Old Dec 10, 2011, 01:49 AM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Originally Posted by falcon5 View Post
1700kv will be too much. I have a 1400kv motor in a Stu 90 on 8S and pulling 90 amps and that's at 5000 feet above sea level, I would be over 100 amps a few thousand feet lower. Tell him to try 6S first, he should see around 100 in amp draw with 6S.
True, 6s will be the max is my guess. It may not even work on 6s. My ARC 75-1t is 1680kv and in a Midifan pulls 130a on 8s. With the CS-12 it would probably be over 160a.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Dec 10, 2011, 05:31 AM
Rusla is offline
Find More Posts by Rusla
Joined May 2008
There is 8 mm shaft version on the X-flight now
Rusla is offline Find More Posts by Rusla
Old Dec 10, 2011, 06:11 AM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
Nice. What would ne nicer is if they would offer just the adaptor for $5 fo those of us who already have the fan. Although it is a nice excuse to get another fan.
scatsob is offline Find More Posts by scatsob
Old Dec 10, 2011, 08:54 AM
Gaz-b is offline
Find More Posts by Gaz-b
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
Finally got to test the lander shroud this is with the std Lander 1280kv on 10s the data logger is a new one and live mode did not record so did a quick recording without a live screen wot 3.2 kg thrust 131a 4.2 KW at 2 KG thrust 52a 1.9 KW ay 1 KG thrust 37a 1.2 kw the cells had allready had a hiding so recharging and making sure data will record in live.looks like wot will need to be short turbo boost type bursts but plenty of poke still at half stick.
Gaz-b is offline Find More Posts by Gaz-b
Old Dec 10, 2011, 08:57 AM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
Forgot to mention those results are with the hawk eflux tube fitted
Old Dec 10, 2011, 09:18 AM
Samjet is offline
Find More Posts by Samjet
Samjet's Avatar
Joined Mar 2010
If I remember correctly the wemo does allmost 4,5 kg at 3,5 kW.
That is a disappointing cause I love the sound
Samjet is offline Find More Posts by Samjet
Old Dec 10, 2011, 09:32 AM
wanaka is offline
Find More Posts by wanaka
Joined Nov 2011
anyone know is this CS 12 blade is balanced?
this rotor needs balance?
wanaka is offline Find More Posts by wanaka
Old Dec 10, 2011, 09:45 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
That's with a thrust tube, I get over 9 pds on high cell count 3000 watts
erh7771 is online now Find More Posts by erh7771
Old Dec 10, 2011, 09:47 AM
Joined Nov 2005
Centrifugal balance if you have have a long enough motor shaft
Old Dec 10, 2011, 10:56 AM
hommel is offline
Find More Posts by hommel
hommel's Avatar
Netherlands, Zwolle
Joined Jul 2005
The thing with any multiblade fan is that matching the right motor with the right number of cells is much more complicated than achieving this with a 'normal' fan.
If you look at the CS70 fan, it would appear that relative low kv motors with a slightly higher weight are the way to go. I bet it won't be any different with this one...
hommel is offline Find More Posts by hommel
Old Dec 10, 2011, 11:11 AM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
What I cant wait to see is the performance difference when its in the airframe and in unloads with airspeed.
Old Dec 10, 2011, 11:16 AM
BILLYDSRC is online now
Find More Posts by BILLYDSRC
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
I think this is going to start a long discussion on this BUT EDF Do Not unload.
BILLYDSRC is online now Find More Posts by BILLYDSRC
Old Dec 10, 2011, 11:25 AM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
That kinda defies logic I will see what the logging reports compare the system in the airframe static and flying see if at a given rpm the amps drop or not.
Old Dec 10, 2011, 11:55 AM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
I'm afraid Billydsrc is right on this one, I have had this discusion before and was proven wrong as I could swear I could hear the fan unloading in the air but it was not to be. our motors will always go to its rpm based on the kv of the motor and voltage given at a cost of amps so as a fan unloads it doesnt go higher rpm it just stays at its kv/dcv/fan load rpm. maybe at a lower amp draw, if load increases too much amps and heat go up and and failure occures.
one of the ways I proved this to my self was to put a keychain cam on my jet and record a flight you can really hear that the motor never does increase rpm during a flight no matter what I did (vertical climb outs,diving) it stayed the same no matter what the external load on the fan was.
jcdfrd is offline Find More Posts by jcdfrd
Old Dec 10, 2011, 12:03 PM
Gaz-b is offline
Gaz-b's Avatar
Norwich,UK
Joined Feb 2006
So I am right then it's the decrease in amps I am looking for.
Sold Zurich sun blocking sun-glasses $40 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 7 Oct 06, 2011 10:47 PM
Sold Zurich sun blocking sun-glasses $50 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 0 Oct 05, 2011 09:14 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Video 6 and 12 blade 90mm fan sound test tom bacsanyi Electric Plane Talk 3 Dec 10, 2009 07:01 PM
