United States, CA, Los Alamitos
Joined Jan 2011
Blades of the CS90
Hey guys, just want to let you know don't breath to hard on the rotor. I was pushing a pulling as the collet slipped to far in on my TJ90 shroud and I was just pushing the collet and rotor out. Mind you it was not tightened or anything pushed out and with my finger damaged the trailing edge of the rotor.
I'm glad at this point I didn't have the chance to spool up on 12s as I had planned. Back to the old faithful rotor I guess. I wanted to give it a go but this material was really soft. |
I just checked the last 2 rotors I got, one was in a shroud the other was just a relacement rotor. I mixed them up so not sure which was which. One weighed 45g and the blades would flex more, the other was 51g and would barely flex at the blade tip. Guess I'm tossing the 45g one. That was the one I had ready to go too.
Australia, VIC, Melbourne
Joined Nov 2006
No real issue doing it either way.
Though technically, if you have cut it down it must be a BIT weaker. Mainly because it trims off some of the motor mount area. But it shouldn't care about that at all really.... at least until very high power levels, and you should have gone alloy by then anyway. |
Joined Nov 2005
It is only done for my convenience. Cheers |
I ran it on 12S on the HET 1100kv motor, On the second flight with better batteries the rotor flew apart. I have a 2nd generation rotor I will try again. |
people thanks for the info. i can totally understand why some guys slice the shroud. i thought it was either to shed weight and or fitment.
whats that rule again about watts per pound? i want to make sure my setup produces enough power to fly my bird.... will be doing a watt test tomorrow. i better get some sleep lol |
Joined Nov 2005
on 935kv HET I got around 12lbs of thrust on 12s at around 3/4 power before a blade tossed.1100kv on 12s must have been a rocket |
| Thread Tools | |
| Sold Zurich sun blocking sun-glasses $40 shipped | mjbennett9 | Aircraft - General - Miscellaneous (FS/W) | 7 | Oct 06, 2011 10:47 PM |
| Sold Zurich sun blocking sun-glasses $50 shipped | mjbennett9 | Aircraft - General - Miscellaneous (FS/W) | 0 | Oct 05, 2011 09:14 PM |
| Sold Change Sun electric retracts | Flip Flop | Aircraft - Electric - Jets (FS/W) | 3 | May 23, 2011 06:20 AM |
| Sold Change Sun Electronic retracts w/Lander struts | hole digger | Aircraft - Electric - Jets (FS/W) | 2 | May 06, 2011 01:27 PM |
| Video 6 and 12 blade 90mm fan sound test | tom bacsanyi | Electric Plane Talk | 3 | Dec 10, 2009 07:01 PM |
