Can I use the default 45gr rotor for the Eurofighter with the 6S without problems? Thanks. |
I have half a dozen 45g fans that I will never use. It is frustrating to have it fail after spending time setting it up and dynamic balancing. Cheers |
Joined Nov 2005
Same thing for a hand drill but a little more time |
Australia, VIC, Melbourne
Joined Nov 2006
You mean check its alignment by running the drill/press after you 'straighten' it?
Once it is 'soft' it would be soft forever wouldn't it? At least softer than it was before.....? Can the shafts of inrunners actually be changed reasonably easily? Maybe some, and others not. |
Joined Nov 2006
I expect you could:
1) Mount it in a drill press (or a hand drill held in a vice) 2) Run the drilll and use a marker pen - move closer to the rotating armature till it JUST touches so that it marks it. 3) That mark will be on the 'bent outwards' side, so press 'away' from that as accurately as you can. 4) Repeat MAYBE if you were really patient and pedantic you could end up with a straight shaft....... |
HK sells a number of 5mm motor shafts. I'm sure you can made one fit. You may need to do some filing or cutting but 5mm shaft is all you need. http://www.hobbyking.com/hobbyking/s...Shaft_Set.html http://www.hobbyking.com/hobbyking/s...ent_Shaft.html http://www.hobbyking.com/hobbyking/s...ent_Shaft.html If it is an inrunner, it is far more complicated to change as the magnets are bonded to the shaft. I have straightened an inrunner, but it will bend much easier the second time and is probably not worth risking as you will destroy another shroud and fan. |
How high do you estimate the physical hazard with a hand launch by the CS12? There is a danger the blades penetrate the foam?
| Thread Tools | |
| Sold Zurich sun blocking sun-glasses $40 shipped | mjbennett9 | Aircraft - General - Miscellaneous (FS/W) | 7 | Oct 06, 2011 10:47 PM |
| Sold Zurich sun blocking sun-glasses $50 shipped | mjbennett9 | Aircraft - General - Miscellaneous (FS/W) | 0 | Oct 05, 2011 09:14 PM |
| Sold Change Sun electric retracts | Flip Flop | Aircraft - Electric - Jets (FS/W) | 3 | May 23, 2011 06:20 AM |
| Sold Change Sun Electronic retracts w/Lander struts | hole digger | Aircraft - Electric - Jets (FS/W) | 2 | May 06, 2011 01:27 PM |
| Video 6 and 12 blade 90mm fan sound test | tom bacsanyi | Electric Plane Talk | 3 | Dec 10, 2009 07:01 PM |
