Old Sep 05, 2012, 04:53 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
Originally Posted by jcdfrd View Post
thats a car motor pav
SO AS THE XK4074
They are the same thing
pavcon is offline Find More Posts by pavcon
Old Sep 05, 2012, 04:54 PM
pavcon is offline
Joined Jan 2010
Originally Posted by SkylineFlyer View Post
I'm willing to learn. Why can we use a heli motor and not a car motor? I honestly don't know.
again.. it's the same motor as hk...
slight changes.. but same specs and same made.
it only costs a bit more
Old Sep 05, 2012, 04:56 PM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
Most if not all the 40mm canned motors are "car" motors, I first used one for edf in a haoye 7 blade shroud. Then I shaved .5 mm off the inside of the CS12 and posted numbers...
Since then they've been made popular for EDF...
HET and some other makers were using 39mm motors with open cap ends the, "car motors" have closed ends to keep dirt out.
If the car motors end caps are kept closed (no holes drilled) the windings or magnets fail and it a very stank nasty way. If they're no holes drilled almost like a pressure cooker...the heat just keeps building up.
Take the end caps off the 40mm motors and drill holes over 2000 watts
Recently I tried another 7 blade haoye with a TACON 40mm, shoot...cant stand the rotor whine now...no matter how balanced they < 10 blade fans are the whine drowns out the white noise.
Check Himodel.com...they have 40mm Suxfly motors (yes, they're all suxfly made but some different magnets) motors and I think they might have the 1400kv a little less than the leopard stamp.
Edit: Here's the himodel 1400kv - http://www.himodel.com/electric/SUXF...r_4065_4Y.html
As I wrote earlier in this thread the HK 1400kv 40mm motor was actually 60mm long in a 74mm long can ...the 60mm long windings don't go to the end of the can but on 8s it's a go with holes drilling in both ends of the caps and gets the FF F100 going stupid fast...
The Himodel 1400kv 40mm motor seems to establish this because It's a 40mm D 60mm L can and its 40usd...
really thinking of getting a couple...
erh7771 is offline Find More Posts by erh7771
Old Sep 05, 2012, 05:02 PM
SkylineFlyer is offline
Find More Posts by SkylineFlyer
Hawk Fanatic
SkylineFlyer's Avatar
United States, KY, Louisville
Joined Jul 2008
Originally Posted by 4stripes View Post
Before drilling the holes I ran 7S and after dozens of flights it eventually smoked. Now with the holes I plan to run it 7S again but expect the temps to be 30-40F cooler.
Unclecrash
I left the plastic end piece in the motor as there is still enough room to allow airflow.
Cheers
Thanks for the reply.
What does everyone recommend if I was to go to a 8s setup? The 6s is fun, but just too slow. The vertical is lacking.
SkylineFlyer is offline Find More Posts by SkylineFlyer
Old Sep 05, 2012, 05:09 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
as erh just said car motors are a closed can design to keep dirt out the problem is they keep heat in. heli motors and edf motors are a open can or bell design to vent heat also the way the wires exit the can on the car motors can create an issue when installing to an edf housing, not always but in some situations. the wires are a minor issue the heat is the major problem with them. some guys will spend 80bucks on a car motor and take it apart and drill holes for cooling and reassemble to be used in their edf, I just prefer to buy the right edf motor in the first place and not have to modify it and risk possibly damaging it
jcdfrd is offline Find More Posts by jcdfrd
Old Sep 05, 2012, 05:17 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
Het 700-68-1200kv
Old Sep 05, 2012, 05:30 PM
Hawk Fanatic
Joined Jul 2008
Het 700-68-1200kv
Thanks bud. I sold my Habu32 and miss it already! Are any of the HK fiberglass 90mm jets contenders in the speed category of the habu32?
Old Sep 05, 2012, 06:40 PM
4stripes is online now
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
The Suxfly and Leopard motors look good but the threaded mounting holes won't match the CS fan shroud. The end cap would have to be drilled and tapped if you wanted the 4 regular mounting screw pattern.
erh777
The 4074 windings don't fill the can completely but they are about 1cm longer than the 4060 as are the magnets on the shaft. The 4074 will handle the load much better than a 4060 (as I found out).
Cheers
Compare the 2 motor shafts....
4stripes is online now Find More Posts by 4stripes
Old Sep 05, 2012, 06:44 PM
erh7771 is offline
Joined Nov 2005
Check out the viper, for the 100 less you have to do some handy person work...
I have time so I usually choose the handy person work and having over 50 jets...
Hi I'm erh7771 and I'm addicted to EDF jets...
Cept today....
had one of those days...1 esc smoked on runway (better than in air), one plane crashed in the fence...trimmed really bad looks like a servo skipped a tooth, and one flipped...
O well
Old Sep 05, 2012, 06:46 PM
pavcon is offline
Joined Jan 2010
never realised the habu was fast :/ we got a couple at our field and the speed isn't exactly blistering.
as I told you with my HK L-59 and 3000watts which are easy to get with 8s I got around 140mph
Old Sep 05, 2012, 06:47 PM
4stripes's Avatar
Joined Jan 2009
HK viperjet
http://www.hobbyking.com/hobbyking/s...dProduct=15536
and Mig 15
http://www.hobbyking.com/hobbyking/s...27mm_ARF_.html
come to mind...
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
O well
You still got 47 left, what u complaining about LOL
Extreme_RC is offline Find More Posts by Extreme_RC
Old Sep 05, 2012, 06:48 PM
pavcon is offline
Joined Jan 2010
ph and I also have the HK viperjet90.. will be maidenned on the 20th this month
Old Sep 05, 2012, 06:58 PM
davecrash is offline
Find More Posts by davecrash
Fly now crash later
davecrash's Avatar
Canada, ON, Newmarket
Joined Nov 2006
I have both, nice jets.
davecrash is offline Find More Posts by davecrash
Old Sep 05, 2012, 07:13 PM
unclecrash is offline
Find More Posts by unclecrash
unclecrash's Avatar
white lake michigan
I am going to drill my 4074 when I get my mill up and going, But Im also going to drill the sides. And I will add 2 tubes size of drinking straws into the side holes bent on a 90 degree and facing froward into the airstream of the fan. The tubes will be ovaled out to minimize there footprint into the airstream. Ram air effect it will be night and day I garantee it. I have dont this before on a glider and it was night and day difference. This time I will take temp reading before and after on this motor. I don't know when I will get to it but it will be cool to see how much heat I can shed.
unclecrash is offline Find More Posts by unclecrash
Sold Zurich sun blocking sun-glasses $40 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 7 Oct 06, 2011 10:47 PM
Sold Zurich sun blocking sun-glasses $50 shipped MJB9 Aircraft - General - Miscellaneous (FS/W) 0 Oct 05, 2011 09:14 PM
Sold Change Sun electric retracts Flip Flop Aircraft - Electric - Jets (FS/W) 3 May 23, 2011 06:20 AM
Sold Change Sun Electronic retracts w/Lander struts hole digger Aircraft - Electric - Jets (FS/W) 2 May 06, 2011 01:27 PM
Video 6 and 12 blade 90mm fan sound test tom bacsanyi Electric Plane Talk 3 Dec 10, 2009 07:01 PM
