I'm thinking maybe I don't understand your question, Michael.
I haven't found the need to grind flats - especially with 4 grub screws. I am sure of this since when I disassembled the failed unit there was no evidence whatsoever of the grub screws having slipped rotationally. Now you are possibly thinking that for the runout to change mid flight something has to move. But the slip is not rotational in nature ... I'd have seen evidence of it on the shaft. The slip must be along the axis of the shaft, and it must be ever ever so miniscule. I truly don't see how flats could prevent this kind of movement. One last thing. Depending on the tightening sequence and torque used with the grub screws, you can alter the runout of these adaptors. Zero runout is obviously the target, and so we make a reasonable number of trial & error attempts so as to end up with (1) equally TIGHT grub screws and (2) next-to-zero runout. Having or not having flats would neither help nor hinder this process. Or am I completely missing the gist of your question?? tn |
OH. I thought your adapter was spinning. Nevermind.
When I was balancing mine (before I gave up until you guys figure out a solution) I could put pressure on any one of the blades after balancing and it would throw the fan out of balance. It would essentially move that one blade around in it's spot enough to throw balance off.
I think if I had this problem I might try using hysol and try to get 3 or 4 drops at the bottom of the hole so that the waxed up motor shaft is in the glue, like a 1/4in of the end of the motor shaft. then install/tune the adapter to the motor and set aside in the proper orientation so as the glue levels out evenly and let cure......I think that might work. just a thought
You need one flat spot to keep the rotor from changing position on the motor shaft. If you have a perfectly dynamically balanced rotor and it twists just a few degrees it will be out of balance, sometimes quite a bit. As I have stated before, try the adapter in all 4 possible positions on the one flat spot to find the straightest position. If the adapter has any play then epoxy is needed to steady it in one position.
TN I think your adapter may have twisted on the motor shaft causing the imbalance that made the blades rub. Cheers |
chicago
Joined Nov 2008
Shroud recommendation
Hello,
Extreme RC sells a 90mm w/o lip for about $70. Has anyone used this on an MB339 flyfly? I am looking to do an 8mm setup with HET 700-68-1400kv 8s 5000. I don't want to have to cut up the plane. I originally bought some cs12s from x-flight; they recently sent me new blades for all of the fans I've ordered - they came out to about 4.5grams each. Thanks for any insite. |
Hey 4stripes, thanks again for your posts
Yeah I agree that a rotor slipping a few degrees would kill the best balancing job, and could definitely lead to disaster. But mine didn't slip. You can see where the grub screws had bit into the shaft and there is no rotational movement. In fact I'd go so far as to say that it looks like no movement whatsoever, but for the vibes to appear mid-flight suggests something moved, right? I've got yet another fan coming, this time from X-Flight. I'll wax, then align and glue the adaptor to the shaft, glue the blades & then balance it 'til I'm cross-eyed. Then fly it like I stole it. BTW, I 100% agree with you on the sound. It is the ONLY reason why I'm still fighting with this unit. Well, that plus the fact that others have clearly got past the problems I'm still fighting with. Without the success stories of others I'd have sadly gone back to fans with poorer acoustics and/or higher price tags. The Jetfan certainly has my attention - especially with ExtremeRC's aluminum (aluminium ) shroud, but all y'all's success stories with this unit keeps me coming back for more!tn (hopelessly addicted non-anonymous cross-eyed member of the "CS12 anonymous" club) Quote:
It has been a bit of a learning curve for me with this fan but the results speak for themselves.
Since your fan didn't shift in rotation TN it can only be the slop allowing the fan to wobble sideways, which will throw the balance off as well. Your next fan will be perfect! Cheers Eric |
a loose sloppy shaft adapter spells disaster no matter what fan your using, this is why this fan's success rate is all over the place. diff motor mnfg shaft sizes vary even though they all say 5mm some are slightly oversize and some undersized so depending on which motor you choose could be the diff between success and failure with this fan. a good running smooth setup starts with the motor and shaft adapter that runs true, if you can achieve that then you might have a chance with hours of balancing
Joined Nov 2005
I've never spent hours of balancing and have had more assemblies than I can count for me and others using different motors and shafts.
The good thing is the fan is going to get better throughout time... addicting more too it I got to fly me ARC F18E with the CS fan in front of a couple of full size F18 pilots on Saturday. It was hoot hearing the comments about the sound With a couple of throttle tricks (don't spool all the way down, use slow spool up during taxi) you get the "it sounds real" comments all the time. |
| Thread Tools | |
| Sold Zurich sun blocking sun-glasses $40 shipped | mjbennett9 | Aircraft - General - Miscellaneous (FS/W) | 7 | Oct 06, 2011 10:47 PM |
| Sold Zurich sun blocking sun-glasses $50 shipped | mjbennett9 | Aircraft - General - Miscellaneous (FS/W) | 0 | Oct 05, 2011 09:14 PM |
| Sold Change Sun electric retracts | Flip Flop | Aircraft - Electric - Jets (FS/W) | 3 | May 23, 2011 06:20 AM |
| Sold Change Sun Electronic retracts w/Lander struts | hole digger | Aircraft - Electric - Jets (FS/W) | 2 | May 06, 2011 01:27 PM |
| Video 6 and 12 blade 90mm fan sound test | tom bacsanyi | Electric Plane Talk | 3 | Dec 10, 2009 07:01 PM |
