Old Oct 23, 2011, 10:27 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
thats what I found also. I plan on mine taking right many hits so checking out alternative setups.
pug398 is offline Find More Posts by pug398
Old Oct 25, 2011, 07:02 PM
daign is offline
Find More Posts by daign
My RC builds in my profile.
daign's Avatar
Joined Feb 2011
Originally Posted by pug398 View Post
daign did you mean 5x3? I had to source them from two different suppliers so hopefully the cw match the ccw.
Yup my bad. Different Projecr. I need a source for 5x3 props. I plan on running 2s.
daign is offline Find More Posts by daign
Old Oct 26, 2011, 09:51 AM
spudandretti is offline
Find More Posts by spudandretti
Honey,just one more thing
spudandretti's Avatar
Rensselaer,IN
Joined Jan 2003
Me too, HK is out. Anybody?
spudandretti is offline Find More Posts by spudandretti
Old Oct 26, 2011, 12:52 PM
Qrome is offline
Find More Posts by Qrome
Design > Build > Fly
Qrome's Avatar
United States, AZ, Mesa
Joined Feb 2005
I just ordered some, thanks. I am going to try the 5030 and the 5030 Triblades.
Qrome is offline Find More Posts by Qrome
Old Oct 26, 2011, 12:57 PM
LazyZero is offline
Find More Posts by LazyZero
Master of Flash
LazyZero's Avatar
Alsdorf/Eifel, Germany
Joined Jun 2005
These props are very bad Produced. I was not able to balance them. Now they are in the trash can.
Better go for the 3 blate from GWS. Check goodluckbuy.com or hobbydreams.com
LazyZero is offline Find More Posts by LazyZero
Old Oct 26, 2011, 02:34 PM
Rensselaer,IN
Joined Jan 2003
Thanks guys, did finally go back to HK and see those Erazotropa. Did get some. Going to order some 3 bladers LazyZero if I can't get the standard ones balanced. Bud
Old Oct 26, 2011, 05:32 PM
AlPackin is offline
Find More Posts by AlPackin
AlPackin's Avatar
United States, CT
Joined Mar 2011
thanks for the link, I just ordered the GWS 5030s from goodluckbuy.com
AlPackin is offline Find More Posts by AlPackin
Old Oct 26, 2011, 10:36 PM
slim1357 is offline
Find More Posts by slim1357
slim1357's Avatar
United States, OR, Portland
Joined Dec 2010
Finished mine
Not sure if the image file is attached, smartphones....
Anyhow I had to use aluminum standoffs because I couldn't find what I wanted in nylon from a local hardware store. Got my three blade gws 5030 props from rcdude.com. I was able to get them to work with prop savers using the twist method with the o-rings. They dont seem to sit level while static but are fine in flight. Definitely saved me from a bent shaft while tuning the board. I have some adapters otw so I will try those when they arrive.
I got HK motors like the ones recommended in the op. I added a little epoxy where the wires go in for strain relief. Some of the set screws for the shaft were quite loose so if you use the same motors, tighten them down prior to maiden flight. running on proton/hobbywing 12a escs and gens ace 800mah 3s. FC board is a HK KK board running quad x 1.7.
I'm reasonably certain I am going to break an arm or two so I will likely be ordering a spare frame. Any chance there might be cf or a similar material available in the future?
slim1357 is offline Find More Posts by slim1357
Old Oct 27, 2011, 01:42 AM
braindead4554 is offline
Find More Posts by braindead4554
Multicopter Addict
braindead4554's Avatar
Southwest Minnesota
Joined Feb 2010
^^ added pic to front page thanks!
Whats the weight of your quad?
braindead4554 is offline Find More Posts by braindead4554
Old Oct 27, 2011, 03:19 AM
slim1357 is offline
slim1357's Avatar
Joined Dec 2010
With a battery, 318 grams
Just like me it needs to go on a diet.
It hovers at just over mid stick. I haven't had an opportunity to check flight times yet. Motors are slightly warm after about 3 minutes.
Old Oct 27, 2011, 08:58 PM
pug398 is offline
VA
Joined Nov 2009
Wow, nice job getting it done. I just got the motors in this afternoon.
I had tried a 5g 3500kv micro motor with the 5030 and it started off a real powerhouse but bearings were gone in less than 10 minutes See another one more suited after I try out the 1811-2000 on the first frame.
Old Oct 28, 2011, 09:26 AM
Qrome is offline
Qrome's Avatar
Joined Feb 2005
I am just waiting on the props for now. Fully ground tested.
Old Oct 28, 2011, 10:40 AM
erazotropa is offline
Find More Posts by erazotropa
MyFlyDream
erazotropa's Avatar
The Netherlands
Joined Jun 2010
Just received 2 micro quad frames.. cant wait to build!
erazotropa is offline Find More Posts by erazotropa
Old Oct 28, 2011, 11:22 AM
pug398 is offline
VA
Joined Nov 2009
What size screws did you use in the motor mounts? Nice looking setup.
Discussion My Ghetto Quad - 1 WiiM+ & 1 Arduino Pro Mini - Exposed wiring troynh Aerial Photography 141 Nov 20, 2011 09:58 AM
Discussion HK has a new mini quad frame Pintac Multirotor Talk 20 Sep 28, 2011 11:04 AM
Discussion My 9" Mini Quad. Scotth72 Multirotor Talk 16 Apr 18, 2011 03:50 PM
Wanted WTB:Pocket quad/mini quad....roller/parts marz1 Non R/C Items (FS/W) 0 Apr 13, 2011 07:30 PM
