Old Nov 15, 2012, 06:50 AM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Torchy the rings don't change. Weigh the whole fan, minus the spinner and adapter.
4stripes is offline Find More Posts by 4stripes
Old Nov 15, 2012, 06:56 AM
Torchy is offline
Find More Posts by Torchy
United States, NY, New York
Joined Aug 2011
46 grams.
Torchy is offline Find More Posts by Torchy
Old Nov 15, 2012, 08:39 AM
ViperVJG73 is offline
Find More Posts by ViperVJG73
ViperVJG73's Avatar
Germany, SH, Neumünster
Joined Dec 2011
Originally Posted by Torchy View Post
46 grams.
Same here!
I got it also from HK today. It's the set with the casing too.
Now I wait on the replacement rotor.
ViperVJG73 is offline Find More Posts by ViperVJG73
Old Nov 15, 2012, 08:56 AM
Thomas Nelson is offline
Find More Posts by Thomas Nelson
Thomas Nelson's Avatar
Calgary, Alberta, Canada
Joined Sep 2002
From my experience the "light" blades range from 2.85 to 3.02 grams each.
If I recall correctly from other posts, the "heavy" blades are in the neighborhood of 3.4-3.5 grams each.
tn
Thomas Nelson is offline Find More Posts by Thomas Nelson
Old Nov 15, 2012, 09:03 AM
EDForever is offline
Find More Posts by EDForever
Joined Nov 2012
Is rhere any xhance that rhe older light blades producemore thrust than the other ones?
EDForever is offline Find More Posts by EDForever
Reply With Quote  (Disabled)
Old Nov 15, 2012, 09:12 AM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
no, as they tend to produce less thrust when the blades come out...
Old Nov 15, 2012, 09:14 AM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
For those that got the weaker rotors, don't expect HK to acknowledge that they are "defective".
They do make good paper weights and conversation pieces...
Old Nov 15, 2012, 09:30 AM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
There wasn't enough of mine left to make a paper weight I guess the motor it pretty much destroyed could be used for that
DamonH is offline Find More Posts by DamonH
Old Nov 16, 2012, 12:24 PM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
Here is a better video of the changesun 1600kv combo in the ready 2 fly Venom
http://m.youtube.com/#/watch?feature...ure%3Dyoutu.be
Old Nov 16, 2012, 12:34 PM
Joined Nov 2012
guys...
I'm selling my used HET 700-68-1500kv motor
it is asselbled with an HET9305-700 fan
never used more than 8s and never raised the amps above 83 which was the maximum in my flyfly MB339.. with the macchi we were actually trying slow passes so the motor was never ever stressed.
asking 130 for the Fan and motor
and 100 for the motor only Shipped WW
Old Nov 17, 2012, 01:12 PM
ViperVJG73's Avatar
Joined Dec 2011
Should we not at all use these 46 grams weaker rotors or is there a limited usage such as max setup for 6S 1500kv 85 Amps?
Mine was very good in the static balance.
Old Nov 17, 2012, 01:48 PM
Torchy is offline
Joined Aug 2011
yup. I too want to know if it will work with the 1600 kv motors or not. I understand that they cannot sustain the higher rpm's and higher KV and or 7-10s combinations.
In the mean time, i will order replacement blades this week...
Old Nov 17, 2012, 01:50 PM
Kevin Cox is offline
Find More Posts by Kevin Cox
EDF Jet Jam 2016, June 16-19
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Great flying 4Stripes!
Kevin Cox is offline Find More Posts by Kevin Cox
Old Nov 17, 2012, 04:44 PM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
I personally will not use any more of my 45g rotors as they are too much work to dynamically balance and then have them destroy the shroud and possibly motor shaft as well. Had one blow at only 1800watts on 6S even though it was perfectly dynamically balanced.
The very early 45g rotors are still working for me but the ones sold this summer were duds.
Old Nov 17, 2012, 06:56 PM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
Thanks for the feedback!
The sound of this fan has caught the attention of many modelers at our field, including a couple turbine fliers! The performance is just right for the Venom. Thanks to the flier who made the video I can share the sweet sound.
Cheers
Sold Zurich sun blocking sun-glasses $40 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 7 Oct 06, 2011 10:47 PM
Sold Zurich sun blocking sun-glasses $50 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 0 Oct 05, 2011 09:14 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Video 6 and 12 blade 90mm fan sound test tom bacsanyi Electric Plane Talk 3 Dec 10, 2009 07:01 PM
