Old Dec 09, 2011, 11:55 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
yeah imagine boeing flight taking off from BEijing and when it reaches us crashes.. LOOOL
pavcon is offline Find More Posts by pavcon
Old Dec 09, 2011, 11:58 AM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Just a FYI..I was testing a Tacon 1700 and it let go just above 2k watts...Killed my CChv85 at the same time..not even a cool one..no smoke or flames..just pop and it is done..
I was runing it in a Wemo for comparison on 9s...peak was 2300 watts then setted down to 2000 max amps was 75...
Old Dec 09, 2011, 12:14 PM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
The fan let go or the motor?
scatsob is offline Find More Posts by scatsob
pavcon is offline
Joined Jan 2010
the fan gave too much stress to the motor
Old Dec 09, 2011, 12:47 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Hmmm, I have a TACON 810 KV motor on a Freewing Rotor (wemo knock off) and it's been giving me over 8lbs of thrust on 12s 50 amps.
It's a 36-60mm motor so it's shorter than the 1700, heats up good but I'm using a heat sink.
Did the coils burn or did the magnets demag? Have you tried another ESC?
In the past when magnets demag and I try to run it it takes out the ESC too.
erh7771 is online now Find More Posts by erh7771
Old Dec 09, 2011, 12:52 PM
wingspan100 is offline
Find More Posts by wingspan100
Lookout For The!Radio Silence.
wingspan100's Avatar
United States, AZ, Scottsdale
Joined Nov 2007
Originally Posted by wingspan100 View Post
It's more or less just a joke.
When they fly in China they mark the CG.
When we put them together in the USA, they are always tail heavy.
Try to explain that?
Lighten up guys, I did mention in the beginning it was sort of a joke, not to be taken seriously.
Still now one has attempted to explain how the manuals are always wrong.
The best explanation is that the manufacturer "Guessed" the CG.
Ok, I'm done now...
wingspan100 is offline Find More Posts by wingspan100
Old Dec 09, 2011, 12:56 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
motor let go...did have a heat sink on it also...should not have died at that power level..but I am sure it was near it limit..Only made 3 short power runs..Shorted a winding out...this motor has no cooling holes...I think that was a factor
Old Dec 09, 2011, 01:03 PM
Joined Nov 2005
Do you smell the windings? Is that what gave out?
I have the smaller green motor and it's been pretty good through multiple runs at over 2000 watts on 12s\50amps
Maybe it's the lack of amps that's giving the 810kv smaller TACON motor it's running power.
I also have the 40mm diameter 74 and it's in a haoye shroud and it's been bullet proof...
Old Dec 09, 2011, 02:07 PM
pavcon is offline
Joined Jan 2010
while the HET motors also have their coolling rings also have cooling holes and those holes are aligned with their EDF units and on top of that the EDF unit has low load.
Old Dec 09, 2011, 02:55 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
my buddy just recieved his new Tacon motor today I think he said its the 1700kv orange one, it came with nice large oval cooling holes in the end caps. very nice just hope it can hold up, he wants to run it on 8s in the cs 90/12 fan
jcdfrd is offline Find More Posts by jcdfrd
Old Dec 09, 2011, 03:14 PM
Joined Nov 2005
Flip Flop was doing 3000 watts with 1485kv, let us know how it goes
Old Dec 09, 2011, 03:19 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
was that on 8s? that would be around 100amp draw oooh thats a lot. may have to go 7s
this fan seem to have more load than normal
Old Dec 09, 2011, 04:06 PM
falcon5 is offline
Find More Posts by falcon5
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
1700kv will be too much. I have a 1400kv motor in a Stu 90 on 8S and pulling 90 amps and that's at 5000 feet above sea level, I would be over 100 amps a few thousand feet lower. Tell him to try 6S first, he should see around 100 in amp draw with 6S.
falcon5 is offline Find More Posts by falcon5
Old Dec 09, 2011, 04:07 PM
bobbit4447 is offline
Find More Posts by bobbit4447
Fly it like you stole it !
bobbit4447's Avatar
Australia, QLD, Coolum Beach
Joined Oct 2011
Thats dissapointing turbo.
For me the question did you have a bad one, or is this motor inheritently not up to the job? Certainly cooling holes will help, which seems some are being supplied with.
It does'nt make sense testing $40 motors if they are going to chew up $100 controllers!
Which leaves us with what motor results do we have on 6S - regardless of motor price ?
B
bobbit4447 is offline Find More Posts by bobbit4447
Old Dec 09, 2011, 04:19 PM
turbonut is offline
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Yea I wonder why some have holes and some dont..none that I got have holes...I will have my data loggger set up in a few days then retest with more systems..I still have one more TACON 1700 and 1300..plus I am going to mix parts from 2 blown motors..should be able to have one good one from the pair..I think I will mill holes in the other 2 I have..
Sold Zurich sun blocking sun-glasses $40 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 7 Oct 06, 2011 10:47 PM
Sold Zurich sun blocking sun-glasses $50 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 0 Oct 05, 2011 09:14 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Video 6 and 12 blade 90mm fan sound test tom bacsanyi Electric Plane Talk 3 Dec 10, 2009 07:01 PM
