Old Oct 17, 2011, 01:06 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
Nice little frame when assembled and looking forward to the motors getting here. I would like a chance to try it in a single layer G10 3mm or 1/8" version as well. Maybe a little slot milled in the center straight stretch of each arm. One of the cleanest cut jobs I have ever seen with virtually no burn.
pug398 is offline Find More Posts by pug398
Old Oct 17, 2011, 01:17 PM
pug398 is offline
VA
Joined Nov 2009
Originally Posted by daign View Post
on its way! will be running my quadrino!
any USA source for the 9x5 EPP props?
daign did you mean 5x3? I had to source them from two different suppliers so hopefully the cw match the ccw.
Old Oct 17, 2011, 01:34 PM
Qrome is offline
Find More Posts by Qrome
Design > Build > Fly
Qrome's Avatar
United States, AZ, Mesa
Joined Feb 2005
Question: does anyone have a good way to use the Tri-blade props with a prop saver o-ring? Just wondering, I think I might want to try the tri-blade on this.
Qrome is offline Find More Posts by Qrome
Old Oct 19, 2011, 12:41 PM
slim1357 is offline
Find More Posts by slim1357
slim1357's Avatar
United States, OR, Portland
Joined Dec 2010
I cannot think of a way that would work. I was planing on buying adapters. If you come up with a solution, please post it here!
slim1357 is offline Find More Posts by slim1357
Old Oct 19, 2011, 12:55 PM
Qrome is offline
Qrome's Avatar
Joined Feb 2005
Are there some tiny light adapters that can be used that don't weigh more than these motors?
Old Oct 19, 2011, 01:22 PM
pug398 is offline
VA
Joined Nov 2009
other than drilling\tapping an adaptor hub every 120 degrees I don't see how it would work. Pick one screw to be 0/360 and then put other screws at 120 and 240.
Old Oct 19, 2011, 01:44 PM
shultz is offline
Find More Posts by shultz
United States, NV, North Las Vegas
Joined Sep 2009
Q, maybe this thread will be of some use.
http://www.rcgroups.com/forums/showthread.php?t=825355
shultz is offline Find More Posts by shultz
Last edited by shultz; Oct 19, 2011 at 03:37 PM. Reason: link went to page 2, change it to page one
Old Oct 19, 2011, 03:34 PM
c2po is offline
Find More Posts by c2po
Sudden Freak
c2po's Avatar
Atlanta, GA
Joined Oct 2006
Search ebay for "CNC prop JJ 2.0mm"
Just received mine (although it took a while, almost 3 weeks), very lightweight, around 2 grams each.
c2po is offline Find More Posts by c2po
Old Oct 19, 2011, 04:28 PM
Qrome is offline
Qrome's Avatar
Joined Feb 2005
Thanks, I just ordered 4 of them... may take 3 weeks. Until then, I can try the o-ring adapters. Thanks!
Old Oct 21, 2011, 12:54 AM
braindead4554 is offline
Find More Posts by braindead4554
Multicopter Addict
braindead4554's Avatar
Southwest Minnesota
Joined Feb 2010
Post #4 updated with shopping list for those that have been asking
braindead4554 is offline Find More Posts by braindead4554
Old Oct 21, 2011, 01:11 AM
SeismicCWave is offline
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
Me too. That will be about the same time my motors will show up from Hobby King.
SeismicCWave is offline Find More Posts by SeismicCWave
Old Oct 21, 2011, 06:45 PM
AlPackin is offline
Find More Posts by AlPackin
AlPackin's Avatar
United States, CT
Joined Mar 2011
I just ordered them too, we are all on the same page , thanks c2po
AlPackin is offline Find More Posts by AlPackin
Old Oct 22, 2011, 12:21 AM
c2po is offline
Sudden Freak
c2po's Avatar
Atlanta, GA
Joined Oct 2006
Sure, you're welcome, I actually found that tip in OpenPilot forums a while ago and bought a few just in case.
Old Oct 23, 2011, 07:06 PM
c2po is offline
Sudden Freak
c2po's Avatar
Atlanta, GA
Joined Oct 2006
Here is how those adapters look like:
Old Oct 23, 2011, 07:51 PM
shultz is offline
Joined Sep 2009
I wish you guys luck with the prop adapters... I found on small foamies running either the 10G or park 250 motors nearly everytime you touch the ground with a prop on an adapter OTHER than the prop saver the 2mm shafts bend...even a simple nose over landing on grass with my E-flight L-4 has bent the shaft...not much but enough to cause vibes... buy LOT's of shafts OR don't crash
Discussion My Ghetto Quad - 1 WiiM+ & 1 Arduino Pro Mini - Exposed wiring troynh Aerial Photography 141 Nov 20, 2011 08:58 AM
Discussion HK has a new mini quad frame Pintac Multirotor Talk 20 Sep 28, 2011 10:04 AM
Discussion My 9" Mini Quad. Scotth72 Multirotor Talk 16 Apr 18, 2011 02:50 PM
Wanted WTB:Pocket quad/mini quad....roller/parts marz1 Non R/C Items (FS/W) 0 Apr 13, 2011 06:30 PM
