Old Oct 10, 2011, 11:43 PM
Speedy059 is offline
Find More Posts by Speedy059
Joined Jan 2010
Syma S033G - Larger Battery
I bought a Syma S033G (Yellow) at the mall the other day, it was an impulse by, and I was wondering if I could buy a larger battery somewhere?
Current Battery:
11.1V 1100mah Li-Pol Battery
Batter I want to get:
11.1V 2700mAh 30C LiPo Battery Pack
http://www.helipal.com/storm-11-1v-2...vf4j19qeelku72
Does anyone know if I need to get a new charger for this battery? And will this new battery from helipal fit into the battery compartment on the Syma S033G?
Are there any other longer lasting batteries that can fit this Syma S033G besides the one I listed above? It seems that is the largest one I can find.
Speedy059 is offline Find More Posts by Speedy059
Old Oct 11, 2011, 12:17 AM
helx is offline
Find More Posts by helx
helx's Avatar
Joined Oct 2011
Hi Speedy. Did you mean S033G?
helx is offline Find More Posts by helx
Old Oct 11, 2011, 12:58 AM
Joined Jan 2010
YEP! Thanks for pointing that out, just edited my post/thread.
Old Jan 11, 2012, 08:15 AM
rrb63 is offline
Find More Posts by rrb63
Joined Jan 2012
Hi speedy. did you try the battery you talked about, if so how did it work
rrb63 is offline Find More Posts by rrb63
Old Jan 11, 2012, 09:37 AM
MDflyGuy is offline
Find More Posts by MDflyGuy
Joined Dec 2011
hello, i bought a 11.1V 2200mAh 20C LiPo Battery Pack from amazon, for about $20
it JUST fit into the nose(where battery resides),works fine
seems to last me almost up to 30min of flying time,however i recommend taking breaks during that 30min(motors get hot)
My heli used to drift slightly backwards,so the added weight point made it tend to go forward now. (if it goes 2 fast forward for you you might need to add some tail weight to even it out)
MDflyGuy is offline Find More Posts by MDflyGuy
Old Jan 11, 2012, 09:56 AM
Heli Dad is offline
Find More Posts by Heli Dad
Joined Jan 2012
Or buy a lighter battery
Heli Dad is offline Find More Posts by Heli Dad
Old Jan 12, 2012, 12:00 PM
rrb63 is offline
Joined Jan 2012
Cool I'm glad it work, thats the onely thing I don't like is the flying is to short. I'm going to order one.
Old Jan 18, 2012, 07:44 AM
rrb63 is offline
Joined Jan 2012
Where did you find the battery for twenty dollars. the onely I found is $39.00
Old Jan 18, 2012, 09:01 AM
MDflyGuy is offline
Joined Dec 2011
http://www.amazon.com/2200mah-11-1v-...6898864&sr=8-3
Old Jan 18, 2012, 09:03 AM
MDflyGuy is offline
Joined Dec 2011
Current Battery:
From that link the pic shows a 2200mah battery, not 2700,so I would double check the mah before purchase
But 2200 is more than enough, trust.
I posted a link to a battery for $17
Old Jan 18, 2012, 04:56 PM
rrb63 is offline
Joined Jan 2012
Thanks man I realy apperciate you getting back to me, I'll get the battery on order,Thanks again
Old Mar 16, 2012, 05:50 PM
jaybochopper164 is offline
Find More Posts by jaybochopper164
Joined Jan 2012
Hi Guys, does the 2200mah battery help the power on the so33g or just the flight time?
jaybochopper164 is offline Find More Posts by jaybochopper164
Old Apr 09, 2013, 05:34 AM
DaiLafing is offline
Find More Posts by DaiLafing
Joined Apr 2013
Hi guys, sorry for grave digging but i signed up specifically for the question...
I got myself a S033G today, and am disappointed with flight time...
The battery i have inside is a 7.4V 1500mAh...
Why are your voltages higher? and can i cause some damage by over volting?
And did anyone else find an even better battery?
DaiLafing is offline Find More Posts by DaiLafing
Old Apr 09, 2013, 08:51 AM
drambuidhe is offline
Find More Posts by drambuidhe
United Kingdom, Scotland, Argyll and Bute
Joined Oct 2012
Hi and welcome to the club!! You have to accept, I'm afraid, that flight times on coax's are never that long. You will damage yours by going to 11.1v that was the voltage that the earlier so33g ran on.
You can however buy a larger capacity (mah) battery but the higher you go the heavier the battery and that affects your time too.
I use 2200mah batteries that weigh about the same as the stock battery and after changing the leads I just velcro them to the underneath of the canopy.
They can be changed in an instant and moved around to suit the wind conditions.
I would suggest buying a proper digital charger(approx 20) these can recharge much quicker and If you buy two batteries and using your original one you can have some good long play's. Stop every few minutes too cool off the motors though.
drambuidhe is offline Find More Posts by drambuidhe
Old Jul 23, 2013, 02:36 AM
ryd_or_die_278 is offline
Find More Posts by ryd_or_die_278
Joined Jul 2013
hey I went on ebay and have purchased 2 x 18650 3.7v 5000mah for $5ish USD im gona solder leads and make my own 7.4v 5000mah battery pack for my so33g chopper, http://www.ebay.com/itm/200924425566...84.m1439.l2649 , knowing my luck these will be sum false Chinese batterys putting out 2000mah or sumthing, but ohh well for $5USD its worth a try, hope they hurry up and turn up!!!
ryd_or_die_278 is offline Find More Posts by ryd_or_die_278
Sold FS: Four Heli's, Two Syma S107, Syma Chinook, 6007 - $45 theleetbeagle Aircraft - Electric - Helis (FS/W) 2 Sep 28, 2011 06:04 PM
Question SYMA 107 battery charging malt_master Micro Helis 2 Aug 24, 2011 04:26 PM
Discussion Plugged a larger battery in an old rc car. Something blew...but what? daniel_boone Electric Power Cars 6 Jul 18, 2011 10:18 AM
Question I have a Syma S107 (150mah battery) and a 400mah batt from walkera4#3Q alexdata Coaxial Helicopters 4 Apr 27, 2011 08:20 PM
Question Radian COG with larger battery alexreeves Electric Sailplanes 3 Mar 11, 2011 05:49 AM
