Old Dec 14, 2011, 07:18 PM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
Ahhhh...Sanger. I miss the valley. Whats the make on the 1700kv motor you are running v8?
scatsob is offline Find More Posts by scatsob
Old Dec 14, 2011, 07:22 PM
SCALECRAFT is offline
Find More Posts by SCALECRAFT
Joined Apr 2004
Originally Posted by v8truckin View Post
Sorry for the glare but couldn't get a good angle w/o much glare.
103a
2300w
6s blue lipo
1700kv outrunner
HW platinum 100a esc (18.75* timing)
Looks like my esc held up was cool to the touch, but the motor was hot. Not sure what the motor amps is rated @. Will prolly have to us this setup in another plane as I don't want to remove the esc & upgrade. Unless I buy the 1600kv combo and use this as a spare (since the specs show 86a). Charging batts will run a better vid by end of day.
http://www.youtube.com/watch?v=FuAGE...e_gdata_player
If thats the Tacon 1700kv motor. It's nominal max amps are 72, I think and max watts at 2400. Could it be a good combo?? Maybe. We'll try the Tacon 1700 out in a few days with more Data on how it performs.
steve
SCALECRAFT is offline Find More Posts by SCALECRAFT
Old Dec 14, 2011, 07:48 PM
v8truckin is online now
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Not a Tacon. It's a edf hobbies 1700kv (not sure who actually makes it), but its an outrunner. They have no specs on it on their site except the kv & lipo. It says 8s on the site, but the box I got says 6s-8s. It was givin to me for a mistake on an order.
Scat,
I missed it 2 when I moved to the bay area for work n cost of living went up. So I'm back, can't replace the country living.
v8truckin is online now Find More Posts by v8truckin
Old Dec 14, 2011, 08:24 PM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Your batts were sagging pretty bad...showed less than 20 volts at peak..
Old Dec 14, 2011, 08:34 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Ya I switched to a gens ace and the #'s jumped, I'll post in a bit.
Old Dec 14, 2011, 08:48 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Edf 90mm CS 12 blade (0 min 43 sec)
Gens Ace 6s 25c
Perfectly balanced prop n no spinner wobble. Too much amps for my esc so I pulled it and went back to my old 90mm. Guess I'll be putting this in my next 90mm edf whatever that'll be.
Old Dec 14, 2011, 08:58 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Much better...2700 watts is pretty good...It will be good to see how the tacon 1700 compairs
Old Dec 14, 2011, 09:31 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Ya just wish the amps were a lil lower. But the watts was were I was expecting. Wish I had a 150a esc in it, but I'd only be getting 3 min flights max with throttle managment. No bueño!
Ill Be looking for that 1700kv test just for comparison.
Lmeano_from_MO is offline
Find More Posts by Lmeano_from_MO
Fast Jets for Fast times
Lmeano_from_MO's Avatar
St. Peters MO.
Joined Nov 2007
I got my Tacon 1700KV motor today and quality looks good. I got a funny response when I requested that I get the EDF version with cooling holes. This was my reply.
Good morning Jeff,
The Tacon Brushless Motor LBP3674-B/2Y-1700KV For 90mm EDF Jet doesn't come with cooling holes. If you have any questions or concern regarding this matter, please feel free to contact us through via email or phone 1(626)968-9860 for technical support extension
Glad they aren’t sure what they have but I got mine with holes on both ends.
Lmeano_from_MO is offline Find More Posts by Lmeano_from_MO
Old Dec 14, 2011, 11:34 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Nice..wish we could figure out how to get that every time...other good point is all four screws will line up...the others on line up 2 screws...Mine is in a ready for testing tomorrow..had to fiddle with it to get it centered just right...working on a fix for that also
Old Dec 15, 2011, 07:40 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Good morning Jeff,
Now I wish I would've waited the ones I have don't have cooling holes, I've been beating up on the 810kv motor with the Hoaye 6 blade rotors on 12s and it has stood up pretty good regarding heat. I've run mine with long runs at 2200 watts and it's a shorter can length, 60mm, that the one you have.
The weak point on the older KDA and SUXFLY motors have been the magnets and not the windings, windings would hold up fine magnets hated heat and would lose their pull.
The Tacon 810 magnets are doing fine with no cooling holes so I suspect it'll hold up better with them, I also have the 2848 motor 2100kv motor in an 80mm Eflight....really surprised that it put out numbers close to the eflight 2100kv motor even though it was a shorter can....on both motors I used a heat sink
erh7771 is online now Find More Posts by erh7771
Old Dec 15, 2011, 07:45 AM
Joined Nov 2005
Scat,
I have one of those motors but its the 2400kv one, it gives 5pds of thrust at 4s\ 80 amps and 6.5 thrust at 5s 100 amps...very efficient motor with a Freewing fan
Love them because they only weigh around 6ozs, my fan assembly is 10oz without the the lip.
How was the heat on the motor after your testing? Any discernible change in winding wire brightness?
That's a pretty good motor if it can eat 2400 watts, it's can length isn't that long so I decided to keep mine at less than 2000 watts for it to last.
Old Dec 15, 2011, 08:00 AM
v8truckin's Avatar
United States, CA
Joined Dec 2010
It was hot to the touch , but did not look @ the windings.
Old Dec 15, 2011, 08:26 AM
FlyBoyTha1 is offline
Find More Posts by FlyBoyTha1
FlyBoyTha1's Avatar
The Greater Bay Area
Joined Sep 2008
I have a pair that i ordered each on different days they came the same as yours did each time.
Was that run up with or without a heatsink?
FlyBoyTha1 is offline Find More Posts by FlyBoyTha1
Old Dec 15, 2011, 09:02 AM
Joined Nov 2005
Originally Posted by FlyBoyTha1 View Post
I have a pair that i ordered each on different days they came the same as yours did each time...
Be interesting to know if these can take 3000 watts on a wemo using 8s, 1700kv takes this fan above 100 amps on 6s with the CS\12 fan
Looks like the 5pd bench mark for this fan is 1500kv at around 1300 watts.
......Was that run up with or without a heatsink?
It was an out runner, around a 50mm can
Sold Zurich sun blocking sun-glasses $40 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 7 Oct 06, 2011 10:47 PM
Sold Zurich sun blocking sun-glasses $50 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 0 Oct 05, 2011 09:14 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Video 6 and 12 blade 90mm fan sound test tom bacsanyi Electric Plane Talk 3 Dec 10, 2009 07:01 PM
