Old Feb 13, 2013, 03:35 PM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
Originally Posted by erh7771 View Post
amps look a lil high... bout it
Well I'm assuming that the ESC is reading high as has been stated before. But does the thrust for rpm seem to be correct? Seems to me thrust is high also. ???
The reason I ask is I can't get any of the numbers to match up to the online fan calculators I have access to. Thrust is way higher on my setup. And rpm vs volts won't line up either.
Michael Paxton is offline Find More Posts by Michael Paxton
Old Feb 14, 2013, 01:48 AM
Shane Sunday is offline
Find More Posts by Shane Sunday
United Kingdom, Northern Ireland, Belfast
Joined Jun 2011
well I gave in and bought a new motor. It's a typhoon 1700kv jobby. and gues what... I got a flash of 83 amps and 1300+ watts on 6s. I think the real problem is my watt meter. this has been very expensive indeed. Needless to say that the thrust off the fan (out of the model) I could hardly stand behind. Such was the force.
Disho. I have my CS impeller in my wemo shroud. Go for it. Sounds like we have the same setup.
Shane Sunday is offline Find More Posts by Shane Sunday
Old Feb 14, 2013, 03:03 AM
union1 is online now
Find More Posts by union1
union1's Avatar
United Kingdom, England, Sudbury
Hi Shane, for what it's worth I've just bought a CS 90 with a Leopard 3674 1650kv motor for my Hunter.
The supplier quoted figures for this setup on 6 cells are 2.4 Kg thrust at 86A
FanCalc gives 2.7 Kg at 89A
Both of these work out around the 1700 -1800 Watt mark, so I gues you're right about the Watt meter!
Cheers, Pete
union1 is online now Find More Posts by union1
Old Feb 14, 2013, 05:47 AM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Is that the composite Hunter?
If so, what AUW do you have or expect?
Landing gear on it?
PeterVRC is offline Find More Posts by PeterVRC
Old Feb 14, 2013, 07:35 AM
union1's Avatar
Hi Peter, it's the ex-Fly Fly one. I'm looking for the AUW to be in the region of 2.5 - 2.75Kg, a bit up from the standard due to larger motor and batteries but should be fine on the wing loading front.
I've also done a bit of CF re-inforcement in the fuselage and intend to finish with wbpu and glass cloth.
I've fitted Eflite retracts with the supplied oleo struts.
I'll post the results here.
Cheers, Pete
Old Feb 14, 2013, 07:40 AM
PeterVRC is offline
Joined Nov 2006
Oh ok thnx.
Those FlyFly oleos and axles/wheels are a bit like shopping trolley stuff! LOL
My F-22 nose wheel 'exploded' its hub. Very cheap brittle plastic, which I could see when I put it all together - and should have changed - but figured as much as they are not very good, it would still work. But as it turned out... not for long....
Sideways forces did it of course, probably combined with the speed involved, but you can get that total easily enough at times. They are just really flakey things....
Old Feb 14, 2013, 08:02 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
For around 3000 watts thrust is a half pound higher but I'd expect that cause your volts are higher under load also.
What packs are you using again?
tia
erh7771 is online now Find More Posts by erh7771
Old Feb 14, 2013, 08:14 AM
Nashville TN.
Joined Mar 2006
GensAce 3300 25C.
Trying to set up a rig for my Sniper 90XL using what I have already.
Old Feb 14, 2013, 08:25 AM
union1's Avatar
Re the supplied oleos, I know just what you mean Peter! Lol They'll have to do until I can find suitable replacements - the mains are easy, it's the nosewheel leg that's tricky to find.
Old Feb 14, 2013, 09:47 PM
PeterVRC is offline
Joined Nov 2006
HobbyKing has a great series of excellent quality oleos, cheap!
Plus dual wheel for nose use.
The Alloy Oleo Legs, or Struts:
http://www.hobbyking.com/hobbyking/s...Oleo_Legs.html
Old Feb 15, 2013, 05:40 AM
Joined Nov 2005
GensAce 3300 25C.
Gonna be a fast sniper
vids or it didn't happen
Old Feb 15, 2013, 03:17 PM
Nashville TN.
Joined Mar 2006
True. Wish I had a vid camera instead of a still camera doing video.
I've pulled the fan apart again as it won't stay in balance. I think I have it now.
Makes a big difference in rpm when it's balanced and the blades of the rotor are spinning flat.
I've roughed up all the surfaces of the rotor adapter to keep it from spinning round under load and added glue between blades and blue loctite to
the base of the adapter. Took a while to get the adapter perfectly smooth on my kinda worn out motor.
Charging up batts now.
Old Feb 15, 2013, 04:05 PM
Nashville TN.
Joined Mar 2006
New thrust test with video.
You can hear how awful the HET bearings are. They've been like that since I got this motor installed in my Stu 80mm.
Thrust leveled out at 10 lbs 9 Oz. It was 10lbs 12 Oz max. No idea of efflux. But about 400 rpm more than previous test with same setup.
Video here: http://www.rcgroups.com/forums/showt...5#post24146560
Good news is that the fan is still in balance after this test. So I'll keep it in one piece for now. OH! Yea...And it didn't explode!!!
Old Feb 15, 2013, 08:49 PM
Joined Nov 2005
nice!!! Wonder what the max on the rotor would be after gluing.
What rollers did you use on your thrust stand?
Thx in advance
Old Feb 15, 2013, 11:19 PM
Nashville TN.
Joined Mar 2006
I think these rotors will be obsolete once we can all get a hold of the one piece ones.
The rollers are just Ace Hardware drawer roller. Essentially just a sliding shelf with no walls.
Sold Zurich sun blocking sun-glasses $40 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 7 Oct 06, 2011 10:47 PM
Sold Zurich sun blocking sun-glasses $50 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 0 Oct 05, 2011 09:14 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Video 6 and 12 blade 90mm fan sound test tom bacsanyi Electric Plane Talk 3 Dec 10, 2009 07:01 PM
