Old Oct 11, 2011, 11:35 PM
f.a.r.m.e.r is offline
Find More Posts by f.a.r.m.e.r
Farmer
f.a.r.m.e.r's Avatar
United States, CA, San Mateo
Joined Oct 2011
Help!
need help on how to press on the stock genius cp pinion onto C05 bl motor
I have a C05 brushless motor and the stock pinion from the walkera genius cp brushed motor.. i'v never pressed on a pinion on such a small motor and im afraid ill bend the shaft..
any sugestions on how I can press this stock genius cp pinion on the C05 brushless motor with a 1mm shaft with out bending it?
thanks in advance ya'll
farmer
f.a.r.m.e.r is offline Find More Posts by f.a.r.m.e.r
Old Oct 12, 2011, 12:26 AM
Farmer
Joined Oct 2011
help!!! lol!!!
Old Oct 12, 2011, 12:39 AM
buster7467 is offline
Find More Posts by buster7467
morgantown, wv
Joined Mar 2004
I must have been lucky. I just got the co5 today and took my stock pinion off and it pressed on with just hard finger pressure. I used loctite on the pinion to hold it.
buster7467 is offline Find More Posts by buster7467
Old Oct 12, 2011, 12:55 AM
Farmer
Joined Oct 2011
yea guess you are lucky lol
mine is tight cant press it down with my fingers and im afraid to ruin it cause them C05 shafts are soft metal they can twist and bend easily and that would suck lol
hopefully some one on here has some advice or sugesstions on getting my pinion on with out bending the shaft
Old Oct 12, 2011, 01:05 AM
Tom Z is offline
Find More Posts by Tom Z
RC Reviews & Tx Setup Guides
Tom Z's Avatar
United States
Joined Sep 2007
I had to press my pinion on in a vice as it was so tight but I bent the motor shaft. I bent it back straight again but it took a long time...
You need to ream the pinion hole a little bigger so it will slide on the motor
shaft tight by hand and then use Loctite 609 or similar to secure the pinion.
Forcing on the pinion too tight in a vise will probably bend the motor shaft as I found out.
Tom
Tom Z is offline Find More Posts by Tom Z
Old Oct 12, 2011, 01:56 AM
Farmer
Joined Oct 2011
Tom
thanks tom that worked (reaming out the pinion) I used an old 1mm shaft in a drill with polishing compound, then cleaned it with denatured alcohol put some anaerobics lock tite retainer and slid right on worked great.
thanks again tom
now I can finish installing my bl conversion!
Old Oct 12, 2011, 02:40 AM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
Your welcome, glad to help out.
Great job on reaming out the pinion.
That looks like a bottle from a T-rex kit, green R48. I have some from
my T-rex 450's.
The BL conversion is great! Very smooth, a lot of power, and very good climb out.
Let me know how you like the BL conversion.
Tom
Old Oct 12, 2011, 04:41 AM
h106frp is offline
Find More Posts by h106frp
Joined May 2011
Heating the pinion with a heat gun or soldering iron will allow you to make a traditional shrink fit, just leave the hole ever so slightly under size, heat up and drop onto shaft.
h106frp is offline Find More Posts by h106frp
Old Oct 12, 2011, 02:28 PM
Farmer
Joined Oct 2011
hey h106frp thanks ill try that on my second brushless conversion.
hey tom your right the genius cp flys so much better brushless. decided to order another conversion for my second one stock feels so whimpy now, lol
I can flip it down low easier now with out worrying about bogging the negative pitch on the inverted transition
overal its how it should of came lol
thanks again
farmer
Old Oct 12, 2011, 02:32 PM
Farmer
Joined Oct 2011
my T-rex 450's.
Tom
btw it is R48 from my trex 450 kits you have a good eye
brushless is awsome though
Old Oct 13, 2011, 06:28 AM
Z06 Tony is offline
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
OOPS wrong thread. I will post this in the genius thread
Z06 Tony is offline Find More Posts by Z06 Tony
Site Sponsor
Old Oct 13, 2011, 10:11 AM
Air Vaca is offline
Find More Posts by Air Vaca
Air Vaca's Avatar
Arivaca,Arizona
Joined May 2008
Hi Tony,
I usually associate a squeal with a gear slipping on its shaft. On the 4#3's it was the pinion most the time. If I lost the pin on the main it would squeal,, also. I haven't looked at my G close enough to see how the main is "keyed" to its shaft.
regards,
Bill
Air Vaca is offline Find More Posts by Air Vaca
Old Oct 13, 2011, 10:20 AM
Tom Z is offline
Tom Z's Avatar
United States
Joined Sep 2007
The Genius CP uses double keyed flat spots on the main shaft that the main gear locks on to.
See my picture.
Tom
Mini-Review Walkera Genius CP Review - Pictures, Video, Brushless Mod, Genius VS mCPX Tom Z Micro Helis 561 Oct 17, 2015 01:50 AM
Discussion Walkera Genius CP-the smallest 3d flybarless heli in the world! @ oomodel oomodel.com Hot Online Deals 17 Sep 28, 2015 10:48 AM
Discussion Walkera Genius CP issue resolved! Tom Z Micro Helis 44 Jan 03, 2012 10:56 PM
Help! is this the right brushless motor and esc for genius cp? f.a.r.m.e.r Micro Helis 16 Oct 07, 2011 03:40 PM
Discussion Setting Up Walkera 2603 for Genius CP Heli BernieHeli Electric Heli Talk 4 Oct 05, 2011 06:55 PM
