Old Oct 24, 2012, 02:58 AM
MagnusEl is offline
Find More Posts by MagnusEl
MagnusEl's Avatar
Sweden, Gävleborg County
Joined Jan 2004
An easy way to check magnetic poles on an inrunner is to use a compass. Just hold it to the side of the motor and turn the shaft one lap. If the compass only change from North to South, it is a 2 pole motor.
MagnusEl is offline Find More Posts by MagnusEl
Old Oct 24, 2012, 03:03 AM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
My compass only has a sharp point and a pencil holder.... no Nth or Sth ???
LOL
That sounds like another good, and easy way, to check poles!
PeterVRC is offline Find More Posts by PeterVRC
Old Oct 24, 2012, 06:36 AM
davecrash is offline
Find More Posts by davecrash
Fly now crash later
davecrash's Avatar
Canada, ON, Newmarket
Joined Nov 2006
A new shipment of replacement blades came in at HK today, These should be the newest ones.
davecrash is offline Find More Posts by davecrash
Old Oct 24, 2012, 07:54 AM
4stripes is online now
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Thanks for the tip Magnus! I tried it on various motors using a cheap compass (from a satellite dish installation kit).
It seems to work for both inrunners and outrunners. The XK4060-1500 is indeed a 4 pole.
4stripes is online now Find More Posts by 4stripes
Old Oct 24, 2012, 07:58 AM
4stripes's Avatar
Joined Jan 2009
The last batch of replacement fans (without shroud or adapter) was also the heavier stronger plastic. I bought the last 6 they had and they all weighed just over 51g. If anyone has fans from HK bought in June/July 2012 I would replace the fan before it trashes the shroud and motor shaft.
Old Oct 24, 2012, 08:21 AM
DamonH is offline
Find More Posts by DamonH
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
I bought the asembly a couple weeks ago from HK. Should this one be the new version?
DamonH is offline Find More Posts by DamonH
Old Oct 24, 2012, 08:47 AM
4stripes's Avatar
Joined Jan 2009
The only way to know is to weigh the fan (minus adapter and spinner). If it is around 51g it should be stronger than the 45g version.
I ordered one a week ago but haven't received it yet.
Old Oct 24, 2012, 10:45 AM
vanderbrander is offline
Find More Posts by vanderbrander
Just an Earth bound misfit - I
vanderbrander's Avatar
Canada, ON, New Tecumseth
Joined Nov 2010
Has anyone run the new heavier fan at substantial power (+3500w) to confirm they are in fact stronger?
vanderbrander is offline Find More Posts by vanderbrander
Old Oct 24, 2012, 11:48 AM
out of stock is offline
Find More Posts by out of stock
Speed only
out of stock's Avatar
United States, FL, Lehigh Acres
Joined Jan 2012
i recieved my cs9012 wth the included 5mm and 8mm shaft adapters. i noticed something obvious. they drilled the spinner holes off centered on both but "B" is much more off centered. unfortanately "B" is the 5mm shaft which fits the shaft on my flyfly 1500kv. however, i did screw the spinner on anyway and it lands on correctly yet still im bothered about this.
here are some pictures taken with the old phone.
(the motor shaft adapter is what goes into "B" correct?) ive never put an edf unit together.
out of stock is offline Find More Posts by out of stock
Old Oct 24, 2012, 11:52 AM
D_FAST is offline
Find More Posts by D_FAST
D_FAST's Avatar
Denver CO
Joined Apr 2008
its not just off center but at a freakn angle as the back holes look pretty good
D_FAST is offline Find More Posts by D_FAST
Old Oct 24, 2012, 01:29 PM
DamonH is offline
DamonH's Avatar
Joined Oct 2011
Does that include the metal washer on the back and front side or is ALL metal removed and just the blades are weighed? Mine was around 47g with the washers still on. My guess is I have the v1
Old Oct 24, 2012, 01:51 PM
Speed only
Joined Jan 2012
i ran up the fan on a 4s and im really shocked how nice these units sound in person.
btw i dint realise that the motor shaft wasnt required. thankfully i was able to use the "slightly off centered" adapter. i will begin balancing tomorrow.
Old Oct 24, 2012, 02:03 PM
DamonH is offline
DamonH's Avatar
Joined Oct 2011
I think I'm lost...why do you say the "motor shaft wasn't required?
Old Oct 24, 2012, 03:09 PM
Speed only
Joined Jan 2012
my fault. i ment the motor shaft adapter that was supplied with the flyfly 1500kv outrunner wasn't required. sorry for that.
i have a question. i need to extend the esc wires. does it matter which wires? 3 wires or pos & neg wires?
im reading alot of modelers extend the motor wires from the esc using same gauge size or larger. if extending batt wires from the esc you must add caps. does this sound right?
Old Oct 24, 2012, 03:25 PM
4stripes's Avatar
Joined Jan 2009
The aluminum washers front and back are weighed but not the adapter or spinner.
Sounds like you have old stock at 47g.
Sold Zurich sun blocking sun-glasses $40 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 7 Oct 06, 2011 10:47 PM
Sold Zurich sun blocking sun-glasses $50 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 0 Oct 05, 2011 09:14 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Video 6 and 12 blade 90mm fan sound test tom bacsanyi Electric Plane Talk 3 Dec 10, 2009 07:01 PM
