This thread is privately moderated by ryancsmith, who may elect to delete unwanted replies.
Old Oct 10, 2011, 10:35 PM
ryancsmith is offline
Find More Posts by ryancsmith
Joined Mar 2011
New Product
Compufly Port To Java With New Features
This is a port of Flytrons USB2PPM Project Compufly with some new features
You can use multiple usb sources and map any axis and button a channel of your choice.
You can also map multiple buttons to the same channel and adjust the ppm value to them
for a 3 way switch with 3 buttons type set up
Current feature list
Servo/PPM output
  • Ability to output no less then 10 ppm Channels
  • Channels need to be able to be inverted
  • Channels need to be able to have Trims rate settings
  • Channels need to be able to have Exponential rate settings
  • Channels need to have multiple input to output mappings
  • Channel Resolution 2048 (11Bit)
Joystick/Gamepad Control
  • Accept 3 or more USB device inputs
  • USB button detection on joystick interface
  • Support for POV HAT Buttons
  • Support for HAT Switches
  • Tabs or Pages for all detected USB interfaces
  • Mapped Values for all axis for specific device per Tab/Page
  • Output Device Configuration
  • Selection of number of channels
  • Mode selection Positive/Negative PPM
GUI
  • Resizable for use on note/netbooks
  • Ability to save/load settings
  • Show values for ppm output and joystick/mini joy axis with Progress Bar type scroll
Everything is kind of setup for my CH Products set up with joystick throttle and rudder at the moment.
Check out the google code page and try it out for yourself.
Make sure to read the wiki pages fore more info. Google Code: Joystick to PPM
I am looking for Java programmers and testers to help work out bugs.
If you think you fit the build PM me here and I'll add you to the list.
Cheers,
Ryan
ryancsmith is offline Find More Posts by ryancsmith
New Product Flight with Joystick!!! CompuFly USBtoPPM Converter Now avail on STOCK! MelihK FPV Talk 460 Sep 20, 2015 04:06 AM
Wanted An inexpensive 4 or 6 channel Tx with trainer port for Sim use. dafremen Aircraft - Electric - Helis (FS/W) 4 Sep 28, 2011 10:33 AM
Sold Compufly flytron totonor FPV Equipment (FS/W) 4 Apr 13, 2011 05:33 PM
Building the S&B Sea Fury with Enhancements (?) Greg Beshouri Foamies (Kits) 30 Dec 15, 2009 10:53 PM
Discussion Enough with the "enhancements" already - if it ain't broke, don't fix it surfimp Site Suggestions / Complaints 0 Feb 08, 2006 10:30 PM
