Old Dec 12, 2011, 08:08 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Originally Posted by Graham d View Post
Received mine too. Quality looks good but seems fairly heavy.
Will be trying a Suxfly 3674 1620KV on 6S to start off with. The motor has got the big holes in the front and back.
Will advise on numbers.
Any handy tips on balancing this fan?
Harmonic balance and then let the fan do the rest worked fine for me, it's the motor shaft length that's the balancing issue. Same thing for their 70mm fan...
erh7771 is offline Find More Posts by erh7771
Old Dec 12, 2011, 08:09 AM
wingspan100 is offline
Find More Posts by wingspan100
Lookout For The!Radio Silence.
wingspan100's Avatar
United States, AZ, Scottsdale
Joined Nov 2007
Originally Posted by pavcon View Post
haven't done anybalancing since mine is still in transit..
buw an accurate scale and having the opposing blades weighted and drill them with a 2 or 1.5mm drill underneath to match the weight.. at least that's what I intent to do
DRILL HOLES IN THE BLADES?
I gotta see this...
wingspan100 is offline Find More Posts by wingspan100
Old Dec 12, 2011, 08:24 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
I gotta see this...
not through the blades.. Im not stupd. The blades can be separated so underneath it is possible to do that...
pavcon is offline Find More Posts by pavcon
Old Dec 12, 2011, 09:24 AM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
You should NOT drill the blades. The best method for EDFs is to add weight to the other side. You can't afford to make any of the plastic weak. For small fans without separate blades, you can apply some CA to blade. Just the weight from CA is often enough to balance the fan. If the blades are separate, you can drill the center hub if necessary. Otherwise, epoxy the center hub under the blade or use the CA trick.
JimDrew is offline Find More Posts by JimDrew
Old Dec 12, 2011, 10:32 AM
Graham d is online now
Find More Posts by Graham d
South Africa, GP, Pretoria
Joined Mar 2011
Thank you guys.
Was just thinking that you would need a bit of epoxy on either side of the hub due to the weight of the fan.
Graham d is online now Find More Posts by Graham d
Old Dec 12, 2011, 11:11 AM
Mannyman535 is online now
Find More Posts by Mannyman535
edf flyer
Mannyman535's Avatar
United States, CA, Marina
Joined Feb 2009
have you guys got your shippment yet.
Mannyman535 is online now Find More Posts by Mannyman535
Old Dec 12, 2011, 11:18 AM
pavcon is offline
Joined Jan 2010
the way I'm going to dril them is not making them weaker.. stronger maybe but not weak.
try to bent a hollow shaft and try to bent a solid... if you know what I mean..
Old Dec 12, 2011, 11:25 AM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Sorry...in no way will drilling a hole(in any direction) make it stronger....Why drill when just adding a bit of weight with tape/glue/putty will solve the problem...I know on many types of equipment they drill hole to ballance but in that use the part is way over built in strength ...these fans are being pushed beyond the limit or close to it..dont risk it...stick with what works..
The only diffreence between a hollow shaft and a solid shaft is weight..if you take the same shaft of the same material the solid will bend and the hollow will fold at failure...it wont be stronger
Old Dec 12, 2011, 11:30 AM
Joined Nov 2007
I hope you explain further.
Old Dec 12, 2011, 11:33 AM
pavcon is offline
Joined Jan 2010
I will take photos when I receive and disassemble the fan
Old Dec 12, 2011, 12:04 PM
falcon5 is offline
Find More Posts by falcon5
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
Billy Madison - Insanely Idiotic (Academic Decathlon) (0 min 27 sec)
falcon5 is offline Find More Posts by falcon5
Old Dec 12, 2011, 12:09 PM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
People complaining about it being a copycat, please start a new thread. I'm tired of sifting through the tissue & tears, just to find the real reason this thread was started & what I'm looking 4...specs, info, & help.
v8truckin is offline Find More Posts by v8truckin
Old Dec 12, 2011, 12:24 PM
pavcon is offline
Joined Jan 2010
Originally Posted by falcon5 View Post
we will talk later... after I balance mine.. and if it works.. all these back to you falcon.. just don't erase your account.. I will be back for you because Ive done this b4
Old Dec 12, 2011, 12:36 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
N e 1 find a 1600kv motor for 6s setup yet? I've been searching for the 1 CS uses in their vid but can figure out which it is. Correct me if I'm wrong, but From what I've tried to read is that a 1700kv motor will pull too much amps.
Old Dec 12, 2011, 12:45 PM
pavcon is offline
Joined Jan 2010
can I suggest this one here???
http://www.hobbyking.com/hobbyking/s...dProduct=17698
Sold Zurich sun blocking sun-glasses $40 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 7 Oct 06, 2011 10:47 PM
Sold Zurich sun blocking sun-glasses $50 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 0 Oct 05, 2011 09:14 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Video 6 and 12 blade 90mm fan sound test tom bacsanyi Electric Plane Talk 3 Dec 10, 2009 07:01 PM
