 or freewing shrouds, the L2226 means that you also have to spend another $6-7 for a shroud.
This new NTM 2836 3000kv maybe a good alternative to the L2226.
Old Mar 05, 2012, 02:51 PM
SteveC68 is offline
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
If I'm not mistaken the T-50 fan is more like a 71mm. You should measure the ID of the shroud to confirm this. Also you should take several measurements all the way around the shroud as the one I have is not round, but egg shaped. One shround that I have used (mostly because the rotors are junk) and combined with HET rotors is this:
http://www.hobbyking.com/hobbyking/s...inch_68mm.html
I've mounted everything from the little KD450 heli motor that HK sells to the JS-1400 in these shrouds and the only time one failed was about 120mph straight into the ground. The HET rotors fit perfectly in these shrouds and the picture is wrong. The mounting tabs are attached to the shroud just like the T-50.
Old Mar 05, 2012, 03:03 PM
SteveC68 is offline
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
Originally Posted by Extreme_RC View Post
4mm shaft adapters
Are you going to be selling the 4mm shaft adapters on your site? Are these just the 4mm wemotec minifan adapters?
Old Mar 05, 2012, 03:35 PM
Glacier Girl is offline
Find More Posts by Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
OK what am I missing here.
I fired up the HET 3W (2980 kv) today on a fresh charged 4S5800 30C pack, in the Me262.
Amps 48, Watts 691.2, Volts 14.4 Settled readings. 1 motor.
Fans were installed in the nacelles, with thrust tubes, and I reformed the front of the nacelles to a lip shape from the flat original faces on them.
The nacelles also have cheater holes in them as the stock set up with WeMo 6904's needed em.
I was thinking more in the near to 70 amps and 1000 watts, like the similar 3000 kv units?
Esc's, Suppo 50 amp, are set to 1 degree timing (recommended for inrunners) and 8 KHz.
Glacier Girl is offline Find More Posts by Glacier Girl
Old Mar 05, 2012, 04:24 PM
901racer is offline
Joined Oct 2011
I don't know what to expect with this motor, no experience with it. Throttle range calibration with the ESC ok?
Old Mar 05, 2012, 04:28 PM
clive45 is offline
Find More Posts by clive45
It should fly at least once
clive45's Avatar
Australia, NSW, Grenfell
Joined Mar 2006
What you must realize is that the static fins in the shroud are different in some cases to those of the CS10. If it has been designed correctly the shape and angle are correct only for that fan, so putting a CS10 blade fan in a Sapac may not be as efficient as it should be. From what I gather its to do with controlling swirl angles from the moving blades and getting the best straight flow of air out the back.
All parts are not equal......also what about tip space is that the same for both fans?
clive45 is offline Find More Posts by clive45
Old Mar 05, 2012, 05:10 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
wemo adapters are wrong size by a long shot. I will have them available soon as I can get round to finish machining the first batch sometime this week.
Extreme_RC is offline Find More Posts by Extreme_RC
New Product Change Sun 12 blade 90mm Flip Flop Electric Ducted Fan Jet Talk 7194 Dec 14, 2015 04:03 PM
New Product Change Sun 120mm and new 10 blade 70mm fans Flip Flop Electric Ducted Fan Jet Talk 131 Apr 27, 2012 08:07 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 07:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 02:27 PM
Sold Change Sun Electric retracts NIB 75.00 jzuniga Aircraft - Electric - Jets (FS/W) 2 Sep 03, 2010 10:36 AM
