Old Sep 08, 2012, 03:58 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
Originally Posted by scunna View Post
is that with an inteake lip??
I got 3059awtts with the exact same setup but the EDF was IN the HK L-59
pavcon is offline Find More Posts by pavcon
Old Sep 08, 2012, 10:29 AM
karlkeh is offline
Find More Posts by karlkeh
Joined Sep 2012
http://u.youku.com/TW-TORNADO or http://www.tw-tornado.com/
karlkeh is offline Find More Posts by karlkeh
Old Sep 08, 2012, 06:26 PM
SkylineFlyer is offline
Find More Posts by SkylineFlyer
Hawk Fanatic
SkylineFlyer's Avatar
United States, KY, Louisville
Joined Jul 2008
Got 3 more flights today at E-Jets. I believe that is 21 flights now on this fan!
SkylineFlyer is offline Find More Posts by SkylineFlyer
Old Sep 09, 2012, 02:23 AM
scunna is offline
Find More Posts by scunna
scunna
scunna's Avatar
United Kingdom, England, South Shields
Joined May 2007
No intake lip
scunna is offline Find More Posts by scunna
Old Sep 09, 2012, 08:40 AM
PeterVRC is online now
Find More Posts by PeterVRC
Australia, VIC, Melbourne
Joined Nov 2006
As long as the plane has 'good' ducting path and openings, it can match the EDF outside with an intake lip. Though quite often in-plane you will end up with a bit less, because the ducting is not optimal. Of course it depends on the plane, and/or whether or not improvement was needed on its ducting.
PeterVRC is online now Find More Posts by PeterVRC
Old Sep 11, 2012, 06:08 PM
washab is offline
Find More Posts by washab
ROLL, PITCH, YAW
washab's Avatar
Joined Jan 2011
INPUT WELCOME
Did a run-up on the bench...
6S 4000mah 40~50c Trunigy
100A Hobby Pentium
1500Kv Outrunner Motor
CS90 12 Blade
1750 watts
80A peak
~16V
Thrust???
Battery was just under full charge.
How my numbers look? This is going in the Freewing 90mm F-18. Carbon copied the setup after I saw V8truckin's vid...
washab is offline Find More Posts by washab
Old Sep 11, 2012, 06:48 PM
Joined Nov 2006
Sounds very close to numbers I get. I had 84A, 2.9Kg thrust.
So your listed ones are fractionally lower... probably 2.8Kg thrust.
Of course it will be less in-plane.
Old Sep 11, 2012, 11:39 PM
anlucas is online now
Find More Posts by anlucas
anlucas's Avatar
Greece, Attica, Athens
Joined May 2011
Originally Posted by washab View Post
INPUT WELCOME
100A Hobby Pentium
CS90 12 Blade
1750 watts
80A peak
~16V
Thrust???
The only worrying bit is the battery.
16V?
That 16/6=2.66V per cell. You may have a bad 6S lipo with a dead cell....
This explains the low amps for a 1500kv...
anlucas is online now Find More Posts by anlucas
Old Sep 11, 2012, 11:50 PM
nighthawk0077 is offline
Find More Posts by nighthawk0077
Canada, ON, Vaughan
Joined Oct 2009
INPUT WELCOME
100A Hobby Pentium
CS90 12 Blade
1750 watts
80A peak
~16V
Thrust???
Im no CS12 expert but on 6S you should have been closer to 2200watts and 100amps. Sounds like you were on 5S?
nighthawk0077 is offline Find More Posts by nighthawk0077
Old Sep 12, 2012, 12:40 AM
Jacques.Eloff is offline
Find More Posts by Jacques.Eloff
Jacques.Eloff's Avatar
United Kingdom, England, Cobham
Joined Oct 2007
INPUT WELCOME
100A Hobby Pentium
CS90 12 Blade
1750 watts
80A peak
~16V
Thrust???
I would throw that pack in the trash can. You're not even getting the voltage that 5S should deliver, let alone 6S! In fact some 4S packs at full charge will hold up more than that!
Are you sure you're actually trying 6S?
Jacques.Eloff is offline Find More Posts by Jacques.Eloff
Old Sep 12, 2012, 01:46 AM
Joined Nov 2006
His volts reading he listed is just wrong.....
Can't you guys add up that 80A and 1750W cannot be 16V .....
I have the 3025-1500kv and it does 84A 1800W or so..... so his is doing what it roughly should. And the 16v is plain to see incorrect.
1800w / 84A = 21.4V Non Nano battery here also (Zippy 6S 5800mAH 30C)
1750W / 80A = 21.8V
So the motors for each case are a little bit different, but very close overall really. Both their true KV's probably very, very close to the same.
Old Sep 12, 2012, 07:54 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
INPUT WELCOME
100A Hobby Pentium
CS90 12 Blade
1750 watts
80A peak
~16V
Thrust???
6-6.5lbs, same thing I did with the SUPPO 1500 (labelled 1300kv)
erh7771 is offline Find More Posts by erh7771
Old Sep 12, 2012, 08:19 AM
v8truckin is offline
Find More Posts by v8truckin
Should've, Would've, Could've
v8truckin's Avatar
United States, CA
Joined Dec 2010
Washab,
Numbers look right cept for the voltage, musta been a typo like Peter said.
Also on that airframe you don't need to pushing 2000w+ and 90a+ you may find she is fast enough and has enough thrust with that setup.
v8truckin is offline Find More Posts by v8truckin
Old Sep 12, 2012, 08:55 AM
pavcon is offline
Joined Jan 2010
Originally Posted by v8truckin View Post
Washab,
you should be right.. 9 is right above 6 so setling at 19v is not so inaccurate for an old pack
Old Sep 12, 2012, 11:45 AM
vanderbrander is offline
Find More Posts by vanderbrander
Just an Earth bound misfit - I
vanderbrander's Avatar
Canada, ON, New Tecumseth
Joined Nov 2010
I got something like 2300w, 103amps peak and 3.25kg thrust from the HK3025 but my batt was a brand new genace 6s 5300 60c. Big difference in pack performance, although he did say his wasn't fully charged.
vanderbrander is offline Find More Posts by vanderbrander
Sold Zurich sun blocking sun-glasses $40 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 7 Oct 06, 2011 10:47 PM
Sold Zurich sun blocking sun-glasses $50 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 0 Oct 05, 2011 09:14 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Video 6 and 12 blade 90mm fan sound test tom bacsanyi Electric Plane Talk 3 Dec 10, 2009 07:01 PM
