Old Nov 14, 2012, 07:48 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
Originally Posted by DamonH View Post
So Stripes...if I order from x-flight I can expect to receive the new version?
thats the way its lookin I have ordered from x-flight many times and have had pretty good service from them. thats where I would get it
jcdfrd is offline Find More Posts by jcdfrd
Old Nov 14, 2012, 08:15 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Originally Posted by jcdfrd View Post
thats the way its lookin I have ordered from x-flight many times and have had pretty good service from them. thats were I would get it
+1, x-flight has set a standard for CS overseas IMHO
I'm going to PU their 90mm blades and run it up with some ignorant power...
see what happens
Wish RC lander would sell the metal shroud for these fans
erh7771 is offline Find More Posts by erh7771
Old Nov 14, 2012, 08:33 PM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
4stripes, nice video...whats the AUW of your venom? Is the x-flight 1600kv combo pretty decent?
DamonH is offline Find More Posts by DamonH
Old Nov 14, 2012, 09:12 PM
4stripes is online now
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Sorry but I haven't weighed it but I estimate the weight at 2.5kg. Very light for a 1.5m wingspan!
The CS combo is pretty shoddy BUT can be made to work with some careful reassembly, and dynamic balancing. Everything, including the solder joints of the bullet connectors is suspect (one of mine just fell off before running). This particular combo and another two just like it each took two days of tinkering. Stupid faults like bearings loose in their mounts, flat spots on the motor shaft not filed far enough back to allow the adapter to be fitted as far on the shaft as possible, loose set screws, cut insulation, poorly cut motor wire slots, and the motor shafts are just a hair undersize for 5mm. But after all that, they do work really nicely in my FreewingVenom and Starmax F/A-18. If time is money and you don't have the patience of a monk, I would recommend an inrunner as they setup much better with less hassle. They also tend to be even quieter.
Cheers
EDIT; The plane weighs 2.91kg with battery.
PS The video quality is poor due to it being made on my cell phone but I will try to post another that was videoed with a better camera.
4stripes is online now Find More Posts by 4stripes
Old Nov 14, 2012, 09:35 PM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
Great Job 4Stripes! You got that thing sounding perfect!! (And I don't say that lightly!)
Cheers
Michael Paxton is offline Find More Posts by Michael Paxton
Old Nov 14, 2012, 09:58 PM
v8truckin is online now
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
4,
Good job on the balancing.
v8truckin is online now Find More Posts by v8truckin
Old Nov 14, 2012, 10:01 PM
DamonH is offline
DamonH's Avatar
Joined Oct 2011
Cheers
Thanks...I definately dont have the patience of a monk...lol Well actually I do but I also have a 4 year old that takes up alot of my time so its more a time issue for me. I just cant seem to find the time to dedicate to building that I'd like to have
Old Nov 15, 2012, 12:53 AM
Thomas Nelson is offline
Find More Posts by Thomas Nelson
Thomas Nelson's Avatar
Calgary, Alberta, Canada
Joined Sep 2002
Sounds Great! Nice flying too!
tn
Here's a link to my latest CS9012 powered Venom (X-flight 1600kv combo). I spent two days dynamic balancing this particular unit...
Thomas Nelson is offline Find More Posts by Thomas Nelson
Old Nov 15, 2012, 02:27 AM
Torchy is offline
Find More Posts by Torchy
United States, NY, New York
Joined Aug 2011
trying to keep my hopes high. Weighed the individual blades and found them all in the 3 gram range. 1 blade is at 2.9 grams . Would that be a good sign? rings weigh 10 grams.
Torchy is offline Find More Posts by Torchy
Old Nov 15, 2012, 02:32 AM
erh7771 is offline
Joined Nov 2005
Where did you get the unit from?
The HK units are the ones that are suspect IIRC
But if you get the blades rotor alone from HK or got the fan unit from X - Flight then most likely it's good to go
Old Nov 15, 2012, 02:39 AM
Torchy is offline
Joined Aug 2011
got it from HK. got the set with the casing. I am aware that the guys mentioned inconsistent QC with the fan set and that replacement blades are of better quality.
I was just hoping that if the individual blades weigh 3 grams that i would be in the safe zone, as the other attributes like stiffness seem to be good from the order i received.
Old Nov 15, 2012, 02:56 AM
erh7771 is offline
Joined Nov 2005
I believe you have to weigh it with the blades and top and bottom blade holders...that should be around 51 grams
Old Nov 15, 2012, 06:15 AM
rfodor is offline
Find More Posts by rfodor
United States, GA, Alpharetta
Joined Feb 2009
I received the replacement rotor from Hobby King yesterday and it weighs 52 grams. The blades are very stiff.
rfodor is offline Find More Posts by rfodor
Old Nov 15, 2012, 06:36 AM
EDForever is offline
Find More Posts by EDForever
Joined Nov 2012
x-flight never sent the soft version anyway
EDForever is offline Find More Posts by EDForever
Reply With Quote  (Disabled)
Old Nov 15, 2012, 06:41 AM
Torchy is offline
Joined Aug 2011
Has anyone weighed the good blades with out the rings? Im just curious. Maybe the rings can vary a few grams in productuon
I guess with my 1600kv motor, I will have better chances of not losing the blades
Sold Zurich sun blocking sun-glasses $40 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 7 Oct 06, 2011 10:47 PM
Sold Zurich sun blocking sun-glasses $50 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 0 Oct 05, 2011 09:14 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Video 6 and 12 blade 90mm fan sound test tom bacsanyi Electric Plane Talk 3 Dec 10, 2009 07:01 PM
