Old Jan 30, 2013, 06:27 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Originally Posted by Maxthrottle View Post
Drafting rules with the arrow on the outside would be 41.4mm OD. So they may be shooting for the 39mm motors.
Curious if they are making a finned heat sink to fit into the slots around the motor.
I hope not...there are tones of 40mm motors that would work find
erh7771 is online now Find More Posts by erh7771
Old Jan 30, 2013, 11:02 PM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
True the walls aren't going to be much over 1.4mm so it could be a 40mm ID. Just depends how thick that wall is. Guess its a wait and see...
Maxthrottle is offline Find More Posts by Maxthrottle
Old Jan 31, 2013, 12:31 AM
ticketec is offline
Find More Posts by ticketec
Brisbane, Australia
Hey Guy's.
I have a NIB CS12 an I bought from HK, and although i put the rotor on the scales yet, I'm tipping is going to be one of the doggy 49g version.
I'm about to order a fan from x-flight, but I couldn't see the rotor just on its own? and was thinking of the HK SK3 1500kv to run on 8s. Anyone done this or any thoughts?
http://www.hobbyking.com/hobbyking/s...dproduct=28503
Is the HET 2.5 times a better motor or get that much better performance because that's roughly the price difference.
P.s. going into a glassed+detailed flyfly Hawk which is looking to be about 4.5kg ready to fly.
Dave
ticketec is offline Find More Posts by ticketec
Old Jan 31, 2013, 01:06 AM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
I haven't seen that anyone has done it, but it should be able to do that.
Hard to know for sure, but you would expect a cheaper motor to use weaker magnets, lower temp windings, and probably cheaper bearings. (any or all of those).
But I expect it would still work well anyway. So you should be fine enough for that price.
You should have considered the HK Lander 10blade 1000kv setup. Its numbers look good, and it is alloy and ready to go. Run it on 8S or 9S.
PeterVRC is online now Find More Posts by PeterVRC
Old Jan 31, 2013, 01:31 AM
anlucas is offline
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
I think that from what people have posted here 1500kv is good as a mid-range 6S performer. Given its amp rating, it could possibly be pushed to 7S but 8S will most likely be too hot.
Most people here used HET 1400kv motors for hot 8S setups.
It's only 68mm long so unless fitted to an alloy housing for extra heat dissipation through the shroud, my personal opinion is to not go for 8S. The Dr Mad Thrust 1200kv looks good but more expensive.
Also, especially for 8S use, you could also decide to not use your suspect CS12 at all ( I have 3 sitting on the shelf) and use the shroud together with the new one piece 12 blade rotors along with the appropriate DPS shaft adapter.
anlucas is offline Find More Posts by anlucas
Old Jan 31, 2013, 10:52 AM
dlxpkg2000 is online now
Find More Posts by dlxpkg2000
dlxpkg2000's Avatar
Chi-Town, Il. U.S.A.
Joined Jul 2009
I just put my order in for the ARC 1400kv, to install in the CS shroud, with the new ONE PIECE 12 blade RCLander fan. I'm going to be running 8s in a H.T.G. L-39. Can anyone say "Fire in the Hole...?" I'll post bench results, when everything is hooked up on the test jig....
dlxpkg2000 is online now Find More Posts by dlxpkg2000
Old Jan 31, 2013, 11:23 AM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
1400 on 8S should be fine. You don't get into trouble until 11S
Michael Paxton is offline Find More Posts by Michael Paxton
Old Jan 31, 2013, 06:42 PM
SKYRYDER1000 is offline
Find More Posts by SKYRYDER1000
SKYRYDER1000's Avatar
NEW JERSEY U.S.A.
Joined Mar 2010
Ok dumb question here.. I just received my first cs 12 90 from Xflight. I planed to assemble it with Hysol or GG but it seems to be glued together already.
Are you guys pulling these apart and reassembling?
Thanks!
SKYRYDER1000 is offline Find More Posts by SKYRYDER1000
Old Jan 31, 2013, 08:43 PM
Joined Nov 2005
Hey Guy's.
I have a NIB CS12 an I bought from HK, and although i put the rotor on the scales yet, I'm tipping is going to be one of the doggy 49g version...
X-flight does have some spare blades for the fan 22usd
This motor looks promising, good cooling and 8mm shaft...I don't think it'll burn up or give you trouble...just no one has but it to thrust test yet...should be around 9-10lbs at 3000k watts.
Fan sounds really good in the FF model in the YT vids I've seen.
It's proven..
Please show pics....I have a FF Hawk in the garage screaming to be built and repainted T-45 colors
Old Jan 31, 2013, 08:45 PM
Joined Nov 2005
Thanks!
show pic, I do notice the blade bases are lot less concave now...
If you're going to put more than 3500 watts through I'd use GG
Old Feb 01, 2013, 09:00 AM
NEW JERSEY U.S.A.
Joined Mar 2010
Basicly what I am asking is how do I disassemble my assembled rotor down to 12 seperate blades.
Like I said it arrived fully assembled and I can't seem to get it apart...
I only plan to run about 2000watts in a flyfly Mirage 2000 using a HET 1680 kv motor. (If my Mirage ever gets here from HK).
Old Feb 01, 2013, 10:21 AM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Some of the CS9012 blades fit tighter into the retaining "washers" than others. I wouldn't bother disassembling it unless it doesn't run true. You won't need any glue or "bonding" assuming it is the 51g rotor (blades and retaining rings, no adapter or spinner).
You will still need to dynamically balance the whole motor/fan regardless of what you do.
Cheers
4stripes is offline Find More Posts by 4stripes
Old Feb 01, 2013, 03:19 PM
CarreraGTSCS is online now
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
Sky-- What did shipping run you? I put the 90mm MIG-15 in my cart but shipping was over $100. I was shocked. I figured it would be $40-50 tops.
CarreraGTSCS is online now Find More Posts by CarreraGTSCS
Old Feb 01, 2013, 03:35 PM
NEW JERSEY U.S.A.
Joined Mar 2010
Thanks for the response 4stripes. I finally got it apart after spending some time with it.
These fan blades had a super snug fit. I probably should have left it alone.
I plan to send Tamjets an email in the near future about balancing the fan unit.
"By the way" I enjoyed your Mirage 2000 build thread some very good mods and info there.
Old Feb 01, 2013, 04:02 PM
NEW JERSEY U.S.A.
Joined Mar 2010
INVOICE TOTAL: $101.04USD
SHIPPING: $68.73USD
I am only about 40-50 miles from you.
Shipping should be about the same I would figure.
I am going on week three of waiting for it to arrive.
Sold Zurich sun blocking sun-glasses $40 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 7 Oct 06, 2011 10:47 PM
Sold Zurich sun blocking sun-glasses $50 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 0 Oct 05, 2011 09:14 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Video 6 and 12 blade 90mm fan sound test tom bacsanyi Electric Plane Talk 3 Dec 10, 2009 07:01 PM
