Old Nov 25, 2012, 05:36 PM
ViperVJG73 is online now
Find More Posts by ViperVJG73
ViperVJG73's Avatar
Germany, SH, Neumünster
Joined Dec 2011
Hi guys, sorry for my stupid question.
Use you all these newer heavier 51 grams fans for your tests? Tell us please the weight of the fans you are testing.
It is very of concern.
Thanks.
ViperVJG73 is online now Find More Posts by ViperVJG73
Old Nov 26, 2012, 02:34 AM
scunna is offline
Find More Posts by scunna
scunna
scunna's Avatar
United Kingdom, England, South Shields
Joined May 2007
Originally Posted by dlxpkg2000 View Post
I'm going "batty" with these figures....I want to run the C.S 12 blade/90mm,Emax 1650kv on a C.C. 100 Lite,(w/heatsink) on 8s. 2x4s 4000mah,30c in series, in a 7 lb. H.T.G L-39. I've heard this fan would have too much amp draw for this set-up...Anyone want to chime in? Thanx in advance
changesun 12 blade fan 90mm 700-68 1400kv 8s 4400 65-130c nanotech lipos (3 min 25 sec)
scunna is offline Find More Posts by scunna
Old Nov 26, 2012, 11:28 AM
MagnusEl is offline
Find More Posts by MagnusEl
MagnusEl's Avatar
Sweden, Gävleborg County
Joined Jan 2004
Originally Posted by manuel v View Post
But with a Kv of 1709, everything is very different.
Yeah...Little too high Kv for 6 cells on the 90mm 12 blade I think.
I can confirm that the Kv rating from HobbyKing is wrong, I get Kv 1730 @ 11,35 volts...that is measured with a Kv meter. have not run it yet...
MagnusEl is offline Find More Posts by MagnusEl
Old Nov 26, 2012, 01:48 PM
manuel v is offline
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
Very consistency with my simple Kv read.
Motor 1.
Io=1.35A. No Load.
With little blade.
1.64A, 11.75V, 20,000 rpm, 1702 Kv.
Motor 2 with little blade.
1.8A, 12.05V, 20,600rpm, 1709 Kv.
For those motor real Kv is A little more high.
same your motor. 1730.
Manuel V.
manuel v is offline Find More Posts by manuel v
Old Nov 26, 2012, 05:50 PM
dlxpkg2000 is offline
Find More Posts by dlxpkg2000
dlxpkg2000's Avatar
Chi-Town, Il. U.S.A.
Joined Jul 2009
Scunna, What size ESC are you using in that set-up.?........
dlxpkg2000 is offline Find More Posts by dlxpkg2000
Old Nov 26, 2012, 06:38 PM
scunna is offline
scunna
scunna's Avatar
Joined May 2007
120 amp turnigy hv from hk
Old Nov 26, 2012, 06:56 PM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
very mush for motor.
Around 38,000 rpm, 3400 watts , 117A.
And only if the motor and batteries support it.
Old Nov 26, 2012, 07:01 PM
DamonH is online now
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
I received my fan assembly from xflight and wanted to confirm that it weighed in at 52g.
DamonH is online now Find More Posts by DamonH
Old Nov 26, 2012, 10:50 PM
4stripes is online now
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
I was having a tough time dynamic balancing one of my fans over the last few days. It would come very close at less than 3/4 throttle but above that it would vibrate as though it was out quite a bit. Figured something was changing position. I glued the adapter to fit tight on the motor shaft and that helped considerably but I couldn't get it perfectly smooth. I also used some locktite on the motor shaft just where it contacts the inner race of each bearing as the shaft had some slight play in each bearing. This helped a little but the final tiny bit of vibration couldn't be fixed until I reduced the play between the adapter and fan hub. There was a little slop as the fan sat on the adapter so a thin layer of CA was added on the inner hub where it contacts the adapter. Naturally it was too tight at first but I reamed it to fit with another spare adapter. With this last bit of slop removed the fan is now balancing much easier and more consistent at every power setting.
The point is, all play must be reduced as much as possible if you want to dynamic balance the fan properly.
Cheers
4stripes is online now Find More Posts by 4stripes
Old Nov 27, 2012, 03:48 AM
ViperVJG73's Avatar
Joined Dec 2011
THX for your info!
Old Nov 27, 2012, 08:52 AM
c131frdave is online now
Find More Posts by c131frdave
Too many numbers
United States, IL, Lake in the Hills
Joined Oct 2010
Hi guys. I have a new airframe coming, and I've had this fan in a drawer for about six months with no motor. Originally I planned on 1200KV at 10S in another airplane, which put it around 45000 rpm, but then I got cold feet. I decided that since there were some issues with blades departing the hub, I'd use a different fan. Now for my new airframe, I want to keep my RPMs down to a reasonable level with this fan. I'm putting a 1500KV motor on it and plan to use 6S. So at this speed (around 33k rpm), will I need to epoxy the blades? If so, how exactly do you do it? Hysol, or epoxy? Thanks!
c131frdave is online now Find More Posts by c131frdave
Old Nov 27, 2012, 09:03 AM
4stripes's Avatar
Joined Jan 2009
have you read through this thread recently? How much does your fan weigh (without adapter or spinner)?
If it is one of the weaker plastic fans, gluing will not prevent failure of this fan. Failure will cause more damage than just the shroud, you can expect a bent motor shaft as well, and whatever damage to the model that results from an uncontained failure without warning.
Replacement fans are available and the cost of buying a stronger fan is cheap insurance.
Old Nov 27, 2012, 09:10 AM
DamonH's Avatar
Joined Oct 2011
I can attest to the weaker (lighter) fan coming apart and destroying fan/shroud and motor. Luckily it hapened on my test sled before it was installed in a plane. If you have the 45g fan and not the 51ish g fan I would consider ordering the new fan. I just received my new unit from xflight and it is 52g.
Old Nov 27, 2012, 09:23 AM
Too many numbers
Joined Oct 2010
Are you weighing the entire fan unit (with the spinner), or just the blades? I'll look through the thread. I bought mine in June which was right when folks started talking about the problem. Is it 52 grams per blade? I actually have the program I used when I worked at General Electric for balancing compressor blades (uses weight of each blade and tells you where to put them) somewhere. Maybe I'll try and dig it up. lol Brings back memories- not all good...
Old Nov 27, 2012, 10:21 AM
DamonH's Avatar
Joined Oct 2011
It is 51-52g for the whole fan and the aluminum washer on the front and back. You do not weigh the motor adapter with it. That GE program sounds interesting.
Sold Zurich sun blocking sun-glasses $40 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 7 Oct 06, 2011 11:47 PM
Sold Zurich sun blocking sun-glasses $50 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 0 Oct 05, 2011 10:14 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 07:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 02:27 PM
Video 6 and 12 blade 90mm fan sound test tom bacsanyi Electric Plane Talk 3 Dec 10, 2009 08:01 PM
