Old Nov 03, 2012, 01:16 AM
mopetista is offline
Find More Posts by mopetista
Vienna, Austria
Joined Apr 2007
Originally Posted by davecrash View Post
I should also point out the 1350 was 1100kv under load in my post above. Running it in a fan with a lighter load will increase the rpm's, this may be a problem for the ESC.
you are right, your motor will not rev as high because the CS90 puts a much heavier load on it than a Wemo - but you're running 7s, I am doing 6s, and my rpms will not be higher than yours...
Just saw that the 1850kV warhead motor is in stock, might get myself one
to run it o 5s in the Wemo - and get the 1350kV later to work in a CS90
Thanks for your suggestions!
cheers
Clemens
mopetista is offline Find More Posts by mopetista
Old Nov 03, 2012, 12:39 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
Has anybody tried from X-Flight the new V2 fan/1600kv outrunner motor combo???...The price is right ($60!!!)...I'm looking for an inexpensive 6S fan/motor combo for my Exceed RC F-86...The stock Haoye fan/motor isn't cutting it...Since the price is right I may just get one anyway...
Here's the link to the fan/motor on X-Flight's site:
http://www.x-flight.com.hk/index.php...&more=&lang=en
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Nov 03, 2012, 02:54 PM
Torchy is offline
Find More Posts by Torchy
United States, NY, New York
Joined Aug 2011
How is the xrp -18 blade ? Is this any good or just another jack of all, master of none?
Looks interesting. ..
Torchy is offline Find More Posts by Torchy
Old Nov 03, 2012, 03:08 PM
davecrash is offline
Find More Posts by davecrash
Fly now crash later
davecrash's Avatar
Canada, ON, Newmarket
Joined Nov 2006
Theres a thread over here. http://www.rcgroups.com/forums/showthread.php?t=1717661
davecrash is offline Find More Posts by davecrash
Old Nov 03, 2012, 03:13 PM
4stripes is online now
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Kevin
Yes it works but it must be completely disassembled and reassembled (using locktite). The motor shaft flat spot likely needs filing farther down the shaft, and the whole thing needs dynamic balancing afterwards. You may need to glue in the bearings as they are prone to rotate in their mounts. Also the bullet connectors need checking as I had one fall off before use.
Yes, it is cheap and can be made to work, but it will require some of your time and patience.
Just go back through this thread as there are many references to this combo.
Cheers
4stripes is online now Find More Posts by 4stripes
Torchy is offline
Joined Aug 2011
Sorry. I actually thought I was still in the ef-2000 thread
Old Nov 04, 2012, 07:26 AM
vanderbrander is offline
Find More Posts by vanderbrander
Just an Earth bound misfit - I
vanderbrander's Avatar
Canada, ON, New Tecumseth
Joined Nov 2010
Kevin
For a cheap 6s setup Kevin, go with the HK3025 and the CS12. I had +25 flights on mine in the F86 and it went great. All the details of my install are in the
F86 thread.
vanderbrander is offline Find More Posts by vanderbrander
Old Nov 08, 2012, 09:38 AM
DamonH is online now
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
Anyone know where I can get the new heavier version of the CS12? I recently bought one from HK and it turned out to be the old version. I mounted and dynamically balanced a Hobby Top Gun 1600kv motor in it. I attempted to do a full run for amps/watts/thrust on my test stand and the fan/shrould explded and bent the motor shaft in the process. Also, anyone know where a I can a replacement shaft? Thanks.
DamonH is online now Find More Posts by DamonH
Old Nov 08, 2012, 01:56 PM
Torchy is offline
Joined Aug 2011
Hi Damon,
Can you please elaborate on the "exploded" CS 12 experience with your HK version? i have the same one coming from HK in a few days and i too have a 1600 kv motor from HK.
May i also ask if you performed the static balance prior to the dynamic balance? was the shaft assembly properly secured and balanced? was the motor shaft balanced? where the blades glued or secured 100%?
From my understanding, these all need to be done prior to the dynamic balance. Please don't take these questions as though i am questioning your knowledge... Just trying to figure out if all the steps were done in the respective order, for us to analyse the possible cause to rule out installation errors or quality issues.
Thank you for sharing this info as others can be more cautious with similar setups from HK.
Torchy
Old Nov 08, 2012, 02:06 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
Hi Damon,
Torchy
This might be for the 120mm, for the 90mm the hevier blades are the ones that work...
If you can bend the blades on your CS 90 fan then don't spin it up, ask for a replacement
erh7771 is online now Find More Posts by erh7771
Old Nov 08, 2012, 02:19 PM
DamonH's Avatar
Joined Oct 2011
Hi Damon,
Torchy
Everything was done except for the glueing of the blades. Motor was securley mounted/locktited in. Adapter was securley mounted and locktited in with all 4 allen screws.It was my understanding that you only had to glue the blades if you were planning on seriously overpowering the fan. The dynamic balance was almost perfect according to the vibration app and the excel spreadsheet. If I remember correctly the vib number was somewhere around .05 to .07 ish. If youve seen the spreadsheet I think these numbers are pretty good. I even rotated the spinner and found the best spot dynamically for it.
Old Nov 08, 2012, 02:29 PM
Torchy is offline
Joined Aug 2011
Thanks man! i found this video on you tube, do you have similar symptoms? i know its the 120mm but just curious if its quality issues with the blades or not...
CS 12 90mm EDF (4 min 51 sec)
Joined Nov 2005
You can get the heavier version from xflight or just get the blades...
HK sells the heavier blades too in their replacement rotors
Old Nov 08, 2012, 02:34 PM
Fly now crash later
davecrash's Avatar
Joined Nov 2006
My replacement rotor from HK is in customs now, should be here in a couple of days. I will let you guys know if it's the better one.
Old Nov 08, 2012, 02:41 PM
DamonH's Avatar
Joined Oct 2011
http://www.youtube.com/watch?v=mpO_usBVICc
Yes...that is VERY similar to what mine looked like. His shroud even looked like mine in that one of the mounts was broken off. My motor shaft was not quite a bad but toast none the less :censored Now I'm not sure what I want to do for my Eurofighter since this was the destination for this motor/fan.
Sold Zurich sun blocking sun-glasses $40 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 7 Oct 06, 2011 10:47 PM
Sold Zurich sun blocking sun-glasses $50 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 0 Oct 05, 2011 09:14 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Video 6 and 12 blade 90mm fan sound test tom bacsanyi Electric Plane Talk 3 Dec 10, 2009 07:01 PM
