Old Dec 04, 2011, 09:50 PM
turbonut is online now
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Hi Guys,
this is what was left! there is not damage from rotation at the retaining area..only the front tab missing from all the baldes..if it was stretch they would show damge from bending..Sorry i just dont think a blade this short will stretch..and no way the ring can..
FYI
I ran some test with 2000 watts as the bench mark to keep it apples to apples
CS 90mm 5blade 2100 watts 195mph eflux 7lbs 5oz
CS 90mm 12 blade 2300 watts 195mph 7lbs 2oz
Wemo 90 6 blade 2100 watts 195mph 8lbs.2oz
But the good part is the 12blade is 10k less rpm..should last longer and sound much better..
All test were run with a 12in long tail pipe at 70mm and the CS intake ring installed
turbonut is online now Find More Posts by turbonut
Old Dec 04, 2011, 10:16 PM
JimDrew is offline
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
This is caused by using the wrong material for the plastic. I am talking with the manufacturer right now about the changes required to eliminate this problem.
JimDrew is offline Find More Posts by JimDrew
Old Dec 04, 2011, 10:40 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
no inlet lip?
corsair nut is offline Find More Posts by corsair nut
Old Dec 04, 2011, 11:05 PM
stumax is offline
Find More Posts by stumax
The blade numbers go up to 11
stumax's Avatar
Sydney, Australia
Joined Aug 2002
Hmm, look at the broken blade pic and look at the CAD model of an SM89-45 rotor blade. They even copied the wedge profiled rings I use to lock it all together. What scumbags. I hope anyone selling this fan takes a good look at this and decides whether they are happy to endorse blatant ripoffs.
Stu.
stumax is offline Find More Posts by stumax
Old Dec 04, 2011, 11:12 PM
SCALECRAFT is offline
Find More Posts by SCALECRAFT
Joined Apr 2004
Originally Posted by turbonut View Post
Hi Guys,
FYI
Tacon 1700kv right??
Steve
SCALECRAFT is offline Find More Posts by SCALECRAFT
Old Dec 04, 2011, 11:13 PM
evo101 is offline
Find More Posts by evo101
evo101's Avatar
Australia
Joined Jun 2009
are they aloud to do that?
Stu.
evo101 is offline Find More Posts by evo101
Old Dec 04, 2011, 11:15 PM
Mike Warren is offline
Find More Posts by Mike Warren
BOHICA!
Mike Warren's Avatar
Joined Dec 2010
Stu,
I got dissed in the very beginning of this thread for pointing out the entirely obvious rip off of your design..........it's the "Wal Mart" mentality at work
Mike Warren is offline Find More Posts by Mike Warren
Old Dec 04, 2011, 11:20 PM
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
yes..
hey Brent....yes it is just off in the pic...I changed it the the CS lip to keep the info from the same set up..
Originally Posted by corsair nut View Post
no inlet lip?
the Tacon 1700 was in the wemo but that is not full power I stopped it at 2k watts to get matching numbers
Old Dec 04, 2011, 11:34 PM
stumax is offline
stumax's Avatar
Sydney, Australia
Joined Aug 2002
Originally Posted by Mike Warren View Post
Stu,
Yep, I originally thought they'd just copied the blade shape, but after I saw some pics of an exploded rotor I realised they'd copied the spinner locating ring and now it's clear they've copied the fact that I use wedge shaped rings to force the blades to lock radially inwards against the hub, as opposed to Dynamax who use rectangular shaped rings. What is clear, is that CS don't know what they're doing, judging by the thrust per Watt figures posted. they way I look at EDF's is that you (usually) need 1 fan per model but lots of lipos. Buy 1 good fan and lots of cheap lipos, then you have a fan which will last you almost forever, and lipos which are cheap enough to replace every couple of years when they wear out. A good fan will be 15% more efficient than a crap one, there's a 15% saving in lipo costs straight away, as you'll need 15% more energy to make up for the useless fan.
Spyda00, yes, unfortunately, they can do it. I could have filed a patent on the wedge shaped rings I use, it was clearly an inventive step over Dynamax's setup, but it's just not worth patenting something like this, as the patent really only gives me the right to go broke defending it. In any case, the Chinese companies will just sell direct to customers, in which case they don't have to worry about prosecution. I'm gonna have a long think about what to say to any of my dealers who sell this fan, though.
Stu.
Old Dec 04, 2011, 11:47 PM
stumax is offline
stumax's Avatar
Sydney, Australia
Joined Aug 2002
Why Jim? Why help them become better copycats? Why not work with a reputable company and develop a better product?
Stu.
Old Dec 05, 2011, 12:26 AM
Zimm is offline
Find More Posts by Zimm
Joined Jul 2004
Stu.
Everyone wants to save a buck!!! losing an eye ,or someone getting seriously injured, you have to ask your self is it worth it......
Stu how many rotors of yours have exploded? I bet not one!!!
zim
At the end of the day you get what you pay for!!!!!
Zimm is offline Find More Posts by Zimm
Old Dec 05, 2011, 12:32 AM
Zimm is offline
Joined Jul 2004
Stu,
I get a hammering also!!!! when i pointed out, if it doesn't perform as the original its not a good copy, and there is nothing to get excited about.
zim
Old Dec 05, 2011, 08:57 AM
Joined Apr 2004
With all due respect.
Note.
People made Walmart the number one retailer of it's time. It's not Walmart mentality, it's what people are willing to pay for on certain items of certain quality.
China copies stuff. Ask Boeing.
Me personally, I crash too much to get a top notch item. This is why I buy cheap, test the limits.
No reflection on a STUMAX product, but I have seen top quality products also fail due to user error.
So what does one control?
It's only Freedom of Choice.
Steve
Old Dec 05, 2011, 09:39 AM
JimDrew is offline
Lake Havasu, AZ
Joined Jun 2005
Stu.
So people don't get hurt. They are going to sell these fans no matter who likes it or not. Might as well make them safe. I think they should change the blade holding mechanism to something a bit more robust. The front tab is needs to be larger than the back one.
Old Dec 05, 2011, 09:40 AM
Concordefan is offline
Find More Posts by Concordefan
Scale Modeler
Concordefan's Avatar
Canada, ON, Mississauga
Joined Feb 2006
Originally Posted by Flip Flop View Post
That one I uploaded with better quality, but there was more talking in the back ground.
WOW, it's amazing how realistic sound this fan unit produces to the turbines, just lovely...Man i can only imagine how 4 of these together will sound in sync!.... What i'm noticing from the results that guys are getting is that, these fan are producing high static thrust and not so high E-flux speeds, which i'd say is better for certain scale jets as you want the high static thrust to get off the ground and be have enough to come in with good landing speeds Vs constant level flying speeds....
Concordefan is offline Find More Posts by Concordefan
Sold Zurich sun blocking sun-glasses $40 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 7 Oct 06, 2011 10:47 PM
Sold Zurich sun blocking sun-glasses $50 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 0 Oct 05, 2011 09:14 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Video 6 and 12 blade 90mm fan sound test tom bacsanyi Electric Plane Talk 3 Dec 10, 2009 07:01 PM
