Old Oct 12, 2011, 04:17 AM
braindead4554 is offline
Find More Posts by braindead4554
Multicopter Addict
braindead4554's Avatar
Southwest Minnesota
Joined Feb 2010
New Product
** Micro Quad / Funsize Quad ** BlueSkyRc.com
Here it is folks!! The mini quad you have been waiting for! I introduce to you the Micro Quad or another name it goes by is "Funsized". This little quad is simple.... light.... cheap.... SMALL....... and last but not least FUN!! Take it anywhere you go. Throw it in a bag, grab your radio and off you go to enjoy a day of flying.
But really here is a super fun lil affordable quad. I designed this to be simple, easy to fix, and as small as possible without breaking the bank. Teamed up with Qrome to bring, to the masses this frame.
Here is the web store where you can get your very own super awesome Micro frame at a super "Micro" price!
http://www.blueskyrc.com/index.php?m...products_id=30
Here are the specs,
Wood version
Motor to motor distance 8 inches
weighs 190 grams with battery
147 grams without battery
5x3 EPP Propellers (Standard and Counter Rotating)
18-11 2000kv Micro Brushless Outrunner (10g)
TURNIGY Plush 6A Speed Controller
800 mAh 20c 2s lipo battery
Arduino Pro Mini
6 DOF board with ITG3200 gyro, BMA180 acc
Black G10 version (My experiment version)
2mm Black G10
weighs 219 grams with battery
174 grams without battery
Arduino Pro Mini
braindead4554 is offline Find More Posts by braindead4554
Old Oct 12, 2011, 04:18 AM
Multicopter Addict
Southwest Minnesota
Joined Feb 2010
reserved for pics
Pics from daf12345
Pic from slim1357
Pics from Qrome
Pics from daign
Pics from SeismicCWave
Pics from erazotropa
Pic form Kronikpilot
Pic from spudandretti
Pic from c2po
Pic from pug398
Pic from rocketscience
Pic from Icewind
Pic from bob4432
Pic from skellator
Multicopter Addict
Southwest Minnesota
Joined Feb 2010
reserved for vids
Funsize Mini Quadcopter (2 min 2 sec)
microquad.wmv (4 min 46 sec)
BlueSkyRC Micro Quad (2 min 40 sec)
Maiden MicroQuad BlueSkyRC Funsized (5 min 22 sec)
BlueSkyRC.com Micro Quadcopter "Funsized" CopterControl (1 min 4 sec)
Micro1.MP4 (3 min 26 sec)
micro quad maiden! (3 min 4 sec)
miniQuadDome (2 min 35 sec)
MicroQuad Impressions (2 min 45 sec)
Old Oct 12, 2011, 04:25 AM
Multicopter Addict
Southwest Minnesota
Joined Feb 2010
reserved for build log
Shopping List
Micro Quad frame http://www.blueskyrc.com/index.php?m...products_id=30
5x3 EPP Propellers (Standard and Counter Rotating) http://www.hobbyking.com/hobbyking/s...dProduct=11328
18-11 2000kv Micro Brushless Outrunner (10g) http://www.hobbyking.com/hobbyking/s...idProduct=5358
TURNIGY Plush 6A Speed Controller http://www.hobbyking.com/hobbyking/s...idProduct=4318
Turnigy nano-tech 850mah 2S 25~40C Lipo Pack http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
Female JST battery pigtail http://www.hobbyking.com/hobbyking/s...idProduct=9683
Turnigy Battery Strap http://www.hobbyking.com/hobbyking/s...dProduct=11736
4- 12mm Hex stand offs
4- 19mm Hex stand offs
8- 3mm screws
16- mini wood screws for motor mounting http://www.hobbyking.com/hobbyking/s...idProduct=6996
Arduino and sensors to your liking
Originally Posted by cryhavoc38 View Post
Bought my micro quad along with a micro spyder from blueskyrc a couple weekends ago.
These are a neat inexpensive frame
Here is a semi completed pic of my micro.
waiting on the hobbywing 6amps to arrive
For those who are searching/sourcing parts..no need to go overseas for your parts when they are readily available stateside.
Motors
Here are the 2000kv 10 gram motors
http://www.headsuprc.com/servlet/the...0-Sport/Detail
Here are the 2mm prop adapters
http://www.headsuprc.com/servlet/the...r-2.0mm/Detail
These 2mm adapters I'm not a fan of. I had to cut down the shaft a few mm and also trim off some length to the inner plastic prop sleeve to get the prop screw to snug up against the prop itself. The ones I've listed above are much better suited, in my opinion to these tiny props.
Speedo's
Hobbywing Funfly 6amp esc (turnigy plush are hobbywing funfly/pentium esc's)
http://www.hobbypartz.com/hobbywing6aair.html
Same esc with a different name. Still a hobbywing funfly esc
http://www.hobbypartz.com/proton6aair.html
Another hobbywing pentium 6amp (aeolian)
http://www.leaderhobby.com/product.asp?ID=9394001220259
a couple other stateside sources
http://www.valuehobby.com/power-syst...flyfun-6a.html
http://www.toysonics.com/emax-esc-be...ming-card.html
IF you prefer the previous revision of the Hobbywing 6amp esc (smaller board)
http://www.headsuprc.com/servlet/the...--7-Amp/Detail
Props
For props, you can get Gemfan quadpacks from blueskyrc.com
http://www.blueskyrc.com/index.php?m...08fa01b29c6b41
GWS tri blades are available here
http://www.headsuprc.com/servlet/the...nch/Categories
For batteries, any of the retailers I've listed would carry a selection of small 2s and 3s sub 1000mAH packs
Make sure you purchase 3mm or 4-40 nylon standoffs from various sources on the web.
I get them very quickly from places such as multiwiicopter.com in australia (surprisingly, it takes just a few days to get them from AUS to WA state with their inexpensive shipping cost for small parts in a padded envelope)
I've also ordered standoffs from quadrocopter.com in Colorado and get them in a couple days.
For those who have only purchased the Plush esc...a little bit of info.
Hobbywing is perhaps the largest manufacturer of speed controls in the world, next to them would be ZTW.
The turnigy plush esc is a hobbywing pentium...now known as the Flyfun. Briefly known as the Fentium when intel TOLD Hobbywing that Pentium was a registered trademark.
Other brands of the "pentium" are
Exceed Proton
Emax
OEMRC
Next Level from Innov8tivedesigns.com and rcdude.com (the scorpion dudes)
Dualsky
flightpower's flightmax
Thunder Power's Higrade
DYS
Aeolian
Robot bird (for those of you in europe)
Compass (you heli heads would recognize this name)
The list is actually quite loong so don't think you need to get Turnigy Plush's from HK when you can get the same thing elsewhere and in stock
Old Oct 12, 2011, 12:16 PM
Qrome is offline
Find More Posts by Qrome
Design > Build > Fly
Qrome's Avatar
United States, AZ, Mesa
Joined Feb 2005
Subscribed! Thanks Terry!
Qrome is offline Find More Posts by Qrome
Old Oct 12, 2011, 01:38 PM
actionplus is offline
Find More Posts by actionplus
United States, CA, Rancho Cucamonga
Joined Mar 2005
Me too
I'm in.
actionplus is offline Find More Posts by actionplus
Old Oct 12, 2011, 01:56 PM
Z06 Tony is offline
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
If all the dealers did what YOU are doing there would be NO RCG. Do you realize that its the sponsorships that dealers pay is what keeps RCG site going? If you are gonna adv like this u should pay to be a sponsor.
Z06 Tony is offline Find More Posts by Z06 Tony
Site Sponsor
Old Oct 12, 2011, 04:49 PM
Qrome is offline
Qrome's Avatar
Joined Feb 2005
Brain dead, with those 10gram motors have you use the 5x3 prop on them? How well do they do if you go with the 3 blade prop and what size would you suggest?
I am still waiting for my motors and ESCs to get here, but I think it would be cool to run this little thing with a triblade. Any input on that guys?
Old Oct 12, 2011, 05:11 PM
Multicopter Addict
Southwest Minnesota
Joined Feb 2010
I haven't personally used the three blade props on this. I think it would work just as good. If a person wanted to use slightly bigger motors or run a 3s battery, three blade props would have to be used.
Old Oct 12, 2011, 05:13 PM
Qrome is offline
Qrome's Avatar
Joined Feb 2005
I see now, I assumed you used 3s packs -- I thought that is what I saw in your video.
Old Oct 12, 2011, 05:16 PM
Multicopter Addict
Southwest Minnesota
Joined Feb 2010
Nope. just 2s batteries to save weight even more. Weight is a big enemy. Have to keep it light as possible to get the performance and flight times to be the best it can be. Just a few extra grams will mess with how it flies and PID numbers.
Old Oct 12, 2011, 06:14 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
I was just getting ready to get the stuff to try to cut a mini frame so you saved me the trouble. Thanks.
pug398 is offline Find More Posts by pug398
Old Oct 12, 2011, 06:16 PM
daign is offline
Find More Posts by daign
My RC builds in my profile.
daign's Avatar
Joined Feb 2011
Perfect for CC!
daign is offline Find More Posts by daign
Old Oct 13, 2011, 08:55 AM
Joined Mar 2005
mtrs and prop
Got motors and 5" props coming in. And the frame coming in too. Yeppee!
Old Oct 13, 2011, 02:16 PM
daign is offline
daign's Avatar
Joined Feb 2011
on its way! will be running my quadrino!
any USA source for the 9x5 EPP props?
Discussion My Ghetto Quad - 1 WiiM+ & 1 Arduino Pro Mini - Exposed wiring troynh Aerial Photography 141 Nov 20, 2011 08:58 AM
Discussion HK has a new mini quad frame Pintac Multirotor Talk 20 Sep 28, 2011 10:04 AM
Discussion My 9" Mini Quad. Scotth72 Multirotor Talk 16 Apr 18, 2011 02:50 PM
Wanted WTB:Pocket quad/mini quad....roller/parts marz1 Non R/C Items (FS/W) 0 Apr 13, 2011 06:30 PM
