Old Oct 11, 2011, 10:44 PM
pow-wow is offline
Find More Posts by pow-wow
United States, TX, Austin
Joined Jul 2009
Help!
T-28 RX cut out caused crash
I have a micro T-28, and was enjoying flying it, but the receiver cut out and caused it to slam into the runway and bang the nose up pretty bad, should i send it to the company, or what?
at the time it as almost brand new, but its been a while since the crash( the last time I used it)
pow-wow is offline Find More Posts by pow-wow
Old Oct 12, 2011, 07:39 AM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
How do you know the RX cut out? Are you sure it wasn't a servo problem? Servos are more of a problem than signal losses with the micros. Try and see if you can duplicate the problem on the ground (check the servos on high rates at full throw and also do a range test).
Tres Wright is offline Find More Posts by Tres Wright
Old Oct 12, 2011, 08:27 AM
pow-wow is offline
Joined Jul 2009
Because the engine cut out and not one servo moved. It did happen a couple times before, but only for half a second or so.
Old Oct 12, 2011, 10:42 AM
Madratter is offline
Find More Posts by Madratter
Joined Jul 2011
That sounds suspiciously like the receiver is losing power. Might be a dodgy connection to the battery or something. Either way, call them up and see what they say.
Madratter is offline Find More Posts by Madratter
Old Oct 12, 2011, 12:03 PM
jabsten is offline
Find More Posts by jabsten
Can't get enough
jabsten's Avatar
United States, WA, Puyallup
Joined May 2010
What lipo are you using? Mine did that with the stock batt. Switched to hyp and it went away. What tx are you using? The toy tx sucks imo for range, so that might be an issue.
J
jabsten is offline Find More Posts by jabsten
Old Oct 12, 2011, 12:36 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
That is usually a battery/connector/power wire solder joint problem.
It's pretty rare for this problem to be in the brick itself.
UNGN is offline Find More Posts by UNGN
Old Oct 12, 2011, 12:37 PM
pow-wow is offline
Joined Jul 2009
I used one from a previous micro, but it was right in front of me. And it was with the stock battery. I'll contact them and see
Old Oct 12, 2011, 06:45 PM
ausf is online now
Find More Posts by ausf
ausf's Avatar
United States, NY, CENTRAL VLY
Joined May 2011
If everything went dead right in front of you, it's a power problem. Those battery wires eventually work their way loose if there's any tension, and by the nature of flying and changing the battery, there's plenty of tension.
Open it up and bench test it, moving the wire with a fresh battery until you can duplicate it. You can certainly call them, but it'll be much faster to have a look yourself.
ausf is online now Find More Posts by ausf
Old Oct 12, 2011, 07:02 PM
Cheese5 is offline
Find More Posts by Cheese5
Cheese5's Avatar
United States, CA
Joined Jul 2010
What TX are you using? Is this happening towards the end of the flight or are the signal losses scattered? Check where the RX antenna is, make sure it is not covered by the CF control rod. Also try to duplicate the signal loss on the ground, if you can do that, you would find the problem.
Cheese5 is offline Find More Posts by Cheese5
Old Oct 12, 2011, 10:36 PM
pow-wow is offline
Joined Jul 2009
I contacted them and they said basically after the first flight there's no warranty. But the guy was VERY nice and said since there's not much to do he'll send me another. He said they don't usually do that though. I got pretty lucky
it probably had something to do with a connection, I remember the battery hanging sometimes during flight and having to put it back
Old Oct 13, 2011, 03:38 AM
jimjim06 is offline
Find More Posts by jimjim06
jimjim06's Avatar
Sweden, Västra Götaland, Partille
Joined May 2009
Good luck for you!
The first "Mod" I did to my T-28 was to secure the battery with a piece of white Electrical tape, it keeps the battery in place and protects the batt on belly landing in moist grass. The tape I use has a weak "glue" and doesn´t leave a mark on the foam, it also covers the batt and makes the plane look nicer, so its a win-win mod.
I also use the same tape to mark my cells, the fully loaded gets taped over the connector, and once the tape is gone, I know that that battery is used.
Tommy
jimjim06 is offline Find More Posts by jimjim06
Old Oct 13, 2011, 09:01 AM
ausf is online now
ausf's Avatar
Joined May 2011
That's why they are the best in the business.
Inspect and resolder your old brick, that thing is worth it's weight in gold. I keep moving them from plane to plane.
Don't toss anything from the old one when you part it out, even the plastic aileron crank stem is important and could come in handy.
Old Oct 13, 2011, 01:25 PM
Forney, TX
Joined Mar 2002
Yup, my Beast was having intermittent problems and I finally traced it to a cold solder joint at the battery connector. I've read comments from others who have had the same issue.
Old Oct 13, 2011, 03:57 PM
pow-wow is offline
Joined Jul 2009
yes, I still have the brick and servos from a smashed citabria and p-51( that one might still be fixable) planning to use the RX and servos on a free flight glider I have
Old Oct 16, 2011, 02:20 PM
pow-wow is offline
Joined Jul 2009
-update-
It actually seems to be my transmitter( its being weird with the new plane, and another guys micro T-28). IIRC its the one from the UM P-51, are there any known compatibility issues? the Vapor works fine with this radio, this is odd....
Video Parkzone trojan t-28 first flight afther crash Anda Inc. Electric Plane Talk 2 Dec 06, 2012 10:09 PM
Discussion T-28 UM RX problem wittpilot Beginner Training Area (Aircraft-Electric) 11 Sep 12, 2011 09:34 PM
For Sale Parkzone T-28 with upgraded motor - RTF - Price Cut dpw21562 Aircraft - Electric - Airplanes (FS/W) 4 Jun 01, 2011 08:42 PM
Discussion Is this 'brown out' on my new AR6250? It caused a crash anyhow! Stuart Warne Radios 25 Aug 12, 2009 03:05 PM
