Old Sep 30, 2012, 05:45 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Clearly shows melting around the bolts, and I dont see why it would be uncommon, 86A through a 3025 size motor is gonna get it hot, I run a hyperion S series 3025 at 100A burst in a hotliner style glider on 3s and if I get a little too carried away with my climbouts the motor is so hot you get burnt with a simple touch!
Extreme_RC is offline Find More Posts by Extreme_RC
Old Sep 30, 2012, 05:55 PM
PeterVRC is offline
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
Hard to tell from pics, you pretty well need to be able to pour over it yourself.... but the 'damage' looks like it could be heat OR loctite (chemical 'melt').
To melt the CS10 housing via heat - even to melt it a small amount - would need a lot of heat. You would most likely see SMOKE from the plane even, as the windings burnt as part of that (Even if just Shellac burning/charring). The motor would not get that hot just from running at high Watts in the 1800W area you mention. (which would also most likely have been what you saw when testing, not flying).
So I suspect loctite damage...
In Pic 1 you can see the 'bottom' screw remained in place, but the other three headed rightwards and allowed rotation of the motor, to be off centre and thus the end result then.
If it 'melted' that would allow sideways 'eating', and/or even the motor to come looser which then means the srews are only being held by their thread in that sideways direction (maybe those 3 loose then), so then they can do that 'eating' into the sideways directions.
But they would still only 'eat' if assisted by chemical or heat reaction.
Does the motor have any discolourations? As evidence of high heat.
Do you use a LOT of loctite? - as the 'melting' under the screw heads would mean it was oozing under them in that case.
I will do some tests on mine tonight or tomorrow night. It runs 1800W, and is in the same F-16 and motor (84Amps approx). So I will do heat checks on it in-plane, as it is being restricted by inlet airflow - well, inlet as far as I can work out so far. (working out how to put 'nice looking' cheaters into it). I have run it up a number of times, doing Amp and heat checks before and nothing was untoward. But not a full battery on WOT.
PeterVRC is offline Find More Posts by PeterVRC
Old Sep 30, 2012, 06:38 PM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Originally Posted by erh7771 View Post
What were the watt numbers on the motor?
1700 kv usually gets you around 100 amps on 6s
Sorry ERH
that is not the experience I have had. I tried a couple 1600kv motors on 6S with good batteries the amp draw was approx. 125A! There is the "factory" changesun"1600kv" outrunner that runs very close to 100A with a full charge, though I believe the Kv is actually closer to 1500.
My XK4074-B-1400 runs about 95A initially on good 6S batteries.
We are talking about the Changesun 90mm 12 blade fan aren't we?
4stripes is offline Find More Posts by 4stripes
Old Sep 30, 2012, 06:43 PM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
Petervrc raised a good point,
Locktite will melt plastic. Perhaps a couple drops made it onto the plastic and between the motor and shroud...
Old Sep 30, 2012, 07:01 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Originally Posted by 4stripes View Post
Sorry ERH
What c rating packs are you using?
I have 1600kv align motors that run close to 100 also but with 65c packs or brand new 45cs
Flip Flops HET 1480ish KV in the beginning of the thread was around 100 amps on 8s...so that's were I'm getting around 100 amps on 1700kv...actually I get around 108 on that 1700kv version of the l3025 motor
I think HET, Scorpion and ARC have some of the most accurate KV motors...
erh7771 is offline Find More Posts by erh7771
Old Sep 30, 2012, 07:04 PM
erh7771 is offline
Joined Nov 2005
Good info, I didn't know this!
I had TONS of loctite on the motor mount with the smaller heads...
I put the loctite on the screws first and then put them in, I remember that step distinctly...
Old Sep 30, 2012, 07:12 PM
4stripes is offline
4stripes's Avatar
Joined Jan 2009
My packs are 6s 5500mah 25c Gens ace. Great batteries by the way....
Old Sep 30, 2012, 07:21 PM
PeterVRC is offline
Joined Nov 2006
I use blue loctite on shaft adaptors (prob should use green really) and CA on motor screws.
I have not seen loctite melt plastic myself (yet), but too many people have mentioned it does, so I tried CA (as they also mentioned) and it seemed to work fine to me.
It is quite hard to use loctite and NOT get any on the housing/mount, for any fan - if you use it, then some will get there one way or another almost certainly.
I use it 'sparingly' (what I consider the right amount to fill thread, but never ooze - though some small amount still will), but I bet some people just slop it on! LOL
Maybe heat/warmth makes the loctite 'melt' happen even sooner/easier?
Old Sep 30, 2012, 07:27 PM
erh7771 is offline
Joined Nov 2005
I'm REALLY impressed with the Gens Ace..after using them I don't understand how some other packs could cost twice as much.
My observations is the heat, ..usually I don't care what the c rating of the packs is I don't like to take them over 30c cause of heat but with Gens the packs come down way cooler.... anyone know if they're making those packs out of a different factory?
Old Sep 30, 2012, 07:43 PM
koren9 is offline
Find More Posts by koren9
koren9's Avatar
Joined Jan 2010
Interesting point about the loctite peter , I will look into that .
also , the motor does not have any signs of overheating , but it would be great if you can take some temp reading in your F-16 with the same setup .
Thank you .
koren9 is offline Find More Posts by koren9
Old Sep 30, 2012, 07:51 PM
PeterVRC is offline
Joined Nov 2006
Yep, will do that tonight pretty surely. I finally finished mine to flyable state over the weekend.
I even ran it briefly on 7S, to up the power.... but that needs more detailed testing, and the poor 3025 probably won't like it being used for more than very short periods!!
Old Sep 30, 2012, 09:17 PM
PAPE is offline
Find More Posts by PAPE
Joined Jun 2012
I feel the same way about gens ace. I just hope the prices stay at what they are now.
PAPE is offline Find More Posts by PAPE
Old Sep 30, 2012, 09:25 PM
PAPE is offline
Joined Jun 2012
I did notice on a bench test of the cs12 3025 on 6s 30c zippy packs, that after a 90sec WOT test the motor was smoking but it was the oil I had cleaned the windings with *corrosion X*.
The motor got very hot, enough to smoke off the oil but the windings looked brand new, I haven't tested it again and I haven't finished the mirage its going in but I always thought about the heat affecting the shroud. I am going to test it again on gen aces 60c lipos again for at least 1min wot to see what happens before putting it in the plane.
Old Sep 30, 2012, 09:39 PM
v8truckin is online now
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
like ive said this motor isnt a good CS12 motor, gets too hot. Your planes arent worth the $17 this piece of #$% motor delivers.
v8truckin is online now Find More Posts by v8truckin
Old Sep 30, 2012, 10:56 PM
PeterVRC is offline
Joined Nov 2006
Yeah, when I was looking over my test 'notes' (comments on video of the test) I had noted how it seemed 'under duress' and not likely to last long term due to the heat levels. That was on 6S at 85A area, 1800W. On dual batteries I got 1900W.... but I wasn't clear on my views as to whether they were made on the single 6S, or the dual battery.
And I remember posting here, that long time back then, about how it seemed it was going to be a marginal motor. But I did (do still?) think it would be passable at that 1800W - the dual battery test is just to see what lower IR/higher-C could drive it to, as a reference against the single battery I would use.
I guess I should unbolt it from the plane for tests....
Sold Zurich sun blocking sun-glasses $40 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 7 Oct 06, 2011 10:47 PM
Sold Zurich sun blocking sun-glasses $50 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 0 Oct 05, 2011 09:14 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Video 6 and 12 blade 90mm fan sound test tom bacsanyi Electric Plane Talk 3 Dec 10, 2009 07:01 PM
