Old Oct 28, 2012, 11:07 AM
davecrash is offline
Find More Posts by davecrash
Fly now crash later
davecrash's Avatar
Canada, ON, Newmarket
Joined Nov 2006
Originally Posted by erh7771 View Post
on 935kv HET I got around 12lbs of thrust on 12s at around 3/4 power before a blade tossed.
1100kv on 12s must have been a rocket
The first flight was on 2200mah 20C batteries, I was only hitting about 50amps. It wasn't anywhere near 12lbs. lol
I was thinking about 900 kv motor though, I like the low amp draw and smaller battery packs.
Has anyone tried the ARC 36-55-3 950kv on 12S ?
davecrash is offline Find More Posts by davecrash
Old Oct 28, 2012, 01:19 PM
alanjets is offline
Find More Posts by alanjets
alanjets's Avatar
Ripoff britain
Joined Jan 2011
This fan sounds nice got a HET 700/68/1125 motor on 8s
Hobbyking L59 (3 min 26 sec)
alanjets is offline Find More Posts by alanjets
Old Oct 28, 2012, 02:23 PM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
http://youtu.be/olEp_ca0f1Y
whoa, really nice sound to that jet....are you using full intakes?
regards
erh7771 is online now Find More Posts by erh7771
Old Oct 28, 2012, 03:05 PM
alanjets is offline
alanjets's Avatar
Ripoff britain
Joined Jan 2011
regards
yep all the intakes are in the only thing i did was to open the inlet to the duct took the lip off the inlet
Old Oct 28, 2012, 05:07 PM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Ya awesome sounding jet. Good job!
v8truckin is offline Find More Posts by v8truckin
Old Oct 28, 2012, 05:17 PM
out of stock is offline
Find More Posts by out of stock
Speed only
out of stock's Avatar
United States, FL, Lehigh Acres
Joined Jan 2012
thanks cooler that was needed
out of stock is offline Find More Posts by out of stock
Old Oct 30, 2012, 09:29 AM
Speed only
Joined Jan 2012
here are some numbers i got this morning.
4400 6s 30c
CS9012 / flyfly 1500kv outrunner
100a hw platinum
1500-1450w @ 67amps.
does that seem about right? will it launch from my hands? lol it feels like it want to rip out of my grip.
btw thanks nick its obviously a basic reliable setup to get started. everything was barely warm. sounds great too!
also , the manual states that adding NACA ducts would improve thrust up to 100g. im thinking of doing it but i dont know.
also should i set esc to med/high timing or low?
i hear a whistling sound (coming from motor it seems) that goes with throttle input. ive heard that from my 30cc sbach 342 eflite 160 motor. is that normal?
Old Oct 30, 2012, 09:33 AM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Ordered 1 90mm 12 blade from HK on the 15th Oct 2012 and delivered yesterday.
They are still shipping thew soft, weak, lighter fans and shrouds! Not very pleased...
For those wanting a good one made of stronger material, Ming from X-flight has them and the three I bought from him recently were fine.
4stripes is offline Find More Posts by 4stripes
Old Oct 30, 2012, 09:42 AM
darmar is offline
Find More Posts by darmar
USA, PA, Pittsburgh
Joined Jul 2001
How about replacement blades sets from x-flight? Are those harder than HK or not?
BTW Ming windrider is one outfit and x-Flight is another one in Hong Kong.
darmar is offline Find More Posts by darmar
Old Oct 30, 2012, 09:58 AM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Out of Stock..... that is a lower end of output that can get. It will pretty surely be due to that battery.
Even a 'weakish' flying plane will feel like it wants to leap out of your grip when testing. 1400/1500Watts will be a bit anaemic. That might even struggle for a hand lauch - at least to have a very safe one. It won't have the pulling power to accelerate to flying speed very quickly, so it will drop X amount..... and may, or may not, hit the ground before flying! LOL
So I would want it to be 'thrown well' by someone else.....
If you had a 5000mAH 65C sort of thing, it should go up to more like 1700/1800 watts area.... at least.
So, I don't think it WON'T fly..... it will just not have power to spare.
If it was taking off from a hard runway, it would fly fine, but would need a fair roll out distance.... which is fine if you want it to be scale-like anyway.
PeterVRC is offline Find More Posts by PeterVRC
Old Oct 30, 2012, 10:28 AM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
I checked, and it was xflight that I ordered from.
Cheers
Old Oct 30, 2012, 11:11 AM
Speed only
Joined Jan 2012
ahh! thanks peter. geez this blows. i should get a nano. time to do some shopping. any idea on that whistling sound that goes with throttle input? honestly i still haven't checked my speedy settings.
Old Oct 30, 2012, 01:01 PM
Speed only
Joined Jan 2012
well guess what? it flew right out of my girlfriends wimpy toss against the wind LOL. although it did take some time to get up to speed but it was no harder than my sapac euro. im charging for the next run. posting video tonight. shes a photographer so it should come out pretty good..
im curious about my esc temperature as i cant reach it. its quite cool outside so im sure its fine.
the heli guys are looking at me like im crazy because im the only lifting body out here (its windy and i believe that aided in hand launch)
Old Oct 30, 2012, 01:23 PM
v8truckin's Avatar
United States, CA
Joined Dec 2010
Ya Out of Stock, you should be getting between 75-85a and 1700-1900w, depending on timing and battery. So it's probably battery problem. What timing are you running your esc @. Also heat on the esc shouldn't be to much of a problem if it has adequate air flow, as my esc temp on that setup is warm. Also what size connector are you using 4mm, 5mm, 6mm?
Old Oct 30, 2012, 01:57 PM
Fly now crash later
davecrash's Avatar
Joined Nov 2006
I ordered the replacement blade a couple of days ago, I will report back when it arrives.
Sold Zurich sun blocking sun-glasses $40 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 7 Oct 06, 2011 10:47 PM
Sold Zurich sun blocking sun-glasses $50 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 0 Oct 05, 2011 09:14 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Video 6 and 12 blade 90mm fan sound test tom bacsanyi Electric Plane Talk 3 Dec 10, 2009 07:01 PM
